Insteon Wall Switch Stopped Controlling Load
Wed Mar 13, 2024 10:13 am
ckeyes888 offline
Have an odd switch behavior. I have an Insteon wall switch that seems to function/respond normally, from the switch and remotely but doesn’t turn the light on/off.
Curious if anyone has seen a switch fail in this way?
Carl
Wed Mar 13, 2024 12:52 pm
Korey offline
Re: Insteon Wall Switch Stopped Controlling Load
I have has a switch act like that once, and then I killed another without cutting the power and shorting the output :|
I moved said switches to a slave in a 3 way switch configuration and they have been working in this configuration for 10+ years.
Korey
Wed Mar 13, 2024 1:44 pm
ckeyes888 offline
Thanks. Guess I’ll just replace it. It’s in a 3 way setup as well.
Carl
