matt (support) wrote:Did you send the +6 and -6 setpoint commands back-to-back to all 5 thermostats without much delay between them? If so, I could see that causing quite a signal storm. The thermostats will broadcast out setpoint changes after they receive them, and if that broadcast occurred while Indigo was trying to send another thermostat a command (or a different thermostat was trying to do a broadcast) then I could see them getting in to a command collision war. That said, it should resolve itself without getting bogus temperature values.
What made the ApplianceLinc start working again? Did you just have to wait a couple of minutes for everything to settle down? And what did the Event Log look like during all of this?
2012-05-21 23:56:14 Error "Thermostat Main Bedrooms" set heat setpoint to 64.0; send failed (no acknowledgment)
2012-05-21 23:56:21 Error "Thermostat Main Bedrooms" set cool setpoint to 83.0; send failed (no acknowledgment)
2012-05-21 23:56:29 Error "Thermostat Main Bedrooms" set heat setpoint to 63.0; send failed (no acknowledgment)
2012-05-21 23:56:30 Sent INSTEON "Thermostat Main Bedrooms" set cool setpoint to 82.0
2012-05-21 23:56:32 Received INSTEON "Thermostat Main Bedrooms" cool setpoint changed to 82.0
2012-05-21 23:56:33 Received INSTEON "Thermostat Main Bedrooms" cool setpoint changed to 82.0
2012-05-21 23:56:34 Received INSTEON "Thermostat Main Bedrooms" cool setpoint changed to 82.0
2012-05-21 23:56:42 Error "Thermostat Main Bedrooms" set heat setpoint to 62.0; send failed (no acknowledgment)
2012-05-21 23:56:49 Error "Thermostat Main Bedrooms" set cool setpoint to 81.0; send failed (no acknowledgment)
2012-05-21 23:56:53 Error "Thermostat Main Bedrooms" set heat setpoint to 61.0; failed (illegal value in command)
2012-05-21 23:57:00 Error "Thermostat Main Bedrooms" set cool setpoint to 80.0; send failed (no acknowledgment)
2012-05-21 23:57:08 Error "Thermostat Main Bedrooms" set cool setpoint to 79.0; send failed (no acknowledgment)
2012-05-21 23:57:15 Error "Thermostat Main Bedrooms" set heat setpoint to 60.0; send failed (no acknowledgment)
2012-05-21 23:57:23 Error "Thermostat Main Bedrooms" set heat setpoint to 59.0; send failed (no acknowledgment)
2012-05-21 23:57:24 Received INSTEON "Thermostat Main Bedrooms" temperature changed to 78.0
2012-05-21 23:57:32 Error "Thermostat Main Bedrooms" set cool setpoint to 78.0; send failed (no acknowledgment)
2012-05-21 23:57:39 Error "Thermostat Main Bedrooms" set cool setpoint to 77.0; send failed (no acknowledgment)
2012-05-21 23:57:42 Sent INSTEON "Thermostat Main Bedrooms" set heat setpoint to 58.0
2012-05-21 23:57:42 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 85.0
2012-05-21 23:57:43 Received INSTEON "Thermostat Main Bedrooms" heat setpoint changed to 58.0
2012-05-21 23:57:44 Received INSTEON "Thermostat Main Bedrooms" heat setpoint changed to 58.0
2012-05-21 23:57:45 Received INSTEON "Thermostat Main Bedrooms" heat setpoint changed to 58.0
2012-05-21 23:57:46 Received INSTEON "Thermostat Fam Study" cool setpoint changed to 85.0
2012-05-21 23:57:53 Error "Thermostat Fam Study" set heat setpoint to 59.0; send failed (no acknowledgment)
2012-05-21 23:58:01 Error "Thermostat Main Bedrooms" set cool setpoint to 81.0; send failed (no acknowledgment)
2012-05-21 23:58:08 Error "Thermostat Main Bedrooms" set heat setpoint to 57.0; send failed (no acknowledgment)
2012-05-21 23:58:16 Error "Thermostat Main Bedrooms" set cool setpoint to 80.0; send failed (no acknowledgment)
2012-05-21 23:58:23 Action Group aStatus Update A/C
2012-05-21 23:58:23 Error "Thermostat Main Bedrooms" set heat setpoint to 57.0; send failed (no acknowledgment)
2012-05-21 23:58:31 Error "Thermostat Main Bedrooms" set heat setpoint to 56.0; send failed (no acknowledgment)
2012-05-21 23:58:34 Received INSTEON "Thermostat Main Bedrooms" temperature changed to 79.0
2012-05-21 23:58:35 Received INSTEON "Thermostat Main Bedrooms" temperature changed to 79.0
2012-05-21 23:58:36 Received INSTEON "Thermostat Main Bedrooms" temperature changed to 79.0
2012-05-21 23:58:44 Error "Thermostat Main Bedrooms" set cool setpoint to 79.0; send failed (no acknowledgment)
2012-05-21 23:58:51 Error "Thermostat Main Bedrooms" set heat setpoint to 55.0; send failed (no acknowledgment)
2012-05-21 23:58:59 Error "Thermostat Main Bedrooms" set cool setpoint to 78.0; send failed (no acknowledgment)
2012-05-21 23:58:59 Sent INSTEON "Thermostat Fam Room" mode request (received: auto on)
2012-05-21 23:59:00 Sent INSTEON "Thermostat Fam Room" temperature request (received: 79.0)
2012-05-21 23:59:00 Sent INSTEON "Thermostat Fam Room" humidity request (received: 43.0)
2012-05-21 23:59:04 Sent INSTEON "Thermostat Fam Room" setpoint request (received: heat 58.0, cool 84.0)
2012-05-21 23:59:04 Sent INSTEON "Thermostat Fam Study" mode request (received: auto on)
2012-05-21 23:59:04 Sent INSTEON "Thermostat Fam Study" temperature request (received: 78.0)
2012-05-21 23:59:05 Sent INSTEON "Thermostat Fam Study" humidity request (received: 47.0)
2012-05-21 23:59:08 Sent INSTEON "Thermostat Fam Study" setpoint request (received: heat 67.0, cool 85.0)
2012-05-21 23:59:08 Sent INSTEON "Thermostat GameRm" mode request (received: auto on)
2012-05-21 23:59:08 Sent INSTEON "Thermostat GameRm" temperature request (received: 78.0)
2012-05-21 23:59:10 Sent INSTEON "Thermostat GameRm" humidity request (received: 47.0)
2012-05-21 23:59:14 Sent INSTEON "Thermostat GameRm" setpoint request (received: heat 60.0, cool 84.0)
2012-05-21 23:59:16 Sent INSTEON "Thermostat Main Bedrooms" mode request (received: auto on)
2012-05-21 23:59:22 Error "Thermostat Main Bedrooms" temperature request; send failed (no acknowledgment)
2012-05-21 23:59:28 Error "Thermostat Main Bedrooms" humidity request; send failed (no acknowledgment)
2012-05-21 23:59:35 Error "Thermostat Main Bedrooms" setpoint request; send failed (no acknowledgment)
2012-05-21 23:59:35 Sent INSTEON "Thermostat MBR" mode request (received: auto on)
2012-05-21 23:59:36 Sent INSTEON "Thermostat MBR" temperature request (received: 75.0)
2012-05-21 23:59:37 Sent INSTEON "Thermostat MBR" humidity request (received: 34.0)
2012-05-21 23:59:40 Sent INSTEON "Thermostat MBR" setpoint request (received: heat 63.0, cool 74.0)
2012-05-21 23:59:47 Error "Thermostat Main Bedrooms" set cool setpoint to 77.0; send failed (no acknowledgment)
2012-05-21 23:59:49 Sent INSTEON "Thermostat Main Bedrooms" set heat setpoint to 54.0
2012-05-21 23:59:52 Received INSTEON "Thermostat Main Bedrooms" heat setpoint changed to 54.0
2012-05-21 23:59:53 Received INSTEON "Thermostat Main Bedrooms" heat setpoint changed to 54.0
2012-05-23 22:11:37 Error "Thermostat Main Bedrooms" set cool setpoint to 75.0; failed (checksum invalid)
2012-05-23 22:11:38 Sent INSTEON "Thermostat Main Bedrooms" set heat setpoint to 64.0
2012-05-23 22:11:42 Received INSTEON "GamPsgWy Master" on
2012-05-23 22:11:42 Received INSTEON "Backyard Big Lts Passageway Slave" on
2012-05-23 22:11:42 Trigger Outdoor Lts Back PsgWy On Timer
2012-05-23 22:11:43 Error "Thermostat MBR" set cool setpoint to 83.0; failed (checksum invalid)
2012-05-23 22:11:44 Error "Thermostat MBR" set heat setpoint to 59.0; failed (checksum invalid)
2012-05-23 22:11:45 Sent INSTEON "Backyard Big Lts Fam Rm Switch" on to 85
2012-05-23 22:11:45 Trigger Lights BackYard Variable
2012-05-23 22:11:45 Sent INSTEON "Backyard Big Lts Passageway Slave" on to 100
2012-05-23 22:11:46 Received INSTEON "Game Rm Front FP Lts" on
2012-05-23 22:11:46 Error "Thermostat MBR" set heat setpoint to 58.0; failed (checksum invalid)
2012-05-23 22:11:47 Sent INSTEON "Thermostat MBR" set cool setpoint to 82.0
2012-05-23 22:11:48 Sent INSTEON "Thermostat MBR" set heat setpoint to 57.0
2012-05-23 22:11:49 Sent INSTEON "Thermostat MBR" set cool setpoint to 81.0
2012-05-23 22:11:49 Sent INSTEON "Thermostat MBR" set heat setpoint to 56.0
2012-05-23 22:11:50 Sent INSTEON "Thermostat MBR" set cool setpoint to 80.0
2012-05-23 22:11:51 Received INSTEON "Thermostat MBR" cool setpoint changed to 80.0
2012-05-23 22:11:56 Received INSTEON "Thermostat MBR" heat setpoint changed to 55.0
2012-05-23 22:12:03 Error "Thermostat MBR" set heat setpoint to 55.0; send failed (no acknowledgment)
2012-05-23 22:12:04 Sent INSTEON "Thermostat MBR" set cool setpoint to 79.0
2012-05-23 22:12:04 Sent INSTEON "Thermostat MBR" set cool setpoint to 78.0
2012-05-23 22:12:06 Received INSTEON "Thermostat MBR" cool setpoint changed to 79.0
2012-05-23 22:12:11 Received INSTEON "Thermostat MBR" cool setpoint changed to 78.0
2012-05-23 22:12:18 Error "Thermostat MBR" set heat setpoint to 54.0; send failed (no acknowledgment)
2012-05-23 22:12:20 Received INSTEON "Thermostat MBR" cool setpoint changed to 77.0
2012-05-23 22:12:24 Received INSTEON "Thermostat MBR" on (button 1)
2012-05-23 22:12:24 Error "Thermostat MBR" set cool setpoint to 77.0; failed
2012-05-23 22:12:25 Error "Thermostat MBR" set heat setpoint to 53.0; failed (checksum invalid)
2012-05-23 22:12:25 Sent INSTEON "Thermostat MBR" set cool setpoint to 79.0
2012-05-23 22:12:26 Sent INSTEON "Thermostat MBR" set heat setpoint to 54.0
2012-05-23 22:12:28 Received INSTEON "Thermostat MBR" off (button 1)
2012-05-23 22:12:30 Received INSTEON "Thermostat MBR" cool setpoint changed to 79.0
2012-05-23 22:12:34 Received INSTEON "Thermostat MBR" heat setpoint changed to 54.0
2012-05-23 22:12:35 Sent INSTEON "Thermostat MBR" set cool setpoint to 78.0
2012-05-23 22:12:36 Sent INSTEON "Thermostat MBR" set heat setpoint to 53.0
2012-05-23 22:12:36 Sent INSTEON "Thermostat MBR" set heat setpoint to 52.0
2012-05-23 22:12:37 Sent INSTEON "Thermostat MBR" set cool setpoint to 77.0
2012-05-23 22:12:38 Error "Thermostat MBR" set heat setpoint to 51.0; failed (checksum invalid)
2012-05-23 22:12:40 Sent INSTEON "Thermostat MBR" set cool setpoint to 76.0
2012-05-23 22:12:41 Sent INSTEON "Thermostat MBR" set heat setpoint to 50.0
2012-05-23 22:12:42 Sent INSTEON "Thermostat MBR" set cool setpoint to 75.0
2012-05-23 22:12:43 Sent INSTEON "Thermostat MBR" set heat setpoint to 49.0
2012-05-23 22:12:44 Sent INSTEON "Thermostat MBR" set cool setpoint to 74.0
2012-05-23 22:12:45 Received INSTEON "Thermostat MBR" cool setpoint changed to 74.0
2012-05-23 22:12:49 Received INSTEON "Thermostat MBR" heat setpoint changed to 49.0
2012-05-23 22:12:50 Received INSTEON "Thermostat MBR" heat setpoint changed to 49.0
2012-05-23 22:13:09 Sent INSTEON "Thermostat Main Bedrooms" set cool setpoint to 74.0
2012-05-23 22:13:10 Sent INSTEON "Thermostat Main Bedrooms" set heat setpoint to 63.0
2012-05-23 22:13:11 Received INSTEON "Thermostat Main Bedrooms" cool setpoint changed to 74.0
2012-05-23 22:13:15 Received INSTEON "Thermostat Main Bedrooms" heat setpoint changed to 63.0
2012-05-23 22:13:17 Action Group aStatus Update A/C
2012-05-23 22:13:17 Sent INSTEON "Thermostat Fam Room" mode request (received: auto on)
2012-05-23 22:13:17 Sent INSTEON "Thermostat Fam Room" temperature request (received: 77.0)
2012-05-23 22:13:20 Sent INSTEON "Thermostat Fam Room" humidity request (received: 37.0)
2012-05-23 22:13:23 Sent INSTEON "Thermostat Fam Room" setpoint request (received: heat 67.0, cool 76.0)
2012-05-23 22:13:24 Sent INSTEON "Thermostat Fam Study" mode request (received: auto on)
2012-05-23 22:13:24 Sent INSTEON "Thermostat Fam Study" temperature request (received: 77.0)
2012-05-23 22:13:26 Sent INSTEON "Thermostat Fam Study" humidity request (received: 42.0)
2012-05-23 22:13:28 Sent INSTEON "Thermostat Fam Study" setpoint request (received: heat 67.0, cool 76.0)
2012-05-23 22:13:34 Error "Thermostat GameRm" mode request; send failed (no acknowledgment)
2012-05-23 22:13:40 Error "Thermostat GameRm" temperature request; send failed (no acknowledgment)
2012-05-23 22:13:47 Error "Thermostat GameRm" humidity request; send failed (no acknowledgment)
2012-05-23 22:13:53 Error "Thermostat GameRm" setpoint request; send failed (no acknowledgment)
2012-05-26 09:09:20 Sent INSTEON "Thermostat MBR" set cool setpoint to 77.0
2012-05-26 09:09:20 Sent INSTEON "Thermostat MBR" set heat setpoint to 66.0
2012-05-26 09:09:21 Sent INSTEON "Thermostat MBR" set cool setpoint to 78.0
2012-05-26 09:09:21 Sent INSTEON "Thermostat MBR" set heat setpoint to 67.0
2012-05-26 09:09:22 Sent INSTEON "Thermostat MBR" set cool setpoint to 79.0
2012-05-26 09:09:22 Sent INSTEON "Thermostat MBR" set heat setpoint to 68.0
2012-05-26 09:09:23 Received INSTEON "Thermostat Fam Room" humidity changed to 41.0
2012-05-26 09:09:24 Sent INSTEON "Thermostat MBR" set cool setpoint to 80.0
2012-05-26 09:09:24 Sent INSTEON "Thermostat MBR" set heat setpoint to 69.0
2012-05-26 09:09:25 Sent INSTEON "Thermostat MBR" set cool setpoint to 81.0
2012-05-26 09:09:25 Sent INSTEON "Thermostat MBR" set heat setpoint to 70.0
2012-05-26 09:09:27 Received INSTEON "Thermostat MBR" cool setpoint changed to 81.0
2012-05-26 09:09:28 Sent INSTEON "Thermostat MBR" set cool setpoint to 80.0
2012-05-26 09:09:29 Sent INSTEON "Thermostat MBR" set heat setpoint to 69.0
2012-05-26 09:09:29 Sent INSTEON "Thermostat MBR" set cool setpoint to 79.0
2012-05-26 09:09:31 Sent INSTEON "Thermostat MBR" set heat setpoint to 68.0
2012-05-26 09:09:31 Sent INSTEON "Thermostat MBR" set cool setpoint to 78.0
2012-05-26 09:09:31 Sent INSTEON "Thermostat MBR" set heat setpoint to 67.0
2012-05-26 09:09:32 Sent INSTEON "Thermostat MBR" set cool setpoint to 77.0
2012-05-26 09:09:32 Sent INSTEON "Thermostat MBR" set heat setpoint to 66.0
2012-05-26 09:09:33 Sent INSTEON "Thermostat MBR" set cool setpoint to 76.0
2012-05-26 09:09:34 Sent INSTEON "Thermostat MBR" set heat setpoint to 65.0
2012-05-26 09:09:38 Received INSTEON "Thermostat MBR" cool setpoint changed to 76.0
2012-05-26 09:09:40 Received INSTEON "Thermostat Fam Study" humidity changed to 44.0
2012-05-26 09:09:41 Sent INSTEON "Thermostat GameRm" set cool setpoint to 85.0
2012-05-26 09:09:41 Sent INSTEON "Thermostat GameRm" set heat setpoint to 61.0
2012-05-26 09:09:42 Sent INSTEON "Thermostat GameRm" set cool setpoint to 86.0
2012-05-26 09:09:42 Sent INSTEON "Thermostat GameRm" set heat setpoint to 62.0
2012-05-26 09:09:43 Sent INSTEON "Thermostat GameRm" set cool setpoint to 87.0
2012-05-26 09:09:43 Sent INSTEON "Thermostat GameRm" set heat setpoint to 63.0
2012-05-26 09:09:44 Sent INSTEON "Thermostat GameRm" set cool setpoint to 88.0
2012-05-26 09:09:44 Sent INSTEON "Thermostat GameRm" set heat setpoint to 64.0
2012-05-26 09:09:44 Sent INSTEON "Thermostat GameRm" set cool setpoint to 89.0
2012-05-26 09:09:45 Sent INSTEON "Thermostat GameRm" set heat setpoint to 65.0
2012-05-26 09:09:46 Received INSTEON "Thermostat GameRm" cool setpoint changed to 89.0
2012-05-26 09:09:49 Sent INSTEON "Thermostat GameRm" set cool setpoint to 88.0
2012-05-26 09:09:50 Sent INSTEON "Thermostat GameRm" set heat setpoint to 64.0
2012-05-26 09:09:50 Sent INSTEON "Thermostat GameRm" set cool setpoint to 87.0
2012-05-26 09:09:51 Sent INSTEON "Thermostat GameRm" set heat setpoint to 63.0
2012-05-26 09:09:51 Sent INSTEON "Thermostat GameRm" set cool setpoint to 86.0
2012-05-26 09:09:52 Sent INSTEON "Thermostat GameRm" set heat setpoint to 62.0
2012-05-26 09:09:52 Sent INSTEON "Thermostat GameRm" set cool setpoint to 85.0
2012-05-26 09:09:53 Sent INSTEON "Thermostat GameRm" set heat setpoint to 61.0
2012-05-26 09:09:53 Sent INSTEON "Thermostat GameRm" set cool setpoint to 84.0
2012-05-26 09:09:54 Sent INSTEON "Thermostat GameRm" set heat setpoint to 60.0
2012-05-26 09:09:57 Received INSTEON "Thermostat GameRm" cool setpoint changed to 84.0
2012-05-26 09:10:00 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 77.0
2012-05-26 09:10:00 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 66.0
2012-05-26 09:10:01 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 78.0
2012-05-26 09:10:01 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 67.0
2012-05-26 09:10:01 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 79.0
2012-05-26 09:10:02 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 68.0
2012-05-26 09:10:02 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 80.0
2012-05-26 09:10:03 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 69.0
2012-05-26 09:10:03 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 81.0
2012-05-26 09:10:04 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 70.0
2012-05-26 09:10:06 Received INSTEON "Thermostat Fam Study" off (button 1)
2012-05-26 09:10:07 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 80.0
2012-05-26 09:10:07 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 69.0
2012-05-26 09:10:07 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 79.0
2012-05-26 09:10:08 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 68.0
2012-05-26 09:10:08 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 78.0
2012-05-26 09:10:09 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 67.0
2012-05-26 09:10:09 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 77.0
2012-05-26 09:10:10 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 66.0
2012-05-26 09:10:10 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 65.0
2012-05-26 09:10:11 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 76.0
2012-05-26 09:10:16 Sent INSTEON "Thermostat Fam Room" set cool setpoint to 77.0
2012-05-26 09:10:16 Sent INSTEON "Thermostat Fam Room" set heat setpoint to 66.0
2012-05-26 09:10:17 Sent INSTEON "Thermostat Fam Room" set cool setpoint to 78.0
2012-05-26 09:10:17 Sent INSTEON "Thermostat Fam Room" set heat setpoint to 67.0
2012-05-26 09:10:18 Sent INSTEON "Thermostat Fam Room" set cool setpoint to 79.0
2012-05-26 09:10:18 Sent INSTEON "Thermostat Fam Room" set heat setpoint to 68.0
2012-05-26 09:10:19 Sent INSTEON "Thermostat Fam Room" set cool setpoint to 80.0
2012-05-26 09:10:19 Sent INSTEON "Thermostat Fam Room" set heat setpoint to 69.0
2012-05-26 09:10:20 Sent INSTEON "Thermostat Fam Room" set cool setpoint to 81.0
2012-05-26 09:10:20 Sent INSTEON "Thermostat Fam Room" set heat setpoint to 70.0
2012-05-26 09:10:21 Received INSTEON "Thermostat Fam Room" cool setpoint changed to 81.0
2012-05-26 09:10:22 Sent INSTEON "Thermostat Fam Room" set cool setpoint to 80.0
2012-05-26 09:10:22 Sent INSTEON "Thermostat Fam Room" set heat setpoint to 69.0
2012-05-26 09:10:23 Sent INSTEON "Thermostat Fam Room" set cool setpoint to 79.0
2012-05-26 09:10:23 Sent INSTEON "Thermostat Fam Room" set heat setpoint to 68.0
2012-05-26 09:10:24 Sent INSTEON "Thermostat Fam Room" set cool setpoint to 78.0
2012-05-26 09:10:24 Sent INSTEON "Thermostat Fam Room" set heat setpoint to 67.0
2012-05-26 09:10:25 Sent INSTEON "Thermostat Fam Room" set cool setpoint to 77.0
2012-05-26 09:10:25 Sent INSTEON "Thermostat Fam Room" set heat setpoint to 66.0
2012-05-26 09:10:26 Sent INSTEON "Thermostat Fam Room" set cool setpoint to 76.0
2012-05-26 09:10:26 Sent INSTEON "Thermostat Fam Room" set heat setpoint to 65.0
2012-05-26 09:10:30 Received INSTEON "Thermostat Fam Room" cool setpoint changed to 76.0
2012-05-26 09:10:31 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 77.0
2012-05-26 09:10:32 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 66.0
2012-05-26 09:10:32 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 78.0
2012-05-26 09:10:33 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 67.0
2012-05-26 09:10:33 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 79.0
2012-05-26 09:10:34 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 68.0
2012-05-26 09:10:34 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 69.0
2012-05-26 09:10:35 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 80.0
2012-05-26 09:10:35 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 81.0
2012-05-26 09:10:36 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 70.0
2012-05-26 09:10:37 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 80.0
2012-05-26 09:10:38 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 69.0
2012-05-26 09:10:38 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 79.0
2012-05-26 09:10:39 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 68.0
2012-05-26 09:10:39 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 67.0
2012-05-26 09:10:40 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 78.0
2012-05-26 09:10:40 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 77.0
2012-05-26 09:10:40 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 66.0
2012-05-26 09:10:41 Sent INSTEON "Thermostat Fam Study" set cool setpoint to 76.0
2012-05-26 09:10:41 Sent INSTEON "Thermostat Fam Study" set heat setpoint to 65.0
Lastly, do you have the polling of the thermostats turned off in the Device dialog? They don't need to be polled, and the polling requires several INSTEON commands which will also increase the odds of collisions.
4Jul, 2012 9:02:09 PM
Received INSTEON "Thermostat GameRm" temperature changed to 79.0
4Jul, 2012 9:03:17 PM
Received INSTEON "Thermostat GameRm" humidity changed to 28.0
Received INSTEON "Thermostat Fam Room" on (button 1)
Received INSTEON "Thermostat Fam Room" temperature changed to 78.0
4Jul, 2012 9:04:25 PM
Received INSTEON "Thermostat GameRm" humidity changed to 27.0
Received INSTEON "Thermostat Fam Room" humidity changed to 36.0
4Jul, 2012 9:05:32 PM
4Jul, 2012 9:06:38 PM
Received INSTEON "Thermostat Main Bedrooms" humidity changed to 38.0
Received INSTEON "Thermostat Fam Room" humidity changed to 35.0
4Jul, 2012 9:07:47 PM
Received INSTEON "Thermostat Main Bedrooms" humidity changed to 37.0
4Jul, 2012 9:08:53 PM
Received INSTEON "Thermostat Fam Room" humidity changed to 34.0
4Jul, 2012 9:11:08 PM
Received INSTEON "Thermostat Fam Room" temperature changed to 77.0
4Jul, 2012 9:11:28 PM
Received INSTEON "Thermostat GameRm" on (button 1)
4Jul, 2012 9:12:04 PM
Received INSTEON "Thermostat GameRm" temperature changed to 80.0
4Jul, 2012 9:13:18 PM
Received INSTEON "Thermostat Fam Room" humidity changed to 33.0
4Jul, 2012 9:14:15 PM
Received INSTEON "Thermostat GameRm" humidity changed to 29.0
4Jul, 2012 9:16:25 PM
Received INSTEON "Thermostat Main Bedrooms" on (button 1)
4Jul, 2012 9:17:31 PM
4Jul, 2012 9:18:33 PM
Received INSTEON "Thermostat Main Bedrooms" humidity changed to 40.0
4Jul, 2012 9:19:47 PM
