trying to uninstall HomeKit Bridge for a reinstall
Mon Oct 28, 2019 2:50 am
erikwegman offline
I am trying to completely delete the HomeKit Bridge 1.0.2 plugin to doe a fresh reinstall since it did not work any work anymore. Since there isn't a simple 'deinstall' button I tried to remove the different files associated with the plugin. I think I got most of them but in the plugin menu it still shows the plugin. When I try to start it gives an error (logically) since it cannot find its files.
If I want to reinstall the plugin now it says that the latest version is already installed but it needs to be enabled (which cannot happen since files are missing).
How do I let Indigo 7.4 'forget' the plugin was installed so I can do this over?
Mon Oct 28, 2019 3:49 am
Re: trying to uninstall HomeKit Bridge for a reinstall
Make sure you delete this preference folder:
/Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.eps.indigoplugin.homekit-bridge
Also, make sure the plugin is deleted from within the Plugins and Plugins (Disabled) folders located here:
Then stop and restart the Indigo server and it should be gone. :)
Mon Oct 28, 2019 5:09 am
erikwegman offline
Thanks, I dis all of that but it needed a complete reboot of the Mac te be able to install the plugin again.
Mon Oct 28, 2019 9:25 am
erikwegman wrote:
Thanks, I did all of that but it needed a complete reboot of the Mac to be able to install the plugin again.
I guess there may be other Home Bridge related processes running?
Did you restart the Indigo Server or the Indigo client or both?
