SwitchLinc dimmer possessed? toggling on/off by itself
Mon May 15, 2023 7:28 am
WagnerOne offline
I have a SwitchLinc dimmer (in-wall device) that recently began toggling on and off seemingly on its own.
My defined Indigo control of it hasn't changed and I see no mention of this toggling on and off in the Indigo logs.
The device has been in service 10+ years and just last week began doing this. I turned it on/off a few times on the physical switch and it stopped doing this, but this morning the thing is turning itself on and off like a switch possessed (I have no reason to think it's actually possessed).
Could this be anything other than a sign the device has reached it's service duration?
Mike
Mon May 15, 2023 7:32 am
WagnerOne offline
Re: SwitchLinc dimmer possessed? toggling on/off by itself
The bulbs in the ceiling light this switch controls are LED and about as old as the switch. Makes me recall these bulbs were like $30+ each back then.
Maybe if one or more of those are flaking out it could make the switch do this toggling?
This thought struck me as it only does this when there is load on it.
When I turn the switch off (via Indigo or physically) the on/off business ceases.
Mon May 15, 2023 8:56 am
Is it the switch actually toggling, or is it the light going on and off? Might be the bulbs flaking out and the switch is innocent.
Tue May 16, 2023 3:06 pm
WagnerOne offline
It's the switch. There are 6 bulbs in the overhead light it controls and they all go on/off in sync.
Guess it's probably time to replace this thing.
Thu May 25, 2023 9:24 am
WagnerOne offline
I've been researching a zwave switch to replace this thing recently.
Goofy thing is it has stopped doing this on/off business. Hasn't done it for a good week now. Hmmm
Sun May 28, 2023 1:03 pm
mundmc offline
I have encountered exactly this problem with insteon switch links (I assume you are using insteon). I'm not sure if it's from Charder on the powerlines or just indicative of the unit failing. Sorry I don't have a solution
Wed Aug 23, 2023 9:28 am
WagnerOne offline
As a followup, this INSTEON switch started cycling the lights it controls again with a vengeance, so it got yanked and replaced with a ZEN72 Z-wave switch.
