Attempting to save Geofence locks DomoticsPad
Wed Nov 15, 2023 9:46 pm
duanel offline
Lat and long are populated automatically and after entering a name and radius, I click the checkmark to save the geofence. The cursor stops blinking and application becomes unresponsive EXCEPT the keyboard will allow me to continue typing on the last edited field (if I haven't closed the on-screen keyboard) and the UI starts responding again.. However, whenever I attempt to save the geofence, the app locks up again.
I'm using a Galaxy S22 Ultra that is paired with the plugin. Status updates are enabled. Location permissions are allowed when using the app and I don't have an option to enable them all of the time. I've noticed that the latitude, longitude and locationFixTime are all blank values in indigo.
Fri Nov 17, 2023 2:05 pm
duanel offline
Re: Attempting to save Geofence locks DomoticsPad
I'm also seeing errors for "undefined page for request /AndroidClientHelper/getDeviceHistory from 192.168.0.***" in the logs after attempting to view device history in the Android app. Lastly, device history is showing "The Domotics Pad Mobile Client plugin is missing or mis-configured on the server". I've confirmed that AndroidClientHelper is in the Web Assets/plugins/ directory.
Mon Dec 25, 2023 3:06 pm
RogueProeliator offline
That sounds like either using an older version of Domotics Pad with a newer Indigo installation or the newest Domotics Pad with an older version of Indigo. Neither scenario will really work as there were some changes to Indigo that required equivalent changes to the application.
What versions are you running? I need to check the published version of Domotics Pad too now that I think about it, but let's start with your current versions.
Wed Jan 03, 2024 4:29 pm
duanel offline
Happy New Year!
Thanks for your help. I'm using Indigo 2023.1.1, Domotics pad clients 2023.11.0(ish) and Domotics Pad v2.0.0.
Indigo version
Screenshot 2024-01-03 at 5.19.25 PM.png (198.85 KiB) Viewed 2125 times
Domotics Pad Clients version
Screenshot 2024-01-03 at 5.19.11 PM.png (62.35 KiB) Viewed 2125 times
Domotics Pad version
Screenshot_20240103_172107_Domotics Pad Medium.jpg (37.58 KiB) Viewed 2125 times
