jay (support) wrote:We haven't revised Indigo Touch yet, but you can create a control page with the appropriate controls on it.
bbruck wrote:Wow! Worked perfectly, solving BOTH problems! Many thanks!
jay (support) wrote:You shouldn't connect the load from the KeypadLinc to the FanLinc - it (the FanLinc) should be wired directly to the line so that it always has power (at least that's how I've got mine installed).
On the KeypadLinc, you'll cap off the load wire and just link the various buttons to either the light part of the FanLinc (to control the light) or to the 4 fan states (Off, Low, Medium, High). As for switching directly to the speed - you have to configure the 4 KPL buttons you want to control the fan speeds as a radio group and set them to non-toggle (ON) mode. At the moment you have to do this manually by following the instructions that came with the KPL.
The next Indigo release will have a plugin that will make setting up this type of functionality easier and I'll write a How-To with the steps to get it done. The next release will hopefully be available sometime this coming week.
Received INSTEON "Lighting [KPL - living room fan]" on (button 2)
Trigger HVAC FAN HIGH [living room]
Sent INSTEON "HVAC FAN [living room] - Fan" set motor speed to high
Jay wrote:You shouldn't connect the load from the KeypadLinc to the FanLinc - it (the FanLinc) should be wired directly to the line so that it always has power (at least that's how I've got mine installed).
Received INSTEON "Controller [KPL - living room fan]" on (button 6)
Trigger HVAC [lvr - dual fans LOW]
Action Group HVAC [dual fans LOW]
Sent INSTEON "HVAC Fan [kitchen]" set motor speed to low
Sent INSTEON "HVAC Fan [living room]" set motor speed to low
Sent INSTEON "Controller [KPL - kitchen fan]" raw insteon command (2E 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Sent INSTEON "Controller [KPL - kitchen fan]" raw insteon command (2E 00 00 09 20 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Sent INSTEON "Controller [KPL - living room fan]" raw insteon command (2E 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Sent INSTEON "Controller [KPL - living room fan]" raw insteon command (2E 00 00 09 20 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Received INSTEON "Controller [KPL - living room fan]" on (button 4)
Trigger HVAC [lvr - dual fans MED]
Action Group HVAC [dual fans MED]
Sent INSTEON "HVAC Fan [kitchen]" set motor speed to medium
Sent INSTEON "HVAC Fan [living room]" set motor speed to medium
Sent INSTEON "Controller [KPL - kitchen fan]" raw insteon command (2E 00 00 09 08 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Sent INSTEON "Controller [KPL - living room fan]" raw insteon command (2E 00 00 09 08 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Received INSTEON "Controller [KPL - living room fan]" on (button 2)
Trigger HVAC [lvr - dual fans HIGH]
Action Group HVAC [dual fans HIGH]
Sent INSTEON "HVAC Fan [kitchen]" set motor speed to high
Sent INSTEON "HVAC Fan [living room]" set motor speed to high
Sent INSTEON "Controller [KPL - kitchen fan]" raw insteon command (2E 00 00 09 02 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Sent INSTEON "Controller [KPL - living room fan]" raw insteon command (2E 00 00 09 02 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Received INSTEON "Controller [KPL - living room fan]" on (button 8)
Trigger HVAC [lvr - dual fans OFF]
Action Group HVAC [dual fans OFF]
Sent INSTEON "HVAC Fan [kitchen]" set motor speed to off
Sent INSTEON "HVAC Fan [living room]" set motor speed to off
Sent INSTEON "Controller [KPL - kitchen fan]" raw insteon command (2E 00 00 09 80 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Sent INSTEON "Controller [KPL - living room fan]" raw insteon command (2E 00 00 09 80 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
CraigM wrote:Not only are some speeds wrong, but what's with the light coming on from a speed command?
CraigM wrote:Is there anyway to show me if there is anything associated a button that I don't know about?
CraigM wrote:I'm tempted to do a factory reset, but how will that hose my radio & LED config on both KPL's?
koensayr wrote:1) Why is creating an Action Group required here? I seem to be able to do this natively with Indigo 6.0b10.
koensayr wrote:2) When I run the associated commands, Indigo returns an error from the KPL saying that the command wasn't acknowledge. I suspect because the firmware on my chosen KPL is just 1.6 and I need something newer. What version does it require?
Anything else I should check?
matt (support) wrote:Here are some examples:
- Code: Select all
dev = indigo.devices[518185989] # ID can be found by right-clicking on the device
# Changing it to a specific speed:
indigo.speedcontrol.setSpeedIndex(dev, 0) # OFF
indigo.speedcontrol.setSpeedIndex(dev, 1) # LOW
indigo.speedcontrol.setSpeedIndex(dev, 2) # MEDIUM
indigo.speedcontrol.setSpeedIndex(dev, 3) # HIGH
indigo.speedcontrol.setSpeedIndex(dev, 2, delay=6) # MEDIUM in 6 seconds
# And performing relative speed changes:
indigo.speedcontrol.increaseSpeedIndex(dev)
indigo.speedcontrol.decreaseSpeedIndex(dev)
theName = indigo.variables["FanLinc_Name"]
theSpeed = indigo.variables["FanLinc_Speed"]
theDevice = indigo.devices[theName]
indigo.speedcontrol.setSpeedIndex(theName, theSpeed)
Users browsing this forum: No registered users and 21 guests
