Upgraded to 7.0.3, however nothing seems to work
Fri Jun 09, 2017 3:15 am
matei offline
Hi all,
Upgraded to 7.0.3 from the last version of 6. Installed w/o issues, start the service and I can see all my devices.
Nothing is greyed out, and no red warnings - however nothing works. If I click on a LightwaveRF device, to turn it on/off - nothing. Same with a Z-wave device.
I can get battery status etc, it looks like they're communicating - but just no commands are being executed.
Has anyone else seen this?
I've not uninstalled 6 yet.
Fri Jun 09, 2017 8:58 am
Re: Upgraded to 7.0.3, however nothing seems to work
So, when you select a Z-Wave device and click the Send Status Request, nothing happens? Does the status bar in the lower left corner of the Home Window do anything? Anything show in the Event Log window?
Tue Jun 13, 2017 2:45 am
matei offline
I managed to get the Zwave devices to work - that was a simple hardware issue, however the LWRF devices just don't work at all.
If I click on a light switch for example, there is no change from off to on or vice versa.
Tue Jun 13, 2017 10:03 am
I'm assuming you're using an RFXCOM to communicate with your LWRF devices - is the 3rd party RFXCOM plugin enabled? Is it configured correctly?
Tue Jun 20, 2017 11:12 am
matei offline
Hi, sorry about the delay - yes, using RFXCOM.
Nothing in the event log save for Error send "hall lamp" failed.
Tue Jun 20, 2017 1:22 pm
Ok - you'll want to post your question over in the RFXCOM subforum since that's a 3rd party plugin.
