Transferring Licence to a New Computer
Thu Feb 22, 2024 6:57 am
Betacruxis offline
Transferring to a New Computer
Hi.
I have migrated from an Intel iMac to a new M3 iMac and used a Time Machine backup to transfer all data, apps and configuration setting.
I deactivated the Indigo license on the old Mac.
When I tried to run the indigo client, it didn`t work. Start server window appears, but after that no window appeared on the screen, all menu items for the client were disables and the server is not running.
Just to be on the safe side, I un-installed and re-installed Indigo on the new Mac, but somehow it is not running. Same behavior.
The license details item on the menu was enabled, so I tried to activate the license, but the window that opens seems not to be working (image attached).
What did I miss or did wrong?
Thu Feb 22, 2024 11:17 am
Re: Transferring Licence to a New Computer
Stop the server, delete the following file:
/Library/Application Support/Perceptive Automation/Indigo 2023.2/Preferences/Indigo Registration.indiPref
then restart the server. You'll need to log back in to your Indigo Account.
Thu Feb 22, 2024 11:36 am
Betacruxis offline
Thanks Jay.
Did all the steps, deleted the registration file, on client opening it asked to accept EULA, which I did and then the server started without asking me to log-in into my account.
No client window were opened and shows the same behavior, except for the License details window.
The server seems to be running as per Activity Monitor, but inaccessible from a browser or Indigo Touch app. And also stops when terminating the client app.
The registration file (Indigo Registration.indiPref) which was created again, reads:
<RegDatabase type="dict">
<RegistrationInfo type="dict">
<EulaAccepted type="bool">true</EulaAccepted>
</RegistrationInfo>
</RegDatabase>
But License details is asking to accept EULA.
I'm lost.
License 2.jpg (23.16 KiB) Viewed 250 times
Thu Feb 22, 2024 1:14 pm
When moving Macs did you follow all the steps here? Specifically, you probably need to delete the Python.framework folder and re-run the Indigo installer.
Thu Feb 22, 2024 4:03 pm
Betacruxis offline
Actually I have had not deleted the Python framework. So I did it and reinstalled Indigo, but the issue remained.
Then I tried a full uninstall again, making sure no trace of Indigo remained, even from previous versions, and deleted again all Python frameworks too.
Restarted the iMac, reinstalled Indigo and finally all went well: accepted EULA and could log-in into my account again.
I must have missed something on the previous uninstall.
Thanks again for your support and guidance.
Best regards.
