Domotics Pad Mobile Client ErrorError in plugin execution
Tue Sep 10, 2019 12:10 pm
T-Power offline
Hello Good People,
Can some one please help with my recent plugin error.
Sep 10, 2019, 12:22:08 PM
  Reloading plugin "Domotics Pad Mobile Client 1.3.2"
  Stopping plugin "Domotics Pad Mobile Client 1.3.2" (pid 16688)
  Stopped plugin "Domotics Pad Mobile Client 1.3.2"
  Starting plugin "Domotics Pad Mobile Client 1.3.2" (pid 76385)
  Started plugin "Domotics Pad Mobile Client 1.3.2"
  Domotics Pad Mobile Client ErrorError in plugin execution runConcurrentThread:
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DomoPad Mobile Client Plugin.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkPlugin.py", line 749, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DomoPad Mobile Client Plugin.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkPlugin.py", line 805, in pollForAvailableUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DomoPad Mobile Client Plugin.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkPlugin.py", line 821, in checkVersionNow
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DomoPad Mobile Client Plugin.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkUpdater.py", line 94, in checkForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DomoPad Mobile Client Plugin.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkUpdater.py", line 182, in _prepareForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DomoPad Mobile Client Plugin.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkUpdater.py", line 103, in getUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DomoPad Mobile Client Plugin.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkUpdater.py", line 124, in getLatestRelease
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/DomoPad Mobile Client Plugin.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkUpdater.py", line 152, in _GET
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 914, in request
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 951, in _send_request
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 908, in endheaders
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 780, in _send_output
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 739, in send
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/httplib.py", line 1116, in connect
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/ssl.py", line 338, in wrap_socket
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/ssl.py", line 120, in __init__
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/ssl.py", line 279, in do_handshake
SSLError: [Errno 1] _ssl.c:491: error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
  Domotics Pad Mobile Client Errorplugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  Email Scanned                   from “baba.com"; subject “hello from baba"
  Trigger                         Email Alert: Baba
  Domotics Pad Mobile Client ErrorError sending push notification.
I am on Indigo v6.1.11
Domo Pad Client 1.3.2
Everything has been working fine without adding anything new to the system setup for a long while. I have reloaded the plugin, restarted Indigo, reboot system, fixed permissions and still the same result.
Any help would be much appreciated.
Thank you :)
MacMini 2.3 GHz Intel Core i7 16GB DDR3
Indigo Pro 2022.1 macOS Mojave 10.14.6
Sat Sep 14, 2019 10:35 am
RogueProeliator offline
Re: Domotics Pad Mobile Client ErrorError in plugin executio
That looks like you are hitting the depreciated SSL version check from an older version of the plugin... I would suggest just turning off the notification check in the plugin configuration since there won't be any further releases for Indigo 6.x.
Adam
Sat Sep 14, 2019 3:40 pm
T-Power offline
Hello Adam,
Hoping your good!
Thanks for the response, I will track down an older version of the plugin along with turning off the notification part.
Sun Sep 15, 2019 4:39 pm
You are running the latest version for Indigo v6.x so no need to do anything other than turn off the notification check for updates.
Adam
