Indigo 7.4 - No Applescripts error
Thu Oct 03, 2019 1:21 am
autolog offline
I used the menu Help > Show AppleScript Usage in Event log.
I had one AppleScript Action Group listed in the Event Log.
I deleted it as I no longer needed it and then ran the help menu command again.
I got this error:
Error internal error calculating showDeprecatedUsage
Error UnicodeEncodeError: 'ascii' codec can't encode character u'\xa0' in position 30: ordinal not in range(128)
I guess this may be related to the previous bug I reported? :)
Thu Oct 03, 2019 3:32 am
Re: Indigo 7.4 - No Applescripts error
Just as another data point, I have no Applescripts and do not get that error. When I run the command, nothing appears to happen (to be clear something did happen when I still had Applescripts).
Suggestion: write "Found no AppleScripts" (or something like that) to the log when there are none.
Thu Oct 03, 2019 8:10 am
roussell offline
Interestingly enough, I had several triggers, schedules, and one action group, all deactivated. I deleted them all and then re-ran the tool and did not get an error, the tool returned nothing. I second the usage of a “No Applescripts Found” type of message.
Terry
Thu Oct 03, 2019 8:28 am
autolog wrote:
I got this error:
Actually, that is a different unrelated unicode encoding buglet. :roll: Both of them will be fixed in 7.4.1, to be released soon.
Additionally, Indigo will now log a "nothing found" type message if you run the report and no embedded AppleScripts were found in your database.
Thanks for the feedback guys!
Fri Feb 07, 2020 1:59 pm
Indigo 7.4.1 is now available and fixes both of these bugs.
