[SOLVED]finding a control page item that is missing/gives er
Sat Jan 14, 2017 12:14 pm
Seeker offline
I've been doing some work on my indigo mini and started seeing these errors:
WebServer no image URL found for page control 135
WebServer no image URL found for page control 181
WebServer no image URL found for page control 164
is there an easy way to determine which items (likely images)?
Sat Jan 14, 2017 1:41 pm
Re: finding a control page item that is missing/gives error
First, you need to determine which Control Page it is with the empty URLs. You can open your different Control Pages with Indigo Touch (or browser) and watch the Event Log for when the problem starts to occur. After that, you can open that Control Page in the editor then enable the Edit Z-Order checkbox. That will turn on feedback showing the control number next to every control, so you can try to find the ones that are labelled 135, 181, 164, etc. I believe they will be refreshing image control types that have an empty URL (the URL is required for those types).
Sat Jan 14, 2017 2:37 pm
Seeker offline
Thanks, got it fixed.
