2017-10-18 21:28:09.226 Error Event cannot be executed because it contains PRO only featues
howartp wrote:At risk of stating the obvious, have you tried the Window menu > Home Window, or Window menu > Bring all to front?
And checked other desktops (swipe left/right on a magic trackpad, or equivalent)?
matt (support) wrote:Does the Indigo 7->Stop Server menu item work? And how about a screen shot of the Indigo 7->Start Local Server... menu (resulting dialog) after stopping the server?
2017-10-18 21:53:45.561 Application Starting Indigo Server version 7.1.0 (Mac OS X 10.12.6)
2017-10-18 21:53:45.739 Error Error in plugin execution serverAdjunct init:
File "sa_main.py-min", line 22, in init sa_main (/Users/mattb/Perceptive Automation/Code/Indigo/Server Adjunct/build/sa_main.c:6806)
File "sa_geturl.py-min", line 9, in init sa_geturl (/Users/mattb/Perceptive Automation/Code/Indigo/Server Adjunct/build/sa_geturl.c:6746)
File "/Library/vendored/tlsssl/ssl.py", line 97, in <module>
ImportError: dlopen(/Library/vendored/tlsssl/_ssl.so, 2): Symbol not found: _CRYPTO_THREADID_set_callback
Referenced from: /Library/vendored/tlsssl/_ssl.so
Expected in: flat namespace
in /Library/vendored/tlsssl/_ssl.so
2017-10-18 21:53:45.741 Error Error in plugin execution licenseCheckFunc1: InvalidParameterError -- plugin does not define method localCachedLicenseCheck
2017-10-18 21:53:45.741 Application Loading attachments
2017-10-18 21:53:45.745 Application "device target attachment.scpt" script loaded
2017-10-18 21:53:45.747 Application "group target attachment.scpt" script loaded
2017-10-18 21:53:45.752 Application "growl attachment.scpt" script loaded
2017-10-18 21:53:45.763 Application "iTunes attachment.scpt" script loaded
2017-10-18 21:53:45.768 Application "scenes attachment.scpt" script loaded
2017-10-18 21:53:45.772 Application "time stamp attachment.scpt" script loaded
2017-10-18 21:53:45.875 Application Loading database "/Users/mediaserver/Documents/howardtp.indiDb"
2017-10-18 21:53:47.070 Application Found plugin "Action Collection 2.0.4" (requires pro version)
2017-10-18 21:53:47.071 Application Loading interface "INSTEON Commands 2.0.10"
2017-10-18 21:53:47.076 Application Starting interface "INSTEON Commands 2.0.10" (pid 23266)
2017-10-18 21:53:47.078 Application Loading interface "Z-Wave 2.0.103"
2017-10-18 21:53:47.081 Application Starting interface "Z-Wave 2.0.103" (pid 23267)
2017-10-18 21:53:47.085 Application Found plugin "Adapters 1.0.0" (requires pro version)
2017-10-18 21:53:47.086 Application Found plugin "Alexa-Hue Bridge 2.0.2" (requires pro version)
2017-10-18 21:53:47.087 Application Found plugin "Autelis Jandy 1.2.9.6" (requires pro version)
2017-10-18 21:53:47.088 Application Found plugin "UPS and Battery Monitor 1.03" (requires pro version)
2017-10-18 21:53:47.089 Application Found plugin "Beacon 1.5.2" (requires pro version)
2017-10-18 21:53:47.090 Application Found plugin "Better Email 7.1.2" (requires pro version)
2017-10-18 21:53:47.092 Application Found plugin "Cynical Behaviors 1.0.5" (requires pro version)
2017-10-18 21:53:47.093 Application Found plugin "ELK M1G Control 1.1.1" (requires pro version)
2017-10-18 21:53:47.094 Application Found plugin "EPS - Homebridge Buddy 0.12" (requires pro version)
2017-10-18 21:53:47.095 Application Found plugin "Global Property Manager 2.0" (requires pro version)
2017-10-18 21:53:47.096 Application Found plugin "Hue Lights 1.5.2" (requires pro version)
2017-10-18 21:53:47.099 Application Found plugin "Backup 0.95" (requires pro version)
2017-10-18 21:53:47.100 Application Found plugin "Pushover 1.1.5" (requires pro version)
2017-10-18 21:53:47.102 Application Found plugin "Masquerade 0.0.1" (requires pro version)
2017-10-18 21:53:47.103 Application Found plugin "MyQ 7.1.8" (requires pro version)
2017-10-18 21:53:47.105 Application Found plugin "NOAA Weather Plus 1.1.19" (requires pro version)
2017-10-18 21:53:47.106 Application Found plugin "Rachio Sprinklers 1.0.2" (requires pro version)
2017-10-18 21:53:47.108 Application Found plugin "SQL Logger 2.0.7" (requires pro version)
2017-10-18 21:53:47.109 Application Found plugin "Survey Plugin 2.21" (requires pro version)
2017-10-18 21:53:47.110 Application Found plugin "utilities 1.12.1" (requires pro version)
2017-10-18 21:53:47.111 Application Found interface "Virtual Devices 2.0.4" (requires pro version)
2017-10-18 21:53:47.111 Application Found plugin "WeatherSnoop 2.1.3" (requires pro version)
2017-10-18 21:53:47.112 Application Found plugin "WUnderground 1.0.04" (requires pro version)
2017-10-18 21:53:47.113 Application Found plugin "Z-Wave Lock Manager 1.1.3" (requires pro version)
2017-10-18 21:53:47.114 Application Found disabled plugin "Airfoil Pro 1.0.7"
2017-10-18 21:53:47.115 Application Found disabled plugin "Cynical SecuritySpy 2.2.2"
2017-10-18 21:53:47.117 Application Found disabled plugin "EasyDAQ Relay Card 2.0.3"
2017-10-18 21:53:47.120 Application Found disabled plugin "Enphase Envoy Plugin 0.1.1"
2017-10-18 21:53:47.121 Application Found disabled plugin "Example Device - Thermostat 1.0.8"
2017-10-18 21:53:47.124 Application Found disabled plugin "GhostXML 0.2.01"
2017-10-18 21:53:47.125 Application Found disabled plugin "Growl 2.0.2"
2017-10-18 21:53:47.127 Application Found disabled plugin "iCal Alarm Processor 2.0.1"
2017-10-18 21:53:47.128 Application Found disabled plugin "INDIGOplotD 4.16.12"
2017-10-18 21:53:47.130 Application Found disabled plugin "iTunes 2.0.4"
2017-10-18 21:53:47.132 Application Found disabled plugin "Matplotlib 0.2.00"
2017-10-18 21:53:47.134 Application Found disabled plugin "NOAA Weather 2.0.1"
2017-10-18 21:53:47.137 Application Found disabled plugin "Roomba 0.0.4"
2017-10-18 21:53:47.139 Application Found disabled plugin "Timers and Pesters 2.0.2"
2017-10-18 21:53:47.140 Application Found disabled plugin "uniFiAP 7.0.25"
2017-10-18 21:53:47.164 Application Bonjour registered "Indigo - Dove Road"
2017-10-18 21:53:47.547 Application Indigo Cocoa client connected
2017-10-18 21:53:47.550 Error Error in plugin execution licenseCheckFunc2: InvalidParameterError -- plugin does not define method remoteStartLicenseCheck
2017-10-18 21:53:47.640 Reflector starting reflector connection to https://bollar.indigodomo.net
2017-10-18 21:53:47.862 Application Started interface "INSTEON Commands 2.0.10"
2017-10-18 21:53:48.343 Application WebServer client connected
2017-10-18 21:53:48.359 Application Started interface "Z-Wave 2.0.103"
2017-10-18 21:53:48.372 WebServer started on port 8176 -- digest authentication enabled
2017-10-18 21:53:48.661 Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodemFD131 (firmware 1.00)
2017-10-18 21:53:48.947 Z-Wave found module included in controller with no matching device (missing or disabled): 024 - Binary Sensor (routing)
howartp wrote:(Do you want to remove your address (DB Name) from that log. Together with your signature I reckon I could find your house pretty easy)
howartp wrote:I’ll be round for tea. Get the kettle on.
matt (support) wrote:This is definitely the problem:
- Code: Select all
Have you installed any 3rd party versions of Python? Or maybe Python SSL related libraries?
I'm running macOS 10.12.6 as well here, so I don't think the problem is specific to that version of macOS. Instead it is somehow configuration related.
Also launch the Terminal app, then start up python by entering:
python
then try:
import ssl
Copy/paste the result if there is an error.
Last login: Wed Oct 18 07:33:50 on console
server:~ mediaserver$ python -V
Python 2.7.10
Python 2.7.10 (default, Feb 7 2017, 00:08:15)
[GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import ssl
