Thanks for the tip Matt. My Powerlinc V2 won't be here until monday, so I have to wait until then to start converting settings in Indigo. As I've already installed about 10 Insteon switches, I'll either have to do a lot of linking/syncing or a lot of removing wall-plates.
Suppose I do choose to just remove wallplates and copy codes down. In Indigo, currently, certain Insteon switches are defined as X10 addresses. If I just tell Indigo they are Insteon switches, input the correct address and press "Links Syncing", do I still have to do the press and hold bit?
Also, will Indigo know about all the cross-links I've already set up? Let me give you an example.
Controlinc---->Switchlinc<-----Keypadlinc
I currently have some lights setup like this. I have everything cross-linked to each other. I.E. Send command from Controlinc will turn on switchinc and a light up the appropriate button on the keypadlinc. If I tell Indigo the address of the switchlinc (and link sync), will Indigo respond to commands from the Controlinc and the keypadlinc? As you know, normally, you have to crosslinc everything to each other (one of the few "cons" of Insteon), to keep everything in sync.
Thomas
