Fibaro Dimmer Bypass 1
Sat Dec 31, 2016 7:17 am
petematheson offline
I have a dimmer 1 module that I've swapped in some LED bulbs. Now, unless I leave one halogen bulb in, the lights won't switch off and they flicker.
So I need a bypass module, but from what i can see the Module 2 only works with the dimmer 2. But the module 1 isn't available anymore?
Sat Dec 31, 2016 3:18 pm
Re: Fibaro Dimmer Bypass 1
Can you elaborate with more details. And what particular Fibaro module do you have?
Sat Dec 31, 2016 3:38 pm
Sorry Matt,
I have the fibaro dimmer module version 1, and I currently have it controlling some halogen gu10 bulbs.
I need to replace the blown bulbs so need a fibaro bypass module (I believe) so that the dimmer module works with the low LED currents. However you can't seem to get the V1 bypass module anymore, so wondering if a V2 module would work.
I could ask Fibaro but I generally find here to be more informed!
Sat Dec 31, 2016 6:58 pm
aderrington offline
I believe I read somewhere awhile ago that the bypass 2 would work with a dimmer 1. But I can't remember where but you should be able to go on the fibaro website and look at the manual for the bypass 2, that might have the info you need.
