Energy Monitor Energy Monitor, Sleep Interval is 900
Energy Monitor PReferences DAtaLogcation - ~/Dropbox/HomeAutomation/Energy_Data
Energy Monitor Energy Data Path - /Users/Benjamin/Dropbox/HomeAutomation/Energy_Data
Started plugin "Energy Monitor 2.10"
Started interface "Z-Wave 2.0.111"
Started plugin "Hue Lights 1.6.6"
Energy Monitor Loading past energy usage for week 31-2018.pickle
Energy Monitor Setting up Device - Power Monitor
Energy Monitor Current Device Version - 3
Energy Monitor Checking Energy meter 497160003
Hue Lights Loaded 2 lights.
Hue Lights Loaded 12 groups.
Hue Lights Loaded 17 scenes.
Hue Lights Loaded 7 sensors.
Energy Monitor Weekly Label- 31-2018
Energy Monitor Daily Label- 214-2018
Energy Monitor Weekly - ['31-2018']
Energy Monitor Daily - ['213-2018', '214-2018']
Energy Monitor today - {'accumEnergyTimeDelta': 38419348, 'accumEnergyTotal': 11557.497, 'curEnergyLevel': 3316.94, 'time': 'Thu Aug 2 22:14:32 2018'}
Energy Monitor Writing all data to disk.
Started plugin "EPS - Homebridge Buddy 1.0.1"
EPS - Homebridge Buddy Starting the Homebridge server 'homenet homebridge', do not try to use Siri until you get a message that the server has started
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
Z-Wave found module included in controller with no matching device (missing or disabled): 008 - Relay Scene Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 011 - Portable Controller
Aug 2, 2018 at 10:14:35 PM
Trigger Reset Chime Status @ startup
Error error finding script file: Weather NOAA sync.scpt - file not found
Connected to PowerLinc 2413U interface on port usbserial-A60333BY
PowerLinc address 2B.93.28, firmware version 9.11
EPS - Homebridge Buddy EPS - Homebridge Buddy is loaded and ready to use
jay (support) wrote:When you moved to the new Mac and copied over the appropriate folder, did you rerun the Indigo installer?
jay (support) wrote:A few more questions:
- Besides the Z-Wave interface menu being grayed out, what other Z-Wave "wonkyness" are you seeing specifically? (there don't appear to be any errors in the event log snippit above)
- Are you on v7.1.1?
- What OS version?
