My PowerLinc Model went dead for no apparent reason. No lights, etc. I ordered a new one and went to install it. When I went to sync it it failed to sync with all the passive battery powered devices: motion sensors, water sensors, etc. It requests I hit the set button on each to wake it up. The only problem is that these are mounted in attics, crawl spaces, and other somewhat inaccessible locations throughout the house. It will likely take two people with walkie talkies at least a couple of hours to do this.
Is there any alternative solution? Is there any way to clone the identity of the prior modem so that the distributed sensors are linked to the replacement?
If not, this seems like a very shortsighted support design flaw with the system. As you can tell I am pretty much resigned to the fact that the situation sucks.
Bummed out.
