any update on this ?
.. still getting the prompts --- I will be traveling next week and would like to make sure indigo stays up.
kw123 wrote:would like to make sure indigo stays up.
jay (support) wrote:Note: Indigo does not need to continuously connect once activated (but it does ping periodically) - if Indigo can't connect to our backend servers it will continue to run fine. So even if this dialog is open it will still continue to run correctly. Logging in should make the recurring popup go away for a while, but something does appear to be making it popup again at a later date, and that's what we're investigating.
