Colly wrote:My main concern is that @FlyingDiver doesn’t fly off as I’m quite reliant on his plugins
FlyingDiver wrote:Thanks Joe.Colly wrote:My main concern is that @FlyingDiver doesn’t fly off as I’m quite reliant on his plugins
At least all mine have open source licenses and are on GitHub. So someone else could take them over.
FlyingDiver wrote:Already did, both development and production machines.
What specific plugins are you missing? There's a few laggards that are being tested now. Pretty much anything else is unlikely to be updated at this point. Finding an alternative solution should be your priority. Just waiting isn't going to help at all.
ryanbuckner wrote:The Nest and Ring plugins are probably the biggest, and it doesn't look like they will be upgraded because of the issues surrounding API support.
autolog wrote:ryanbuckner wrote:The Nest and Ring plugins are probably the biggest, and it doesn't look like they will be upgraded because of the issues surrounding API support.
Nest devices can be accessed in Indigo via a Starling Hub and associated plugin, see: Starling Bridge
FlyingDiver wrote:What specific plugins are you missing? There's a few laggards that are being tested now. Pretty much anything else is unlikely to be updated at this point. Finding an alternative solution should be your priority. Just waiting isn't going to help at all.
Turribeach wrote:Alexa-Hue Bridge, Tivo Network Remote, uniFiAP and UPS Battery and Monitor.
CliveS wrote:Just updated my vote from Not Sure to Yes thanks to Neil and the last yellow dot on Honeywell went green with its replacement Evohome
