updated to 7.0.3 and interfaces and plugins are all broken
Sat Feb 11, 2017 8:32 am
henkjanvries offline
Yesterday I upgraded, from 7.0.x to 7.0.3 and nothing works anymore. Starting the server takes forever. and when I finally get into the home screen, it says all interfaces are disabled, which I can't enable. All plugins are started but get disabled directly.
Luckily I still have my 6.x.x version running, but I'd like to get this fixed.
what can I do to get help? I've attached the logs from startup till it finally gives a window.
hope someone can help out.
indigodomo 7.0.3 startuplog.txt
(21.23 KiB) Downloaded 92 times
Sat Feb 11, 2017 9:50 am
Re: updated to 7.0.3 and interfaces and plugins are all brok
Those are all file/folder permission problems. Re-run the Indigo 7.0.3 installer then restart your Mac. If that doesn't help then there is probably a folder owner problem caused by another installer which will need to be fixed. Lately we had lots of users end up with their main user folder being owned by root. This can happen when a poorly written installer (not Indigo) is run.
