There is definitely something odd going on with this. The Airfoil error message seems to start up and go away at will. I have only one copy of Airfoil on the Mac running server. I have checked and re-checked. But the airfoil error seems to come and go randomly. There will no errors for days at a time, then all of a sudden the error messages start, seemingly with no provocation. The below is from my log when the error started, and it has got for 21 hours straight since. I have one simple AppleScript that communicates with Radium and Airfoil receives the sound from the radium app.
ANY IDEAS?
received: 69.5)
2016-12-10 11:16:39.247 Trigger Motion Living Room
2016-12-10 11:22:59.235 Trigger Open Front Door
2016-12-10 11:23:27.957 Trigger Motion Living Room
2016-12-10 11:26:13.281 Received INSTEON "Thermostat - Upstairs" on (button 2)
2016-12-10 11:26:14.862 Received INSTEON "Thermostat - Upstairs" on (all linked devices)
2016-12-10 11:26:53.760 Trigger Motion Living Room
2016-12-10 11:27:05.269 Trigger Motion Office
2016-12-10 11:30:10.454 Trigger Motion Office
2016-12-10 11:30:43.721 Airfoil Error Update failed. Check to see if Airfoil is functioning correctly and that there is only a single copy of the application on your hard drive.
2016-12-10 11:30:45.890 Airfoil Error Update failed. Check to see if Airfoil is functioning correctly and that there is only a single copy of the application on your hard drive.
2016-12-10 11:30:48.009 Airfoil Error Update failed. Check to see if Airfoil is functioning correctly and that there is only a single copy of the application on your hard drive.
2016-12-10 11:30:50.150 Airfoil Error Update failed. Check to see if Airfoil is functioning correctly and that there is only a single copy of the application on
RADIUM SCRIPT:
- Code: Select all
using terms from application "IndigoServer"
on GetsxmStation()
tell application id "com.catpigstudios.Radium3"
if it is running then
set AAA to track name
my set_variable(("sxmTrack"), AAA as string)
set AAA to station name
my set_variable(("sxmStation"), AAA as string)
end if
end tell
end GetsxmStation
on set_variable(variable_name, variable_value)
if not (variable (variable_name) exists) then
make new variable with properties {name:variable_name, value:(variable_value as string)}
else
set value of (variable (variable_name)) to (variable_value as string)
end if
end set_variable
end using terms from
