No GUI After 7.1 Upgrade
Sat Nov 11, 2017 4:09 pm
Albatros offline
Re: No GUI After 7.1 Upgrade
Did a reinstall of 7.1.1 and starts quickly. Lost quite a few plugins. But the panasonic plugin is their. Also some errors in the log.
11 nov. 2017 23:03:46
Starting Indigo Server version 7.1.1 (Mac OS X 10.11.6)
Loading attachments
Loading database "/Library/Application Support/Perceptive Automation/Indigo 7/databases/My House (Exemplaar met conflict van Mac mini van Taco 2017-11-11).indiDb"
Loading plugin "Action Collection 2.0.4"
Starting plugin "Action Collection 2.0.4" (pid 938)
Loading interface "Z-Wave 2.0.111"
Starting interface "Z-Wave 2.0.111" (pid 939)
Loading plugin "Panasonic Network Remote 0.1.0"
Starting plugin "Panasonic Network Remote 0.1.0" (pid 940)
Found disabled interface "INSTEON Commands 2.0.10"
Error plugin ".Z-Wave.indigoPlugin" is missing file: /Library/Application Support/Perceptive Automation/Indigo 7/Plugins (Disabled)/.Z-Wave.indigoPlugin/Contents/Info.plist
Found disabled plugin "Airfoil Pro 1.0.9"
Found disabled plugin "EasyDAQ Relay Card 2.0.3"
Found disabled plugin "Global Property Manager 2.0"
Found disabled plugin "Growl 2.0.2"
Found disabled plugin "iCal Alarm Processor 2.0.1"
Found disabled plugin "iTunes 2.0.4"
Found disabled plugin "NOAA Weather 2.0.1"
Found disabled plugin "SQL Logger 2.0.7"
Found disabled plugin "Timers and Pesters 2.0.2"
Found disabled interface "Virtual Devices 2.0.4"
Found disabled plugin "WeatherSnoop 2.1.3"
Error InitializeThread() caught exception: LowLevelBadParameterError
Error failed to create reflector connection: public/private keys not found
Indigo Cocoa client connected
Started plugin "Action Collection 2.0.4"
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Started plugin "Panasonic Network Remote 0.1.0"
Started interface "Z-Wave 2.0.111"
Sat Nov 11, 2017 4:20 pm
It looks like there are some file/drive problems on your Mac. That particular file that is missing is definitely installed by the installer, so if it cannot be found now something has gone wrong. I'd suggest running First Aid from the Disk Utility app, rebooting the Mac, the re-downloading and running the Indigo installer.
Sat Nov 11, 2017 9:46 pm
hensed offline
Looks like I'm having the same problem on 2 separate Macs - the one running the server and the client. I rebooted, then installed the x.1 update. GUI seems to be working again on client and server.
Sun Nov 12, 2017 1:09 am
Albatros’s database is also subject to conflicting copies being synced to or from somewhere.
Sun Nov 12, 2017 1:28 pm
Albatros offline
Thanks all. Did a new fresh install and it is working again. Installing went very well and quickly as before it took almost 30 minutes. Maybe the last had to do with the use of Dropbox syncing.
I can't completely reproduce what went wrong but the second complete stop of working had to do with the indigo directory synched to Dropbox. Maybe this isn't smart to do I was think of as a regular backup of indigo. This never gave any problem as off yesterday Indigo stopped working completely. Not sure why but I was thinking of stopping the syncing of dropbox-indigo but I did and . then I deleted the dropbox files. Didn't read the message of dropbox that it would remove also the files on the mac. So that is the sync error in the log file.
But if the dropbox-indigo syncing also caused the problems of de slow installation and the not working of the GUI, i don't no.
For know no problems anymore.
