Restarting Indigo, my interface disappears (PART 1)
Sat May 13, 2017 11:28 pm
alpitmaster offline
Matt, this post follows my previous post, "7.0.3.Update Issues," to which you replied, Since I was able to successfully install the update, I decided a new topic is in order.
I think I may be bringing you a watch in a paper bag and asking you to put it back together.
Every time I restart Indigo, the following sequence of events occurs:
    Indigo tells me that my database no longer exists or is corrupt
    It gives me the options create a new database or use an existing one
    When I elect to choose an existing one, it shows me the name of my database
    I choose the existing database
    Indigo tells me that a new Powerlinc has been connected or I have updated to a new version of Indigo, so I must resync. (this has happened multiple times since I updated successfully)
    I choose to resync all devices
    Indigo then tells me that my interface is not connected (which it is) and that I must enable it
    I enable the interface, including choosing a port
    It then tells me to resync
    I resync, including skipping all my battery powered sensors manually, (I grow a beard)
    All of my devices appear in the device list (they were there before, but they are now black instead of red)
    I test a few devices, to confirm that they are functioning properly
    I fill in the form to start the local server, so that it is available for Indigo Touch, etc., and click the restart server button
    Indigo informs me that my database is no longer connected, and I must choose one
    RETURN to beginning of this list. (it's an endless loop)
Where should I go from here? I'm wondering if I need to reset my interface (2413U), but if I have 60 devices, 64 triggers, 14 schedules, and 16 action groups. I'd like to preserve as much of that as possible.
I am appending my restart log. Will send the re-sync log in separate post. Too long to include here.
Event log for last restart:
May 13, 2017, 11:19:20 PM
Starting Indigo Server version 7.0.3 (Mac OS X 10.10.3)
Loading attachments
Loading database "/Library/Application Support/Perceptive Automation/Indigo 7/Databases/Sample House.indiDb"
Error XML Parse Error: no element found
Error On character 0 of line number 1.
Error failed to load database file
Loading plugin "Action Collection 2.0.4"
Starting plugin "Action Collection 2.0.4" (pid 2452)
Loading interface "INSTEON Commands 2.0.10"
Starting interface "INSTEON Commands 2.0.10" (pid 2453)
Loading plugin "Messages 0.1.1"
Starting plugin "Messages 0.1.1" (pid 2454)
Loading plugin "Timers and Pesters 2.0.2"
Starting plugin "Timers and Pesters 2.0.2" (pid 2455)
Found disabled interface "Z-Wave 2.0.68"
Found disabled plugin "Airfoil Pro 1.0.7"
Found disabled plugin "Airfoil 1.1.11"
Found disabled plugin "DIRECTV DVR Control 1.1.0"
Found disabled plugin "EasyDAQ Relay Card 2.0.3"
Found disabled plugin "Global Property Manager 2.0"
Found disabled plugin "Growl 2.0.2"
Found disabled plugin "iCal Alarm Processor 2.0.1"
Found disabled plugin "iTunes 2.0.4"
Found disabled plugin "NOAA Weather 2.0.1"
Found disabled plugin "SQL Logger 2.0.5"
Found disabled plugin "Vera Bridge 1.0.8"
Found disabled interface "Virtual Devices 2.0.4"
Found disabled plugin "WeatherSnoop 2.1.2"
Started plugin "Action Collection 2.0.4"
Started plugin "Timers and Pesters 2.0.2"
Started interface "INSTEON Commands 2.0.10"
Started plugin "Messages 0.1.1"
Indigo Cocoa client connected
Disabling interface "INSTEON Commands 2.0.10"
Stopping interface "INSTEON Commands 2.0.10" (pid 2453)
Stopped interface "INSTEON Commands 2.0.10"
May 13, 2017, 11:19:59 PM
Stopping plugin "Action Collection 2.0.4" (pid 2452)
Stopping plugin "Timers and Pesters 2.0.2" (pid 2455)
Stopping plugin "Messages 0.1.1" (pid 2454)
Stopped plugin "Action Collection 2.0.4"
Stopped plugin "Timers and Pesters 2.0.2"
Stopped plugin "Messages 0.1.1"
Loading database "/Library/Application Support/Perceptive Automation/Indigo 6/Databases/WMSLights.indiDb"
Database file was in old Indigo 6 folder
Saving converted database file "/Library/Application Support/Perceptive Automation/Indigo 7/Databases/WMSLights 10.indiDb"
Switching to database "WMSLights 10"
Starting plugin "Action Collection 2.0.4" (pid 2478)
Starting plugin "Messages 0.1.1" (pid 2479)
Starting plugin "Timers and Pesters 2.0.2" (pid 2480)
Found disabled interface "INSTEON Commands 2.0.10"
May 13, 2017, 11:20:00 PM
May 13, 2017, 11:20:09 PM
Timers and Pesters Debug logging disabled
May 13, 2017, 11:30:00 PM
Schedule Evening OFF
Sent (offline) "Front Yard. Porch & Uplights" off
Sent (offline) "Greenhouse. Steps" off
Sat May 13, 2017 11:32 pm
alpitmaster offline
Re: Restarting Indigo, my interface disappears (PART 1)
This is the first half of the event log for the re-sync process, for the above post:
Event log for last re-sync (FIRST HALF):
May 14, 2017, 12:01:12 AM
Enabling interface "INSTEON Commands 2.0.10"
Starting interface "INSTEON Commands 2.0.10" (pid 3628)
Connected to PowerLinc 2413U interface on port usbserial-A6033606
PowerLinc address 34.7A.C9, firmware version 9.14
PowerLinc Linking - batch syncing all links for "Floods. Upper Deck"
PowerLinc Linking - batch syncing all links for "GTRM. Piano Track"
PowerLinc Linking - batch syncing all links for "GTRM. Sofa Track"
PowerLinc Linking - batch syncing all links for "GTRM E MS. 10"
PowerLinc Linking - batch syncing all links for "Kitchen. Table"
PowerLinc Linking - batch syncing all links for "Master Bath. Chandelier"
PowerLinc Linking - batch syncing all links for "Back Hall (rear switch)"
PowerLinc Linking - batch syncing all links for "Floods. Front North Corner"
PowerLinc Linking - batch syncing all links for "Carport. Lights"
PowerLinc Linking - batch syncing all links for "Foyer. Lights"
PowerLinc Linking - batch syncing all links for "Front Yard. Porch & Uplights"
PowerLinc Linking - batch syncing all links for "LL #5"
PowerLinc Linking - batch syncing all links for "Christmas. Loft"
PowerLinc Linking - batch syncing all links for "Parking Apron MS.1"
PowerLinc Linking - batch syncing all links for "Carport S Wall MS. 4"
PowerLinc Linking - batch syncing all links for "Thermostat"
PowerLinc Linking - batch syncing all links for "Foyer MS. 7 (facing guest room)"
PowerLinc Linking - batch syncing all links for "Apartment, Kitchen"
PowerLinc Linking - batch syncing all links for "Apartment. Storage Room Ceiling"
PowerLinc Linking - batch syncing all links for "Floods. North Gable"
PowerLinc Linking - batch syncing all links for "Lauren's Bathroom"
PowerLinc Linking - batch syncing all links for "Humidifier"
PowerLinc Linking - batch syncing all links for "Foyer MS. 11(facing back hall)"
PowerLinc Linking - batch syncing all links for "MS. 12 Playroom"
PowerLinc Linking - batch syncing all links for "GTRM. Mantle Track"
PowerLinc Linking - batch syncing all links for "Garage Door Opener"
PowerLinc Linking - batch syncing all links for "Back Hall (front switch)"
PowerLinc Linking - batch syncing all links for "Studio. Kitchen Track"
PowerLinc Linking - batch syncing all links for "Studio. Sconces"
PowerLinc Linking - batch syncing all links for "LL #2 Carport"
PowerLinc Linking - batch syncing all links for "Master Bath. Vanity"
PowerLinc Linking - batch syncing all links for "Floods. Pool South"
PowerLinc Linking - batch syncing all links for "Floods. Pool North"
PowerLinc Linking - batch syncing all links for "Apt Parking MS (Garage O'head Door)"
PowerLinc Linking - batch syncing all links for "Floods. Apt SouthWest Corner"
PowerLinc Linking - batch syncing all links for "Floods. Apt front"
PowerLinc Linking - batch syncing all links for "Carport W Wall MS. 6"
PowerLinc Linking - batch syncing all links for "GTRM N MS. 13"
PowerLinc Linking - batch syncing all links for "Leak Sensor #1"
PowerLinc Linking - batch syncing all links for "Carport Hidden Door Sensor"
PowerLinc Linking - batch syncing all links for "Kitchen. Track"
PowerLinc Linking - batch syncing all links for "Loft (LL)"
PowerLinc Linking - batch syncing all links for "LL On/Off "
PowerLinc Linking - batch syncing all links for "Christmas.Village (LL#4)"
PowerLinc Linking - batch syncing all links for "Christmas. Tree"
PowerLinc Linking - batch syncing all links for "Garage LampLinc (LL#3)"
PowerLinc Linking - batch syncing all links for "Pond Outlet (2, top) "
PowerLinc Linking - batch syncing all links for "Pond Outlet (1, PUMP)"
PowerLinc Linking - batch syncing all links for "Irrigation Controller"
PowerLinc Linking - batch sync started
PowerLinc Linking - syncing PowerLinc links (address 34.7A.C9)
PowerLinc Linking - comparing local and powerlinc links
PowerLinc Linking - . . . read: INSTEON plc link to controller 1B.1B.3F, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 1A.B3.98, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to responder 1A.00.80, flags 02, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 27.70.DD, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 17.8D.75, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 19.55.BA, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 1D.C9.BA, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 1E.E9.4C, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 17.EC.C2, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 27.C9.71, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to controller 27.CC.6A, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to controller 17.EB.D2, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 1E.EB.F4, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 17.ED.62, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 18.93.CA, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 26.F4.D2, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 14.6F.4C, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 14.76.2D, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 14.72.77, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 28.9B.BD, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 14.76.43, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 1D.DF.B1, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 1D.D9.98, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to controller 22.85.56, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 21.91.C8, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 27.CB.F7, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 17.EC.C5, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 24.A2.F4, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to controller 28.C2.7A, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 27.B8.49, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 18.32.1B, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 1B.32.1B, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to controller 26.F4.2C, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 33.10.2E, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to controller 24.2C.7A, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to controller 24.E8.8E, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to controller 22.41.C1, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to controller 21.10.15, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 21.8E.83, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to responder 1E.EB.F4, flags 02, group FE, data 01 1F 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 33.10.2E, flags 02, group FE, data 01 41 43
PowerLinc Linking - . . . read: INSTEON plc link to controller 24.E8.8E, flags 03, group 00, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to responder 24.E8.8E, flags 02, group FE, data 01 20 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 1E.E9.4C, flags 02, group FE, data 01 1F 41
PowerLinc Linking - . . . read: INSTEON plc link to controller 24.A2.F4, flags 03, group 00, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to responder 24.A2.F4, flags 02, group FE, data 01 20 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 21.8E.83, flags 02, group FE, data 01 0E 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 1D.C9.BA, flags 02, group FE, data 01 20 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 24.E8.9F, flags 02, group FE, data 01 20 41
PowerLinc Linking - . . . read: INSTEON plc link to controller 24.E8.9F, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to responder 22.41.C1, flags 02, group FE, data 01 2D 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 21.10.15, flags 02, group FE, data 02 2A 42
PowerLinc Linking - . . . read: INSTEON plc link to controller 1D.D9.98, flags 03, group 00, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to responder 1D.D9.98, flags 02, group FE, data 01 20 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 1D.DF.B1, flags 02, group FE, data 01 20 41
PowerLinc Linking - . . . read: INSTEON plc link to controller 14.73.56, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to responder 1D.DA.87, flags 02, group FE, data 01 20 41
PowerLinc Linking - . . . read: INSTEON plc link to controller 1D.DA.87, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to responder 25.8A.58, flags 02, group FE, data 01 1F 41
PowerLinc Linking - . . . read: INSTEON plc link to controller 25.8A.58, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to controller 27.B3.10, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 27.B3.1D, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to responder 14.72.77, flags 02, group FE, data 10 01 34
PowerLinc Linking - . . . read: INSTEON plc link to responder 28.5A.79, flags 02, group FE, data 10 01 41
PowerLinc Linking - . . . read: INSTEON plc link to controller 28.5A.79, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to responder 32.12.88, flags 02, group FE, data 10 08 43
PowerLinc Linking - . . . read: INSTEON plc link to controller 32.12.88, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 1A.B7.80, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 2A.FF.A6, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to responder 26.F4.D2, flags 02, group FE, data 01 0E 41
PowerLinc Linking - . . . read: INSTEON plc link to controller 27.CC.6A, flags 03, group 00, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to responder 27.CC.6A, flags 02, group FE, data 02 37 46
PowerLinc Linking - . . . read: INSTEON plc link to controller 21.92.B5, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to responder 21.92.B5, flags 02, group FE, data 01 0E 41
PowerLinc Linking - . . . read: INSTEON plc link to controller 27.C9.71, flags 03, group 00, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to responder 27.C9.71, flags 02, group FE, data 02 37 46
PowerLinc Linking - . . . read: INSTEON plc link to responder 24.2C.7A, flags 02, group FE, data 07 00 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 21.91.C8, flags 02, group FE, data 01 0E 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 41.8A.BE, flags 02, group FE, data 02 39 44
PowerLinc Linking - . . . read: INSTEON plc link to controller 41.8A.BE, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 41.8A.BE, flags 03, group 02, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to responder 28.C2.7A, flags 02, group FE, data 07 00 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 38.7C.0F, flags 02, group FE, data 04 00 28
PowerLinc Linking - . . . read: INSTEON plc link to controller 38.7C.0F, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to controller 3E.91.30, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . read: INSTEON plc link to responder 3E.91.30, flags 02, group FE, data 01 0E 43
PowerLinc Linking - . . . read: INSTEON plc link to responder 3E.9D.83, flags 02, group FE, data 01 0E 43
PowerLinc Linking - . . . read: INSTEON plc link to controller 3E.9D.83, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to responder 3E.94.EE, flags 02, group FE, data 01 0E 43
PowerLinc Linking - . . . read: INSTEON plc link to controller 3E.94.EE, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to responder 3E.B9.1B, flags 02, group FE, data 01 0E 43
PowerLinc Linking - . . . read: INSTEON plc link to controller 3E.B9.1B, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to responder 3E.92.6E, flags 02, group FE, data 01 0E 43
PowerLinc Linking - . . . read: INSTEON plc link to controller 3E.92.6E, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . . read: INSTEON plc link to responder 34.55.C9, flags 02, group FE, data 05 0B 10
PowerLinc Linking - . . . read: INSTEON plc link to responder 22.85.56, flags 02, group FE, data 02 1A 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 26.F4.2C, flags 02, group FE, data 01 0E 41
PowerLinc Linking - . . . read: INSTEON plc link to responder 28.9B.BD, flags 02, group FE, data 05 0B 0D
PowerLinc Linking - . . . read: INSTEON plc link to controller 34.55.C9, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . match: remote link is identical to persistent link 1B.1B.3F, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 1A.B3.98, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 1A.B7.80, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 27.70.DD, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 17.8D.75, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 19.55.BA, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 1D.C9.BA, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 1E.E9.4C, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 17.EC.C2, flags 03, group 01
PowerLinc Linking - . mismatch: remote link differs from persistent link 27.C9.71, flags 03, group 01 (changing remote link)
PowerLinc Linking - . mismatch: remote link differs from persistent link 27.CC.6A, flags 03, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 17.EB.D2, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 1E.EB.F4, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 17.ED.62, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 18.93.CA, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 26.F4.D2, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 14.6F.4C, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 14.76.2D, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 14.72.77, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 28.9B.BD, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 14.76.43, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 1D.DF.B1, flags 03, group 01
PowerLinc Linking - . mismatch: remote link differs from persistent link 1D.D9.98, flags 03, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 22.85.56, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 21.91.C8, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 27.CB.F7, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 17.EC.C5, flags 03, group 01
PowerLinc Linking - . mismatch: remote link differs from persistent link 24.A2.F4, flags 03, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 28.C2.7A, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 27.B8.49, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 18.32.1B, flags 03, group 01
PowerLinc Linking - . mismatch: remote link differs from persistent link 1B.32.1B, flags 03, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 26.F4.2C, flags 03, group 01
PowerLinc Linking - . mismatch: remote link differs from persistent link 33.10.2E, flags 03, group 01 (changing remote link)
PowerLinc Linking - . mismatch: remote link differs from persistent link 24.2C.7A, flags 03, group 01 (changing remote link)
PowerLinc Linking - . mismatch: remote link differs from persistent link 24.E8.8E, flags 03, group 01 (changing remote link)
PowerLinc Linking - . mismatch: remote link differs from persistent link 22.41.C1, flags 03, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 21.10.15, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 21.8E.83, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 24.E8.9F, flags 03, group 01
PowerLinc Linking - . mismatch: remote link differs from persistent link 14.73.56, flags 03, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 1D.DA.87, flags 03, group 01
PowerLinc Linking - . mismatch: remote link differs from persistent link 25.8A.58, flags 03, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 27.B3.10, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 27.B3.1D, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 28.5A.79, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 32.12.88, flags 03, group 01
PowerLinc Linking - . mismatch: remote link differs from persistent link 2A.FF.A6, flags 03, group 01 (changing remote link)
PowerLinc Linking - . mismatch: remote link differs from persistent link 21.92.B5, flags 03, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 41.8A.BE, flags 03, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 38.7C.0F, flags 03, group 01
PowerLinc Linking - compare complete
PowerLinc Linking - . changing: INSTEON plc link to controller 27.C9.71, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 27.C9.71, flags 03, group 01, data 00 00 FF
Error resending previous command (failure response)
Error ManageAllLinkRecord failed to modify link record
PowerLinc Linking - . changing: INSTEON plc link to controller 27.CC.6A, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 27.CC.6A, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . changing: INSTEON plc link to controller 1D.D9.98, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 1D.D9.98, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . changing: INSTEON plc link to controller 24.A2.F4, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 24.A2.F4, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . changing: INSTEON plc link to controller 1B.32.1B, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 1B.32.1B, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . changing: INSTEON plc link to controller 33.10.2E, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 33.10.2E, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . changing: INSTEON plc link to controller 24.2C.7A, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 24.2C.7A, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . changing: INSTEON plc link to controller 24.E8.8E, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 24.E8.8E, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . changing: INSTEON plc link to controller 22.41.C1, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 22.41.C1, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . changing: INSTEON plc link to controller 14.73.56, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 14.73.56, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . changing: INSTEON plc link to controller 25.8A.58, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 25.8A.58, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . changing: INSTEON plc link to controller 2A.FF.A6, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 2A.FF.A6, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . changing: INSTEON plc link to controller 21.92.B5, flags 03, group 01, data 00 00 00
PowerLinc Linking - . . . . to: INSTEON plc link to controller 21.92.B5, flags 03, group 01, data 00 00 FF
PowerLinc Linking - PowerLinc links updated
PowerLinc Linking - sync complete
PowerLinc Linking
PowerLinc Linking - initializing remote device "Carport Hidden Door Sensor" (address 2A.FF.A6, firmware version 43)
PowerLinc Linking - batch sync skipping unresponsive device
Error Linking - initializing failed; remote device might be asleep
PowerLinc Linking
PowerLinc Linking - initializing remote device "Leak Sensor #1" (address 32.12.88, firmware version 43)
PowerLinc Linking
PowerLinc Linking - initializing remote device "GTRM N MS. 13" (address 28.5A.79, firmware version 41)
PowerLinc Linking
PowerLinc Linking - initializing remote device "Carport W Wall MS. 6" (address 14.72.77, firmware version 34)
PowerLinc Linking
PowerLinc Linking - initializing remote device "Apt Parking MS (Garage O'head Door)" (address 14.73.56, firmware version 34)
May 14, 2017, 12:04:08 AM
PowerLinc Unexpected command 02 9B (flushing)
PowerLinc Linking
PowerLinc Linking - initializing remote device "Foyer MS. 11(facing back hall)" (address 27.B8.49, firmware version 41)
PowerLinc Linking
PowerLinc Linking - initializing remote device "Foyer MS. 7 (facing guest room)" (address 14.76.43, firmware version 34)
PowerLinc Linking
PowerLinc Linking - initializing remote device "Carport S Wall MS. 4" (address 14.76.2D, firmware version 34)
PowerLinc Linking
PowerLinc Linking - initializing remote device "Parking Apron MS.1" (address 14.6F.4C, firmware version 34)
PowerLinc Linking
PowerLinc Linking - initializing remote device "GTRM E MS. 10" (address 27.70.DD, firmware version 41)
PowerLinc Linking
PowerLinc Linking - initializing remote device "Floods. Upper Deck" (address 1B.1B.3F, firmware version 40)
PowerLinc Linking - . . . read: default on brightness 0%, ramp rate duration 0.1 seconds
PowerLinc Linking - initialize complete
PowerLinc Linking - device "Floods. Upper Deck" properties updated
PowerLinc Linking
PowerLinc Linking - syncing remote device "Floods. Upper Deck" (address 1B.1B.3F, firmware version 40)
PowerLinc Linking - syncing all links
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 00, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 2C.09.7B, flags E2, group 01, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 17, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 1B.32.1B, flags A2, group 07, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 18, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 1B.32.1B, flags A2, group 08, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 01, data 03 1F 00
PowerLinc Linking - . . . read: INSTEON dev link (empty record at 0FC0)
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.10.2E, flags E2, group 01, data 03 1F 00
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.10.2E, flags A2, group 07, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.10.2E, flags A2, group 08, data FF 1F 01
PowerLinc Linking - . . found: PowerLinc responder for group 1
PowerLinc Linking - comparing local and remote links
PowerLinc Linking - . . match: remote link is identical to persistent link 33.10.2E, flags E2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 33.10.2E, flags A2, group 07
PowerLinc Linking - . . match: remote link is identical to persistent link 33.10.2E, flags A2, group 08
PowerLinc Linking - device "Floods. Upper Deck" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "GTRM. Piano Track" (address 1A.B3.98, firmware version 40)
PowerLinc Linking - . . . read: default on brightness 100%, ramp rate duration 0.1 seconds
PowerLinc Linking - device "GTRM. Piano Track" properties updated
PowerLinc Linking
PowerLinc Linking - syncing remote device "GTRM. Piano Track" (address 1A.B3.98, firmware version 40)
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 00, data 00 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 13, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 1B.32.1B, flags A2, group 05, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 1C, data 66 1F 01
PowerLinc Linking - . . . read: INSTEON dev link (empty record at 0FC8)
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.10.2E, flags A2, group 05, data FF 1F 01
PowerLinc Linking - . . match: remote link is identical to persistent link 33.10.2E, flags A2, group 05
PowerLinc Linking - device "GTRM. Piano Track" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "GTRM. Sofa Track" (address 1A.B7.80, firmware version 40)
PowerLinc Linking - device "GTRM. Sofa Track" properties updated
PowerLinc Linking
PowerLinc Linking - syncing remote device "GTRM. Sofa Track" (address 1A.B7.80, firmware version 40)
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 00, data FF 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 14, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 1B.32.1B, flags A2, group 03, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 1C, data CC 1F 01
May 14, 2017, 12:07:05 AM
May 14, 2017, 12:07:25 AM
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.10.2E, flags A2, group 03, data FF 1F 01
PowerLinc Linking - . . match: remote link is identical to persistent link 33.10.2E, flags A2, group 03
PowerLinc Linking - device "GTRM. Sofa Track" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Kitchen. Table" (address 19.55.BA, firmware version 40)
PowerLinc Linking - . . . read: default on brightness 0%, ramp rate duration 9.0 minutes
PowerLinc Linking - device "Kitchen. Table" properties updated
PowerLinc Linking
PowerLinc Linking - syncing remote device "Kitchen. Table" (address 19.55.BA, firmware version 40)
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 15, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 1B.32.1B, flags A2, group 04, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 1A, data 4C 1B 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 1B, data 4C 1A 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.10.2E, flags A2, group 04, data CF 1F 01
PowerLinc Linking - . . match: remote link is identical to persistent link 33.10.2E, flags A2, group 04
PowerLinc Linking - device "Kitchen. Table" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Master Bath. Chandelier" (address 1D.C9.BA, firmware version 41)
PowerLinc Linking - . . . read: default on brightness 100%, ramp rate duration 0.5 seconds
PowerLinc Linking - device "Master Bath. Chandelier" properties updated
PowerLinc Linking
PowerLinc Linking - syncing remote device "Master Bath. Chandelier" (address 1D.C9.BA, firmware version 41)
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags AA, group FE, data 00 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags EA, group 01, data 03 1C 01
PowerLinc Linking - device "Master Bath. Chandelier" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Back Hall (rear switch)" (address 1E.E9.4C, firmware version 41)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Back Hall (rear switch)" (address 1E.E9.4C, firmware version 41)
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags A2, group FE, data FF 1C 00
PowerLinc Linking - . . . read: INSTEON dev link to controller 24.E8.8E, flags A2, group 01, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.E8.8E, flags E2, group 01, data 03 1F 00
PowerLinc Linking - . . match: remote link is identical to persistent link 24.E8.8E, flags A2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 24.E8.8E, flags E2, group 01
PowerLinc Linking - device "Back Hall (rear switch)" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Floods. Front North Corner" (address 17.EB.D2, firmware version 3A)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Floods. Front North Corner" (address 17.EB.D2, firmware version 3A)
PowerLinc Linking - . . . read: INSTEON dev link (empty record at 0FE0)
PowerLinc Linking - device "Floods. Front North Corner" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Carport. Lights" (address 17.EC.C2, firmware version 3A)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Carport. Lights" (address 17.EC.C2, firmware version 3A)
PowerLinc Linking - device "Carport. Lights" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Foyer. Lights" (address 1E.EB.F4, firmware version 41)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Foyer. Lights" (address 1E.EB.F4, firmware version 41)
PowerLinc Linking - device "Foyer. Lights" properties updated
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 00, data 00 1F 01
Received INSTEON "GTRM N MS. 13" on (button 1)
Trigger Great Room Motion Tripped (N Wall)
Trigger GreatRoomMotion TURN ON
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags A2, group FE, data FE 1F 00
Trigger GreatRoomMotion ALREADY ON
PowerLinc Linking - device "Foyer. Lights" links updated
Sent INSTEON "GTRM. Piano Track" on to 25
Sent INSTEON "GTRM. Mantle Track" on to 25
PowerLinc Linking
PowerLinc Linking - initializing remote device "Front Yard. Porch & Uplights" (address 17.ED.62, firmware version 3A)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Front Yard. Porch & Uplights" (address 17.ED.62, firmware version 3A)
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 16, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 1B.32.1B, flags A2, group 06, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.10.2E, flags A2, group 06, data FF 1F 01
PowerLinc Linking - . . match: remote link is identical to persistent link 33.10.2E, flags A2, group 06
PowerLinc Linking - device "Front Yard. Porch & Uplights" links updated
Received INSTEON "Master Bath. Vanity" on
PowerLinc Linking
PowerLinc Linking - initializing remote device "LL #5" (address 18.93.CA, firmware version 3B)
PowerLinc Linking - device "LL #5" properties updated
PowerLinc Linking
PowerLinc Linking - syncing remote device "LL #5" (address 18.93.CA, firmware version 3B)
PowerLinc Linking - device "LL #5" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Christmas. Loft" (address 26.F4.D2, firmware version 41)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Christmas. Loft" (address 26.F4.D2, firmware version 41)
PowerLinc Linking - device "Christmas. Loft" properties updated
PowerLinc Linking - device "Loft (LL)" properties updated
PowerLinc Linking - . . . read: INSTEON dev link (empty record at 0FF0)
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags A2, group FE, data 00 1C 00
PowerLinc Linking - device "Christmas. Loft" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Thermostat" (address 28.9B.BD, firmware version 0D)
PowerLinc Linking - . reading: settings and date/time
PowerLinc Linking - . updating: date/time to 12:09 AM
PowerLinc Linking
PowerLinc Linking - syncing remote device "Thermostat" (address 28.9B.BD, firmware version 0D)
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags AA, group 00, data 46 4E 41
PowerLinc Linking - . . . read: INSTEON dev link to responder 2C.09.7B, flags EA, group 01, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags EA, group 01, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags EA, group 02, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags EA, group 03, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 04, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group EF, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags A2, group FE, data 3C 4F 43
PowerLinc Linking - . . found: PowerLinc responder for group 2
PowerLinc Linking - . . found: PowerLinc responder for group 3
PowerLinc Linking - . . found: PowerLinc responder for group 4
PowerLinc Linking - . . found: PowerLinc responder for group 239
PowerLinc Linking - . enabling: status change broadcasting
Schedule Great Room Motion Tripped (N Wall) (delayed action)
Updated "GTRM N MS. 13" off
PowerLinc Linking - device "Thermostat" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Apartment, Kitchen" (address 22.85.56, firmware version 41)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Apartment, Kitchen" (address 22.85.56, firmware version 41)
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags A2, group FE, data 00 00 00
PowerLinc Linking - device "Apartment, Kitchen" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Apartment. Storage Room Ceiling" (address 27.CB.F7, firmware version 46)
Received INSTEON "GTRM N MS. 13" off (button 1)
Sat May 13, 2017 11:39 pm
alpitmaster offline
Event log for re-sync (SECOND HALF)
May 14, 2017, 12:10:34 AM
PowerLinc Linking
PowerLinc Linking - initializing remote device "Floods. North Gable" (address 17.EC.C5, firmware version 3A)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Floods. North Gable" (address 17.EC.C5, firmware version 3A)
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags A2, group 11, data FF 1F 01
PowerLinc Linking - device "Floods. North Gable" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Lauren's Bathroom" (address 24.A2.F4, firmware version 41)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Lauren's Bathroom" (address 24.A2.F4, firmware version 41)
PowerLinc Linking - device "Lauren's Bathroom" properties updated
PowerLinc Linking - . . . read: INSTEON dev link to responder 23.E1.4A, flags EA, group 01, data 03 1C 01
PowerLinc Linking - . . . read: INSTEON dev link (empty record at 0FE8)
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags EA, group 00, data 03 1C 00
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags AA, group FE, data FF 1C 01
PowerLinc Linking - device "Lauren's Bathroom" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Humidifier" (address 28.C2.7A, firmware version 41)
PowerLinc Linking - . reading: configuration settings
PowerLinc Linking - . . . read: configuration settings 02
PowerLinc Linking - device "Humidifier" properties updated
PowerLinc Linking
PowerLinc Linking - syncing remote device "Humidifier" (address 28.C2.7A, firmware version 41)
May 14, 2017, 12:11:50 AM
PowerLinc Linking - device "Humidifier" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "MS. 12 Playroom" (address 26.F4.2C, firmware version 41)
PowerLinc Linking
PowerLinc Linking - syncing remote device "MS. 12 Playroom" (address 26.F4.2C, firmware version 41)
PowerLinc Linking - device "MS. 12 Playroom" properties updated
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags A2, group FE, data FE 1C 00
PowerLinc Linking - device "MS. 12 Playroom" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "GTRM. Mantle Track" (address 33.10.2E, firmware version 43)
PowerLinc Linking - . . . read: backlight brightness 10%
PowerLinc Linking
PowerLinc Linking - device "GTRM. Mantle Track" properties updated
PowerLinc Linking - syncing remote device "GTRM. Mantle Track" (address 33.10.2E, firmware version 43)
PowerLinc Linking - . . . read: INSTEON dev link to controller 1E.06.71, flags AA, group 01, data FF 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 02, data 03 1F 02
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 03, data 03 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 04, data 03 1F 04
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 05, data 03 1F 05
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 06, data 03 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 07, data 03 1F 07
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 08, data 03 1F 08
PowerLinc Linking - . . . read: INSTEON dev link to controller 1B.32.1B, flags AA, group 01, data FF 1C 02
PowerLinc Linking - . . . read: INSTEON dev link to responder 1B.32.1B, flags E2, group 02, data 03 1C 02
PowerLinc Linking - . . . read: INSTEON dev link to responder 17.8D.75, flags E2, group 02, data 03 1F 02
PowerLinc Linking - . . . read: INSTEON dev link to controller 17.8D.75, flags A2, group 01, data FF 1F 02
PowerLinc Linking - . . . read: INSTEON dev link to controller 1B.1B.3F, flags A2, group 01, data FF 1F 07
PowerLinc Linking - . . . read: INSTEON dev link to controller 17.ED.62, flags A2, group 01, data FF 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to controller 1A.B3.98, flags A2, group 01, data FF 1F 05
PowerLinc Linking - . . . read: INSTEON dev link to controller 1A.B7.80, flags A2, group 01, data FF 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to controller 19.55.BA, flags A2, group 01, data FF 1F 04
PowerLinc Linking - . . . read: INSTEON dev link to responder 17.ED.62, flags E2, group 08, data 03 1F 08
PowerLinc Linking - . . . read: INSTEON dev link to responder 1A.B7.80, flags E2, group 03, data 03 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to responder 19.55.BA, flags E2, group 04, data 03 1F 04
PowerLinc Linking - . . . read: INSTEON dev link to responder 1A.B3.98, flags E2, group 05, data 03 1F 05
PowerLinc Linking - . . . read: INSTEON dev link to responder 17.ED.62, flags E2, group 06, data 03 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to responder 1B.1B.3F, flags E2, group 07, data 03 1F 07
PowerLinc Linking - . . . read: INSTEON dev link to responder 17.EC.C2, flags E2, group 08, data 03 1F 08
PowerLinc Linking - . . . read: INSTEON dev link to responder 17.EC.C5, flags E2, group 08, data 03 1F 08
PowerLinc Linking - . . . read: INSTEON dev link to responder 1D.DF.B1, flags E2, group 08, data 03 1F 08
PowerLinc Linking - . . . read: INSTEON dev link to responder 1D.D9.98, flags E2, group 08, data 03 1F 08
PowerLinc Linking - . . . read: INSTEON dev link to responder 1B.1B.3F, flags E2, group 08, data 03 1F 08
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 01, data 03 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags AA, group FE, data FE 1C 01
PowerLinc Linking - . . found: PowerLinc responder for group 5
PowerLinc Linking - . . found: PowerLinc responder for group 6
PowerLinc Linking - . . found: PowerLinc responder for group 7
PowerLinc Linking - . . found: PowerLinc responder for group 8
PowerLinc Linking - . . match: remote link is identical to persistent link 17.8D.75, flags E2, group 02
PowerLinc Linking - . . match: remote link is identical to persistent link 17.8D.75, flags A2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 1B.1B.3F, flags A2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 17.ED.62, flags A2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 1A.B3.98, flags A2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 1A.B7.80, flags A2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 19.55.BA, flags A2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 17.ED.62, flags E2, group 08
PowerLinc Linking - . . match: remote link is identical to persistent link 1A.B7.80, flags E2, group 03
PowerLinc Linking - . . match: remote link is identical to persistent link 19.55.BA, flags E2, group 04
PowerLinc Linking - . . match: remote link is identical to persistent link 1A.B3.98, flags E2, group 05
PowerLinc Linking - . . match: remote link is identical to persistent link 17.ED.62, flags E2, group 06
PowerLinc Linking - . . match: remote link is identical to persistent link 1B.1B.3F, flags E2, group 07
PowerLinc Linking - . . match: remote link is identical to persistent link 17.EC.C2, flags E2, group 08
PowerLinc Linking - . . match: remote link is identical to persistent link 17.EC.C5, flags E2, group 08
PowerLinc Linking - . . match: remote link is identical to persistent link 1D.DF.B1, flags E2, group 08
PowerLinc Linking - . . match: remote link is identical to persistent link 1D.D9.98, flags E2, group 08
PowerLinc Linking - . . match: remote link is identical to persistent link 1B.1B.3F, flags E2, group 08
PowerLinc Linking - device "GTRM. Mantle Track" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Garage Door Opener" (address 24.2C.7A, firmware version 41)
PowerLinc Linking - . . . read: configuration settings 0A
PowerLinc Linking - device "Garage Door Opener" properties updated
PowerLinc Linking
PowerLinc Linking - syncing remote device "Garage Door Opener" (address 24.2C.7A, firmware version 41)
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 01, data 03 00 00
PowerLinc Linking - device "Garage Door Opener" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Back Hall (front switch)" (address 24.E8.8E, firmware version 41)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Back Hall (front switch)" (address 24.E8.8E, firmware version 41)
PowerLinc Linking - device "Back Hall (front switch)" properties updated
PowerLinc Linking - . . . read: INSTEON dev link to controller 1E.E9.4C, flags AA, group 01, data FF 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 1E.E9.4C, flags E2, group 01, data 03 1F 00
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags AA, group FE, data 00 1C 00
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags EA, group 01, data 03 1F 00
PowerLinc Linking - . . . read: INSTEON dev link to responder 1E.E9.4C, flags EA, group 01, data 03 1F 00
PowerLinc Linking - . . . read: INSTEON dev link to controller 1E.E9.4C, flags A2, group 01, data FF 1F 01
PowerLinc Linking - . . match: remote link is identical to persistent link 1E.E9.4C, flags E2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 1E.E9.4C, flags A2, group 01
PowerLinc Linking - device "Back Hall (front switch)" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Studio. Kitchen Track" (address 22.41.C1, firmware version 41)
PowerLinc Linking
PowerLinc Linking - device "Studio. Kitchen Track" properties updated
PowerLinc Linking - syncing remote device "Studio. Kitchen Track" (address 22.41.C1, firmware version 41)
PowerLinc Linking - . . . read: INSTEON dev link (empty record at 0FF8)
PowerLinc Linking - device "Studio. Kitchen Track" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Studio. Sconces" (address 21.10.15, firmware version 42)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Studio. Sconces" (address 21.10.15, firmware version 42)
PowerLinc Linking - . . . read: INSTEON dev link to responder 22.18.11, flags EA, group 01, data 03 1C 01
Trigger GreatRoomMotion TURN OFF
PowerLinc Linking - . . . read: INSTEON dev link to responder 22.41.C1, flags EA, group 01, data 03 1C 01
PowerLinc Linking - device "Studio. Sconces" links updated
Sent INSTEON "GTRM. Piano Track" off
Sent INSTEON "GTRM. Mantle Track" off
PowerLinc Linking
PowerLinc Linking - initializing remote device "LL #2 Carport" (address 21.8E.83, firmware version 41)
PowerLinc Linking
PowerLinc Linking - device "LL #2 Carport" properties updated
PowerLinc Linking - syncing remote device "LL #2 Carport" (address 21.8E.83, firmware version 41)
PowerLinc Linking - . . . read: INSTEON dev link to controller 21.33.3D, flags A2, group 00, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 21.33.3D, flags E2, group 01, data FF 1F 01
PowerLinc Linking - device "LL #2 Carport" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Master Bath. Vanity" (address 24.E8.9F, firmware version 41)
PowerLinc Linking
PowerLinc Linking - device "Master Bath. Vanity" properties updated
PowerLinc Linking - syncing remote device "Master Bath. Vanity" (address 24.E8.9F, firmware version 41)
PowerLinc Linking - device "Master Bath. Vanity" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Floods. Pool South" (address 1D.D9.98, firmware version 41)
PowerLinc Linking
PowerLinc Linking - device "Floods. Pool South" properties updated
PowerLinc Linking - syncing remote device "Floods. Pool South" (address 1D.D9.98, firmware version 41)
PowerLinc Linking - . . . read: INSTEON dev link (empty record at 0FD8)
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags EA, group 00, data 03 1F 00
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags AA, group FE, data FF 1F 01
PowerLinc Linking - device "Floods. Pool South" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Floods. Pool North" (address 1D.DF.B1, firmware version 41)
PowerLinc Linking
PowerLinc Linking - device "Floods. Pool North" properties updated
PowerLinc Linking - syncing remote device "Floods. Pool North" (address 1D.DF.B1, firmware version 41)
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags AA, group 00, data 00 1F 01
PowerLinc Linking - device "Floods. Pool North" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Floods. Apt SouthWest Corner" (address 1D.DA.87, firmware version 41)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Floods. Apt SouthWest Corner" (address 1D.DA.87, firmware version 41)
Error resending previous command (reply mismatch)
PowerLinc Linking - . . . read: INSTEON dev link to controller 18.54.79, flags A2, group 08, data FF 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 2C.09.7B, flags AA, group 00, data 00 1C 01
PowerLinc Linking - device "Floods. Apt SouthWest Corner" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Floods. Apt front" (address 25.8A.58, firmware version 41)
PowerLinc Linking
PowerLinc Linking - device "Floods. Apt front" properties updated
PowerLinc Linking - syncing remote device "Floods. Apt front" (address 25.8A.58, firmware version 41)
PowerLinc Linking - device "Floods. Apt front" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Kitchen. Track" (address 1B.32.1B, firmware version 40)
PowerLinc Linking - . . . read: default on brightness 0%, ramp rate duration 0.5 seconds
PowerLinc Linking - device "Kitchen. Track" properties updated
PowerLinc Linking
PowerLinc Linking - syncing remote device "Kitchen. Track" (address 1B.32.1B, firmware version 40)
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.10.2E, flags E2, group 01, data 05 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.10.2E, flags A2, group 02, data CF 1C 01
PowerLinc Linking - device "Kitchen. Track" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Loft (LL)" (address 26.F4.D2, firmware version 41)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Loft (LL)" (address 26.F4.D2, firmware version 41)
PowerLinc Linking
PowerLinc Linking - initializing remote device "LL On/Off " (address 27.CC.6A, firmware version 46)
May 14, 2017, 12:16:55 AM
PowerLinc Linking
PowerLinc Linking - initializing remote device "Christmas.Village (LL#4)" (address 21.92.B5, firmware version 41)
PowerLinc Linking
PowerLinc Linking - device "Christmas.Village (LL#4)" properties updated
PowerLinc Linking - syncing remote device "Christmas.Village (LL#4)" (address 21.92.B5, firmware version 41)
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 01, data 00 1C 00
PowerLinc Linking - device "Christmas.Village (LL#4)" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Christmas. Tree" (address 27.C9.71, firmware version 46)
May 14, 2017, 12:17:30 AM
PowerLinc Linking
PowerLinc Linking - initializing remote device "Garage LampLinc (LL#3)" (address 21.91.C8, firmware version 41)
PowerLinc Linking
PowerLinc Linking - device "Garage LampLinc (LL#3)" properties updated
PowerLinc Linking - syncing remote device "Garage LampLinc (LL#3)" (address 21.91.C8, firmware version 41)
PowerLinc Linking - device "Garage LampLinc (LL#3)" links updated
PowerLinc Linking
PowerLinc Linking - initializing remote device "Pond Outlet (2, top) " (address 41.8A.BE, firmware version 44)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Pond Outlet (2, top) " (address 41.8A.BE, firmware version 44)
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags EA, group 02, data 03 1C 02
PowerLinc Linking - . . . read: INSTEON dev link to controller 1D.94.F0, flags AA, group 01, data FF 1C 02
PowerLinc Linking - . . . read: INSTEON dev link to controller 1F.62.E9, flags AA, group 01, data 00 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.0F.F2, flags AA, group 01, data FF 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.0F.F0, flags AA, group 01, data FF 1C 02
PowerLinc Linking - . . . read: INSTEON dev link to controller 17.6E.C7, flags AA, group 01, data FF 1C 01
Received INSTEON "Master Bath. Vanity" off
Received X10 "Storage Room Appliance Module" off
PowerLinc Linking - . . . read: INSTEON dev link to controller 34.7A.C9, flags AA, group FE, data FF 1C 02
PowerLinc Linking - . . . read: INSTEON dev link to responder 34.7A.C9, flags E2, group 02, data 03 1F 00
PowerLinc Linking - device "Pond Outlet (2, top) " links updated
PowerLinc Unexpected command 02 10 (flushing)
PowerLinc Linking
PowerLinc Linking - initializing remote device "Pond Outlet (1, PUMP)" (address 41.8A.BE, firmware version 44)
PowerLinc Linking
PowerLinc Linking - syncing remote device "Pond Outlet (1, PUMP)" (address 41.8A.BE, firmware version 44)
PowerLinc Linking - syncing of this device not possible remotely (skipping)
PowerLinc Linking
PowerLinc Linking - initializing remote device "Irrigation Controller" (address 38.7C.0F, firmware version 28)
PowerLinc Linking - . enabling: valve status change broadcasting
PowerLinc Linking - . reading: pump control status and zone maximum durations
PowerLinc Linking - . forcing: internal valve selection
PowerLinc Linking - . . . read: pump control is disabled for valve 8
PowerLinc Linking - . . . read: zone maximum durations 40, 20, 40, 40, 40, 40, 40, 40 (i2cs)
PowerLinc Linking - . . . read: zone enabled flags FF
PowerLinc Linking - device "Irrigation Controller" properties updated
PowerLinc Linking
PowerLinc Linking - syncing remote device "Irrigation Controller" (address 38.7C.0F, firmware version 28)
PowerLinc Linking - batch sync complete
Sun May 14, 2017 9:34 pm
It looks like there are multiple things going wrong. I wonder if your are having file/folder permission problems or hard drive malfunctioning issues.
The fact that none of your changes are saved across Indigo Server restarts likely means that Indigo isn't able to save the files (either the database file or the preference file, possibly both).
Do you have more than one macOS user account on this Mac?
Open the Terminal application, and copy/paste in the following:
id
cd /Library/Application\ Support/
ls -al
cd Perceptive\ Automation/
ls -al
cd Indigo\ 7
ls -al
cd Databases
ls -al
cd ../Preferences
ls -al
Then copy/paste the Terminal window results into a reply for me.
Mon May 15, 2017 8:09 am
alpitmaster offline
mac-server:~ george$ export PS1="\[\033[36m\]\u\[\033[m\]@\[\033[32m\]\h:\[\033[33;1m\]\w\[\033[m\]\$ "
george@mac-server:~$ id
uid=501(george) gid=20(staff) groups=20(staff),703(com.apple.sharepoint.group.8),258(com.apple.access_backup),253(com.apple.access_addressbook),704(com.apple.sharepoint.group.9),404(com.apple.sharepoint.group.4),501(ssllc),702(com.apple.sharepoint.group.7),255(com.apple.access_calendar),252(com.apple.access_ftp),401(com.apple.sharepoint.group.1),12(everyone),61(localaccounts),79(_appserverusr),80(admin),81(_appserveradm),98(_lpadmin),398(com.apple.access_screensharing-disabled),250(com.apple.access_afp),403(com.apple.sharepoint.group.3),701(com.apple.sharepoint.group.6),256(com.apple.access_mail),405(com.apple.sharepoint.group.5),251(com.apple.access_smb),254(com.apple.access_chat),257(com.apple.access_vpn),500(com.apple.local.ard_admin),502(com.apple.local.ard_reports),33(_appstore),100(_lpoperator),204(_developer),399(com.apple.access_ssh),402(com.apple.sharepoint.group.2),503(com.apple.local.ard_interact),504(com.apple.local.ard_manage)
george@mac-server:~$ cd /Library/Application\ Support/
george@mac-server:/Library/Application Support$ ls -al
total 0
drwxr-xr-x 16 root admin 544 Jan 13 2015 .
drwxr-xr-x+ 63 root wheel 2142 Apr 21 2016 ..
drwxr-xr-x 3 root wheel 102 Dec 28 2015 Adobe
drwxr-xr-x 3 root admin 102 Nov 18 2014 App Store
drwxr-xr-x 11 root wheel 374 May 19 2015 Apple
drwx------ 5 root admin 170 Nov 18 2014 ApplePushService
drwxrwxr-x 23 root admin 782 Apr 20 23:05 CrashReporter
drwxrwxr-x 10 root admin 340 Nov 18 2014 Logic
drwxr-xr-x 5 root admin 170 Apr 21 2016 Macromedia
drwxrwxr-x 5 root admin 170 Dec 27 21:43 Perceptive Automation
drwxrwxr-t 3 root admin 102 Nov 6 2014 ProApps
drwxr-xr-x 3 root wheel 102 Sep 11 2014 Script Editor
drwxr-xr-x 4 root wheel 136 Jan 7 2015 VMware
drwx------ 3 root admin 102 Nov 18 2014 com.apple.TCC
drwxrwxrwx 4 root admin 136 Nov 18 2014 handyPrintPro
drwxr-xr-x 3 root wheel 102 Sep 27 2014 iLifeMediaBrowser
george@mac-server:/Library/Application Support$ cd Perceptive\ Automation/
george@mac-server:/Library/Application Support/Perceptive Automation$ ls -al
total 16
drwxrwxr-x 5 root admin 170 Dec 27 21:43 .
drwxr-xr-x 16 root admin 544 Jan 13 2015 ..
-rw-r--r--@ 1 george admin 6148 Dec 27 21:43 .DS_Store
drwxrwxr-x 13 george admin 442 Oct 22 2016 Indigo 6
drwxrwxr-x 12 george admin 408 May 13 23:19 Indigo 7
george@mac-server:/Library/Application Support/Perceptive Automation$ cd Indigo\ 7
george@mac-server:/Library/Application Support/Perceptive Automation/Indigo 7$ ls -al
total 24
drwxrwxr-x 12 george admin 408 May 13 23:19 .
drwxrwxr-x 5 root admin 170 Dec 27 21:43 ..
-rw-r--r--@ 1 george admin 8196 May 13 22:07 .DS_Store
drwxrwxr-x 14 george admin 476 May 15 08:19 Databases
drwxrwxr-x 3 george admin 102 May 12 11:51 IndigoPluginHost.app
drwxrwxr-x 3 george admin 102 May 12 11:51 IndigoServer.app
drwxrwxr-x 29 george admin 986 May 12 11:48 IndigoWebServer
drwxrwxr-x 39 george admin 1326 May 15 00:00 Logs
drwxrwxr-x 6 george admin 204 May 14 00:01 Plugins
drwxrwxr-x 16 george admin 544 May 14 00:01 Plugins (Disabled)
drwxrwxr-x 7 george admin 238 May 15 08:19 Preferences
drwxrwxr-x 7 george admin 238 May 12 11:48 Scripts
george@mac-server:/Library/Application Support/Perceptive Automation/Indigo 7$ cd Databases
george@mac-server:/Library/Application Support/Perceptive Automation/Indigo 7/Databases$ ls -al
total 24
drwxrwxr-x 14 george admin 476 May 15 08:19 .
drwxrwxr-x 12 george admin 408 May 13 23:19 ..
-rw-rw-r-- 1 george admin 0 Apr 9 20:40 Sample House.indiDb
-rw-rw-r-- 1 george admin 0 Apr 18 06:10 WMSLights 1.indiDb
-rw-rw-r-- 1 george admin 0 May 15 08:19 WMSLights 10.indiDb
-rw-rw-r-- 1 george admin 3086 May 11 21:38 WMSLights 2.indiDb
-rw-rw-r-- 1 george admin 0 May 12 11:29 WMSLights 3.indiDb
-rw-rw-r-- 1 george admin 0 May 12 16:24 WMSLights 4.indiDb
-rw-rw-r-- 1 george admin 0 May 13 12:55 WMSLights 5.indiDb
-rw-rw-r-- 1 george admin 3086 May 13 17:38 WMSLights 6.indiDb
-rw-rw-r-- 1 george admin 0 May 13 21:52 WMSLights 7.indiDb
-rw-rw-r-- 1 george admin 0 May 13 22:09 WMSLights 8.indiDb
-rw-rw-r-- 1 george admin 3086 May 13 23:19 WMSLights 9.indiDb
-rw-rw-r-- 1 george admin 0 Apr 9 20:23 WMSLights.indiDb
george@mac-server:/Library/Application Support/Perceptive Automation/Indigo 7/Databases$ cd ../Preferences
george@mac-server:/Library/Application Support/Perceptive Automation/Indigo 7/Preferences$ ls -al
Mon May 15, 2017 9:40 am
Re: Restarting Indigo, my interface disappears (PART 1)
That all looks good, but the last command to the Terminal didn't execute (maybe you didn't press Enter after pasting in the commands). So copy/paste this in:
cd /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Preferences
ls -al
followed by the Enter key and let me see the results.
Mon May 15, 2017 10:29 am
alpitmaster offline
total 8
drwxrwxr-x 7 george admin 238 May 15 08:19 .
-rw-rw-r-- 1 george admin 1166 Nov 29 16:34 Indigo Registration.indiPref
-rw-rw-r-- 1 george admin 0 May 15 08:19 Indigo Server Prefs.indiPref
-rw-rw-r-- 1 george admin 0 May 13 23:19 Indigo Server Settings.indiPref
drwxrwxr-x 9 george admin 306 May 13 23:20 Plugins
drwxrwx--- 8 george admin 272 Nov 29 16:31 PrismReflector
Wed May 17, 2017 8:35 pm
Your settings files are empty for some reason. The permissions on them look okay, so I'm not sure what is wrong. Can you right-click on both of these folders and choose the "compress" menu item then send me the 2 resulting .zip files?
/Library/Application Support/Perceptive Automation/Indigo 7/Preferences/
/Library/Application Support/Perceptive Automation/Indigo 7/Databases/
Email them to support AT indigodomo.com. I'll try to reproduce the problem here with your files to see if I can track down what is occurring.
