Page 2 of 2
Re: Invalid historical data
PostPosted: Thu Aug 27, 2020 10:13 pm
by RogueProeliator
I'm having the same "invalid historical data" problem. I'm running plugin v2.2.6 in Indigo 7.4 under MacOS 10.7.5 and connecting to v1.9.1 of the Android client on a Samsung S10e.
Any errors in the event log? Can you post a screenshot of your SQL Logger setup (can block out anything you don't want shown)?
PostPosted: Fri Aug 28, 2020 7:20 pm
by gmusser
Here's the SQL configuration.
Screen Shot 2020-08-28 at 9.06.26 PM.png (236.44 KiB) Viewed 2691 times
PostPosted: Tue Sep 01, 2020 8:38 pm
by RogueProeliator
Hmm, I wonder if the storing of only the changed states is causing issues with NULL values -- I think the historical data pull may predate that feature. Can you do a quick test - I see you have the variable history tracked, would you mind checking the history on a variable and see if that shows properly?
Adam
PostPosted: Wed Sep 02, 2020 7:35 am
by gmusser
I get the "Invalid historical data received" message for variables, too.
