I received my new USB Stick due the the failure of my 2nd 2413U (viewtopic.php?f=75&t=18009) and got it set up!
Some things I noticed that I would love some feedback on:
1. It took a long time to "sync" all the links. I know Matt that you said it would be slower, so I expected that.
2. Command reliability.
I use mostly Insteon Scenes inside Actions Groups triggered by either a wall-button or a software app like the control panel in Indigo Touch... I noticed consistently that many of my devices would not change (like turn off, dim..ect) like they should. I did a quick check up on all my access points. I have 5 total access points. 2 "newer" ones and 3 older ones. 2 upstairs, 3 downstairs. I noticed that one of the older one's green light does not even blink and is extremely dim. Perhaps is it bad? Also, I see that you no longer can buy an Access Point?
I turned on "Group Cleanup" and this seemed to solve the reliability follow-through when the clean up happens, but that is slow of course.
So,
Would you recommend still using Insteon Scenes? or perhaps switch to a Virtual Group or adding the devices manually to my action groups.?
Also, is "Group Cleanup" my best option for reliability here?
Or! any other suggestions? Are these findings congruent with other users?
Thanks for all the help,
- Matt T
