Foscam Plugin - control/capture Foscam ip camera
Tue Jan 14, 2014 2:47 pm
virgahyatt offline
Re: Foscam Plugin - control/capture Foscam ip camera
Just FYI, I was able to use this plugin to control my Insteon IP camera 75790 without any trouble. I haven't fully tested it yet but from what I can tell the cgi paths match what foscam uses.
Sun Feb 02, 2014 12:38 pm
Unklmarty offline
Problem using Foscam plugin to send snapshots.
All software is on same box:
MAC IO 10.9.1
Indigo: 6.0.10
Security Spy 3.1.3
Cynical SecuritySpy Plugin 1.6.1
Foscam Plugin 1.0.2
I have created SS and Foscam devices and checked that the plugins are correctly configured.
When exciting the trigger I get the following message:
Foscam Controller Error Error in plugin execution ExecuteAction:
See end of Event Log.
Any ideas?
Marty
Event log: (I've added the ????)
Feb 2, 2014, 1:25:32 PM
Starting Indigo Server version 6.0.10
Loading attachments
Loading plugin "Action Collection 1.4.5"
Starting plugin "Action Collection 1.4.5" (pid 428)
Loading interface "INSTEON Commands 2.0.4"
Starting interface "INSTEON Commands 2.0.4" (pid 429)
Loading plugin "Announcer 1.1.6"
Starting plugin "Announcer 1.1.6" (pid 430)
Loading plugin "Cynical SecuritySpy 1.6.1"
Starting plugin "Cynical SecuritySpy 1.6.1" (pid 431)
Loading plugin "Foscam Controller 1.0.2"
Starting plugin "Foscam Controller 1.0.2" (pid 432)
Loading plugin "Backup 1.00"
Starting plugin "Backup 1.00" (pid 433)
Loading plugin "NOAA Weather 1.1.0"
Starting plugin "NOAA Weather 1.1.0" (pid 434)
Found disabled interface "Z-Wave 1.0.187"
Found disabled plugin "Airfoil 1.1.4"
Found disabled plugin "DIRECTV DVR Control 1.0.0"
Found disabled plugin "EasyDAQ Relay Card 1.1.4"
Found disabled plugin "Growl 1.1.1"
Found disabled plugin "iCal Alarm Processor 1.1.0"
Found disabled plugin "iTunes 1.1.4"
Found disabled plugin "SQL Logger 1.1.6"
Found disabled plugin "Timers and Pesters 1.1.3"
Found disabled plugin "Vera Bridge 1.0.5"
Found disabled interface "Virtual Devices 1.0.11"
Found disabled plugin "WeatherSnoop 2.0.1"
Bonjour registered "Indigo - 33mr 6.0.10.indidb"
Indigo Cocoa client connected
Started plugin "Backup 1.00"
Backup Starting Backup, saving to ~/Documents/IndigoBackup
Backup archive filename /????/????/Documents/IndigoBackup/Indigo_Backup_02_02_2014__13_25_33.zip
Backup save path /library/Application Support/Perceptive Automation/Indigo 6
Cynical SecuritySpy API version 1.15
Started interface "INSTEON Commands 2.0.4"
Started plugin "Action Collection 1.4.5"
Started plugin "NOAA Weather 1.1.0"
Started plugin "Cynical SecuritySpy 1.6.1"
Cynical SecuritySpy mapping device "SSpy MR Front Door" 1120033567(camera)
Cynical SecuritySpy SSpy MR Front Door starting
Cynical SecuritySpy mapping device "SSpy Server" 216251738(server)
Cynical SecuritySpy SSpy Server starting
Cynical SecuritySpy mapping device "SSpy MR Front HD" 1549148742(camera)
Cynical SecuritySpy SSpy MR Front HD starting
Cynical SecuritySpy mapping device "SSpy MR Mud room" 1266063879(camera)
Cynical SecuritySpy SSpy MR Mud room starting
Cynical SecuritySpy mapping event "Motion activated email from Front door camera" 1119829864(cameramotion)
Cynical SecuritySpy Motion activated email from Front door camera starting
Cynical SecuritySpy plugin starting asyn operation
Cynical SecuritySpy SSpy Server is now ready
Cynical SecuritySpy SSpy MR Front Door host device SSpy Server now available
Cynical SecuritySpy SSpy MR Front Door is now active
Cynical SecuritySpy SSpy MR Front HD host device SSpy Server now available
Cynical SecuritySpy SSpy MR Front HD is now active
Cynical SecuritySpy SSpy MR Mud room host device SSpy Server now available
Cynical SecuritySpy SSpy MR Mud room is now active
Cynical SecuritySpy event tap active
Started plugin "Foscam Controller 1.0.2"
Foscam Controller Debug startup called
Started plugin "Announcer 1.1.6"
WebServer client connected
WebServer started on port ???? -- digest authentication enabled
Backup Backup Finished.
Feb 2, 2014, 1:25:36 PM
Emails on POP server mail.verizon.net will be scanned every 1 minutes
Feb 2, 2014, 1:25:37 PM
Connected to PowerLinc 2413U interface on port usbserial-A4016MXF
PowerLinc address 1E.DC.EF, firmware version 9.11
Feb 2, 2014, 1:25:54 PM
Trigger Motion activated email from Front door camera
Foscam Controller Debug snap called
Foscam Controller Debug url xmitted: http://192.168.1.35:????/snapshot.cgi?user=????&pwd=????
Announcer Announcing message "Motion Detected at the Front door".
Feb 2, 2014, 1:30:15 PM
File "plugin.py", line 242, in snap
File "plugin.py", line 260, in sendViaEmail
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/smtplib.py", line 244, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/smtplib.py", line 311, in connect
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/smtplib.py", line 355, in getreply
<class 'smtplib.SMTPServerDisconnected'>: Connection unexpectedly closed
Fri Feb 07, 2014 3:18 pm
robertgerman offline
Re: Foscam Plugin for Indigo
Thanks for a great plug-in! Any plans on adding the newer foscam models with hd-capturing?
Rob
Mon Mar 03, 2014 8:42 pm
bmcgowan13 offline
What do you use for the hostname? I am trying to get my Insteon IP cameras connected but they all fail. Is the host name the same as the web address (http://192.168.0.41:25110) and do you use the generic password (admin) with generic password (blank).
I'd love to be able to use my motion detector to trigger captures but I'm stumbling...
Tue Mar 04, 2014 5:10 pm
bmcgowan13 offline
I get this error message from all three of my INSTEON/FOSCAM cameras. Am I missing something obvious? I'd love to be able to use the motion sensor to trigger some video.
Trigger CAM Garage Snapshot
Foscam Controller Debug url xmitted: http://192.168.0.51:25XXX/snapshot.cgi? ... 3&pwd=XXXX
File "plugin.py", line 256, in sendViaEmail
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/email/mime/image.py", line 43, in __init__
<type 'exceptions.TypeError'>: Could not guess image MIME subtype
Thu Mar 13, 2014 7:44 pm
fim32 offline
i submitted a pull request... to get around this error i forced the mime type to "jpeg", for better or worse.
i don't know if this helps any but the nerdliest, but here's the patch:
Contents/Server Plugin/plugin.py | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/Contents/Server Plugin/plugin.py b/Contents/Server Plugin/plugin.py
index 8048e9c..c9ba39c 100644
--- a/Contents/Server Plugin/plugin.py
+++ b/Contents/Server Plugin/plugin.py
@@ -253,7 +253,7 @@ class Plugin(indigo.PluginBase):
# Open the files in binary mode. Let the MIMEImage class automatically
# guess the specific image type.
fp = open('/tmp/snap.jpg', 'rb')
- img = MIMEImage(fp.read())
+ img = MIMEImage(fp.read(), "jpeg")
fp.close()
msg.attach(img)
Sat Mar 15, 2014 11:53 am
Unklmarty offline
(i don't know if this helps any but the nerdliest, but here's the patch:)
It sure would help except.....ummmm.. just where and how do I apply the patch?
Sun Mar 30, 2014 7:37 am
Ankleshanker offline
I'm getting ready to purchase a Foscam. The allure of HD images and improved quality of the 9000 series is tempting, but the Indigo compatibility of the 8000 series (thanks to your plugin) trumps it. Do you plan to update your plugin to support the 9000 series in the near future?
Thank you for your time and effort on this plug in,
Sun Apr 06, 2014 1:55 pm
pantalones offline
@ankleshanker
i say this as the owner of four foscam cameras, two panasonics, and one y-cam
do not buy foscams. they have the worst customer support on the planet, unstable inconsistent products, and most of all, faulty hardware. it seems to be a shell company for a completely disorganized system of developers in China (nothing against china, that's not the issue). What happens is they release some buggy garbage, customers complain, and then it may or may not get fixed. In two cases now instead of fixing the problem for users (e.g., cameras disconnecting, rebooting, not saving images), they've released a "v2" of the camera (six months later, not a reasonable product cycle) and left the v1 owners hanging.
My foscams are only items of regret at this point. I'm replacing them all.
If you're still unsure, go look at the foscam boards. They are filled with furious customers.
Fri Apr 18, 2014 2:04 am
wasmitschmidt offline
Hello,
I just try this cool plugin.
But when I try to send an snapshot via mail I receive this error:
  File "plugin.py", line 248, in sendViaEmail
<type 'exceptions.KeyError'>: key subject not found in dict
The URL for the snapshot works when I manually enter the URL in my browser.
  Trigger                         HT - isMotion
  Foscam Controller Debug         url xmitted: http://10.0.1.19:8081/snapshot.cgi?user=USER&pwd=PASSWORD
Any idea what is wrong in my setup?
Sat Apr 19, 2014 2:55 am
OMG, a typical stupid user error...
I didn't enter subject and recipient in the cam action template!
Now everything work very fine :-)
Tue Dec 09, 2014 4:28 am
richo offline
Have setup SMTP in Indigo and notifications from Indigo work however can't send snapshots from the plugin. Get the following message:
File "plugin.py", line 264, in sendViaEmail
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/smtplib.py", line 596, in login
<class 'smtplib.SMTPAuthenticationError'>: (535, '5.7.8 Username and Password not accepted. Learn more at\n5.7.8 http://support.google.com/mail/bin/answ ... swer=14257 e7sm1087474wjx.31 - gsmtp')
Ryszard
Sun Dec 21, 2014 10:08 pm
flg8r96 offline
I just downloaded the v1.0.0 version of the foscam plugin and wasn't able to email a snaphot from my foscam. After reviewing the event log it was clear that there was an extra forward slash after my camera's IP address that was messing things up and preventing indigo from grabbing a snapshot from the cam. See error below:
Foscam Controller Debug url xmitted: http://192.168.1.76//snapshot.cgi?user=admin&pwd=admin
After looking at the source code for this plugin I notice that 1.0.0 had a bug in plugin.py on line 233 ... it had an extra forward slash before 'snapshot.cgi' as show below:
esp = self.xmitToCamera('/snapshot.cgi', {}, dev)
The good news is v1.0.3 doesn't have the extra slash. However, after upgrading to that plugin I'm getting the same error. I've restarted the plugin, I've restarted the indigo server ... no luck.
Any advice would be much appreciated.
M
Sat Jan 03, 2015 9:28 pm
cdeggz offline
I'm loving the plugin! Having this on my garage door control page is great.
That said, is is possible to get the video feed, not just images? Right now I'm doing 1-second image refresh using a fetch image URL, but would prefer to imbed the video feed.
Thu Jan 29, 2015 5:01 am
MarcoGT offline
Is there a plan to support HD cameras?
