Replacing PowerLinc USB with a new one
Mon Apr 24, 2023 4:28 pm
webdeck offline
My PowerLinc USB was getting flaky, so when I saw Insteon start selling them again, I grabbed one.
I followed the process in the docs to replace it, but I am seeing a ton of errors (this is just a small sample - almost every non-battery-powered device is failing) when it is trying to to the batch syncing:
2023-04-24 15:13:45.075   PowerLinc   Linking - initializing remote device "Stair Lights (Main Floor Secondary)" (address 41.AC.44, firmware version 45)
2023-04-24 15:13:45.389   PowerLinc   Linking - adding PowerLinc to database of module 41.AC.44
2023-04-24 15:13:45.437   PowerLinc   Linking - entered discovery linking mode (240 seconds)
2023-04-24 15:13:46.444   PowerLinc   Linking - received module button pressed from 3E.FF.55
2023-04-24 15:13:54.036   PowerLinc   Linking - exited linking mode
2023-04-24 15:13:57.345   PowerLinc   Linking - initialize complete
2023-04-24 15:13:57.346   PowerLinc   Linking - syncing remote device "Stair Lights (Main Floor Secondary)" (address 41.AC.44, firmware version 45)
2023-04-24 15:13:57.665   PowerLinc   Linking - adding PowerLinc to database of module 41.AC.44
2023-04-24 15:13:57.713   PowerLinc   Linking - entered discovery linking mode (240 seconds)
2023-04-24 15:13:58.738   PowerLinc   Linking - received module button pressed from 41.AC.44
2023-04-24 15:14:06.423   PowerLinc   Linking - exited linking mode
2023-04-24 15:14:09.480   PowerLinc   Linking - syncing all links
2023-04-24 15:14:09.812   Error   failed to send command to module - PowerLinc not in module's database -- try the Define and Sync process in the device dialog
2023-04-24 15:14:09.812   Error   Linking - syncing failed
2023-04-24 15:14:09.813   PowerLinc   Linking
2023-04-24 15:14:09.813   PowerLinc   Linking - initializing remote device "Upper Stairs Lights" (address 41.BB.F5, firmware version 45)
2023-04-24 15:14:10.163   PowerLinc   Linking - adding PowerLinc to database of module 41.BB.F5
2023-04-24 15:14:10.211   PowerLinc   Linking - entered discovery linking mode (240 seconds)
2023-04-24 15:14:11.186   PowerLinc   Linking - received module button pressed from 41.AC.44
2023-04-24 15:14:18.873   PowerLinc   Linking - exited linking mode
2023-04-24 15:14:19.896   PowerLinc   Linking - initialize complete
2023-04-24 15:14:19.912   PowerLinc   Linking
2023-04-24 15:14:19.913   PowerLinc   Linking - syncing remote device "Upper Stairs Lights" (address 41.BB.F5, firmware version 45)
2023-04-24 15:14:20.231   PowerLinc   Linking - adding PowerLinc to database of module 41.BB.F5
2023-04-24 15:14:20.280   PowerLinc   Linking - entered discovery linking mode (240 seconds)
2023-04-24 15:14:21.302   PowerLinc   Linking - received module button pressed from 41.BB.F5
2023-04-24 15:14:30.016   PowerLinc   Linking - exited linking mode
2023-04-24 15:14:33.091   PowerLinc   Linking - syncing all links
2023-04-24 15:14:33.416   Error   failed to send command to module - PowerLinc not in module's database -- try the Define and Sync process in the device dialog
2023-04-24 15:14:33.416   Error   Linking - syncing failed
Mon Apr 24, 2023 5:43 pm
webdeck offline
Re: Replacing PowerLinc USB with a new one
Update: Subsequent sync picked up more devices correctly, but 28 devices continued to have this error. I had to go an define and sync each of those 28 devices individually.
Mon Apr 24, 2023 8:11 pm
What version of Indigo are you running?
Mon Apr 24, 2023 8:47 pm
webdeck offline
2022.2.2
After all the Define and Syncs were completed, everything appears to be in a good state. All the devices that had issues were dual-band dimmers, dual-band on/off switches, and dual-band keypads, but it wasn't all of them.
Mon Apr 24, 2023 8:51 pm
webdeck offline
I spoke too soon. It looks like I will have to Define and Sync every device.
   Schedule                        Sunset
   Sent INSTEON                    "PowerLinc Interface" on (scene 1 - Night Lights)
   Sent INSTEON                    "Stair Lights (Main Floor Secondary)" on (scene 1 cleanup)
   Sent INSTEON                    "Stair Lights" on (scene 1 cleanup)
   Sent INSTEON                    "Kitchen Cabinet Lights (Secondary)" on (scene 1 cleanup)
   Sent INSTEON                    "Kitchen Cabinet Lights" on (scene 1 cleanup)
   Sent INSTEON                    "Stair Lights (Upstairs Secondary)" on (scene 1 cleanup)
   Error                           "Game Room Keypad" on to 100; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
   Error                           "Front Door Lights" on to 26; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
   Sent INSTEON                    "PowerLinc Interface" on (scene 5 - Front Exterior)
   Sent INSTEON                    "Front Patio Lights (Secondary)" on (scene 5 cleanup)
   Sent INSTEON                    "Front Patio Lights" on (scene 5 cleanup)
   Schedule                        schedule "Sunset - Exterior" (delayed action)
   Sent INSTEON                    "Front Driveway Lights" on
   Sent INSTEON                    "PowerLinc Interface" on (scene 17 - Left Landscape Lights)
   Sent INSTEON                    "Left Landscape Lights" on (scene 17 cleanup)
   Sent INSTEON                    "Rear Patio Keypad" on (scene 17 cleanup)
   Sent INSTEON                    "PowerLinc Interface" on (scene 18 - Right Landscape Lights)
   Sent INSTEON                    "Right Landscape Lights" on (scene 18 cleanup)
   Sent INSTEON                    "Rear Patio Keypad" on (scene 18 cleanup)
Mon Apr 24, 2023 9:02 pm
webdeck offline
More details:
Original Sync:
2023-04-24 14:58:57.333   Application   Connected to PowerLinc 2413U interface on port usbserial-A10OSRW8
2023-04-24 14:58:57.333   Application   PowerLinc address 70.1A.20, firmware version 9.14
2023-04-24 14:59:01.695   PowerLinc   Linking - batch syncing all links for "Stair Lights (Main Floor Secondary)"
2023-04-24 14:59:01.695   PowerLinc   Linking - batch syncing all links for "Upper Stairs Lights"
2023-04-24 14:59:01.696   PowerLinc   Linking - batch syncing all links for "Lower Stairs Lights"
2023-04-24 14:59:01.696   PowerLinc   Linking - batch syncing all links for "Upstairs Hallway Lights"
2023-04-24 14:59:01.698   PowerLinc   Linking - batch syncing all links for "Foyer Lights"
2023-04-24 14:59:01.699   PowerLinc   Linking - batch syncing all links for "Lower Stairs Lights (Secondary)"
2023-04-24 14:59:01.699   PowerLinc   Linking - batch syncing all links for "Stair Lights (Upstairs Secondary)"
2023-04-24 14:59:01.699   PowerLinc   Linking - batch syncing all links for "Upper Stairs Lights (Secondary)"
2023-04-24 14:59:01.699   PowerLinc   Linking - batch syncing all links for "Upstairs Hallway Lights (Secondary)"
2023-04-24 14:59:01.699   PowerLinc   Linking - batch syncing all links for "Foyer Lights (Secondary)"
2023-04-24 14:59:01.699   PowerLinc   Linking - batch syncing all links for "Office Remote"
2023-04-24 14:59:01.699   PowerLinc   Linking - batch syncing all links for "Kitchen Cabinet Lights"
2023-04-24 14:59:01.699   PowerLinc   Linking - batch syncing all links for "Kitchen Cabinet Lights (Secondary)"
2023-04-24 14:59:01.700   PowerLinc   Linking - batch syncing all links for "Laundry Hallway Lights"
2023-04-24 14:59:01.700   PowerLinc   Linking - batch syncing all links for "Laundry Hallway Lights (Secondary)"
2023-04-24 14:59:01.700   PowerLinc   Linking - batch syncing all links for "Front Patio Lights"
2023-04-24 14:59:01.700   PowerLinc   Linking - batch syncing all links for "Front Patio Lights (Secondary)"
2023-04-24 14:59:01.700   PowerLinc   Linking - batch syncing all links for "Master Bedroom Right Reading Light"
2023-04-24 14:59:01.700   PowerLinc   Linking - batch syncing all links for "Master Bedroom Left Reading Light"
2023-04-24 14:59:01.700   PowerLinc   Linking - batch syncing all links for "Family Room Keypad"
2023-04-24 14:59:01.700   PowerLinc   Linking - batch syncing all links for "Ground Floor Hallway Lights"
2023-04-24 14:59:01.700   PowerLinc   Linking - batch syncing all links for "Ground Floor Bathroom Fan"
2023-04-24 14:59:01.700   PowerLinc   Linking - batch syncing all links for "Main Floor Bedroom Lights"
2023-04-24 14:59:01.700   PowerLinc   Linking - batch syncing all links for "Kitchen Island Lights"
2023-04-24 14:59:01.701   PowerLinc   Linking - batch syncing all links for "Kitchen Soffit Lights"
2023-04-24 14:59:01.701   PowerLinc   Linking - batch syncing all links for "Family Room Soffit Lights"
2023-04-24 14:59:01.701   PowerLinc   Linking - batch syncing all links for "Master Bedroom Keypad"
2023-04-24 14:59:01.701   PowerLinc   Linking - batch syncing all links for "Game Room Wall Sconces"
2023-04-24 14:59:01.701   PowerLinc   Linking - batch syncing all links for "Game Room Fireplace Spotlight"
2023-04-24 14:59:01.701   PowerLinc   Linking - batch syncing all links for "Game Room Soffit Lights"
2023-04-24 14:59:01.702   PowerLinc   Linking - batch syncing all links for "Game Room Keypad"
2023-04-24 14:59:01.702   PowerLinc   Linking - batch syncing all links for "Game Room Wall Lights"
2023-04-24 14:59:01.702   PowerLinc   Linking - batch syncing all links for "Dining Room Soffit Lights"
2023-04-24 14:59:01.704   PowerLinc   Linking - batch syncing all links for "Dining Room Spotlights"
2023-04-24 14:59:01.704   PowerLinc   Linking - batch syncing all links for "Dining Room Chandelier"
2023-04-24 14:59:01.704   PowerLinc   Linking - batch syncing all links for "Dining Room Chandelier (Secondary)"
2023-04-24 14:59:01.704   PowerLinc   Linking - batch syncing all links for "Dining Room Wall Lights"
2023-04-24 14:59:01.705   PowerLinc   Linking - batch syncing all links for "Kitchen Nook Chandelier"
2023-04-24 14:59:01.705   PowerLinc   Linking - batch syncing all links for "Shed Exterior Motion Light"
2023-04-24 14:59:01.705   PowerLinc   Linking - batch syncing all links for "Main Floor Bathroom Hall Lights"
2023-04-24 14:59:01.705   PowerLinc   Linking - batch syncing all links for "Family Room Fireplace Spotlight"
2023-04-24 14:59:01.705   PowerLinc   Linking - batch syncing all links for "Kitchen Bar Spotlight"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Samantha's Bedroom Lights"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Calvin's Bedroom Lights"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Holiday Lights - Kid's Christmas Tree"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Family Room Soffit Lights Switch"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Kitchen Sink Spotlight"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Stair Lights"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Downstairs Thermostat"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Upstairs Thermostat"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Rear Patio Keypad"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Shed Lights"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Left Landscape Lights"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Right Landscape Lights"
2023-04-24 14:59:01.706   PowerLinc   Linking - batch syncing all links for "Waterfall Outlet"
2023-04-24 14:59:01.707   PowerLinc   Linking - batch syncing all links for "Side Motion Floodlight"
2023-04-24 14:59:01.707   PowerLinc   Linking - batch syncing all links for "Holiday Lights - Front Lower"
2023-04-24 14:59:01.707   PowerLinc   Linking - batch syncing all links for "Shed String Lights"
2023-04-24 14:59:01.707   PowerLinc   Linking - batch syncing all links for "Mailbox Open/Close Sensor"
2023-04-24 14:59:01.707   PowerLinc   Linking - batch syncing all links for "Garage Door Open/Close Sensor"
2023-04-24 14:59:01.707   PowerLinc   Linking - batch syncing all links for "Office Hall Light"
2023-04-24 14:59:01.707   PowerLinc   Linking - batch syncing all links for "Office Keypad"
2023-04-24 14:59:01.707   PowerLinc   Linking - skipping batch sync for "Holiday Lights - Christmas Tree Water Level" (device communication is disabled)
2023-04-24 14:59:01.707   PowerLinc   Linking - batch syncing all links for "Holiday Lights - Fireplace"
2023-04-24 14:59:01.707   PowerLinc   Linking - batch syncing all links for "Garage Motion Sensor"
2023-04-24 14:59:01.707   PowerLinc   Linking - batch syncing all links for "Front Door Lights"
2023-04-24 14:59:01.707   PowerLinc   Linking - batch syncing all links for "Front Door Lights (Secondary)"
2023-04-24 14:59:01.708   PowerLinc   Linking - batch syncing all links for "Master Bedroom Closet Lights"
2023-04-24 14:59:01.708   PowerLinc   Linking - batch syncing all links for "Master Bathroom Light"
2023-04-24 14:59:01.708   PowerLinc   Linking - batch syncing all links for "Master Bathroom Mirror Lights"
2023-04-24 14:59:01.708   PowerLinc   Linking - batch syncing all links for "Upstairs Bathroom Light"
2023-04-24 14:59:01.708   PowerLinc   Linking - batch syncing all links for "Upstairs Bathroom Mirror Lights"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Laundry Room Lights"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Ground Floor Bathroom Lights"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Main Floor Bathroom Mirror Lights"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Main Floor Bathroom Light"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Main Floor Bedroom Closet Lights"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Front Driveway Lights"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Master Bedroom Bedside Keypad"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Master Bedroom Fan Keypad"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Family Room Fan Keypad"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Garage Lights"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Game Room Left Cabinet Outlet - Top"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Game Room Left Cabinet Outlet - Bottom"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Game Room Pinball Outlet"
2023-04-24 14:59:01.709   PowerLinc   Linking - batch syncing all links for "Game Room Christmas Tree Outlet"
2023-04-24 14:59:01.710   PowerLinc   Linking - batch syncing all links for "Game Room Right Cabinet Outlet - Top"
2023-04-24 14:59:01.710   PowerLinc   Linking - batch syncing all links for "Game Room Right Cabinet Outlet - Bottom"
2023-04-24 14:59:01.710   PowerLinc   Linking - batch syncing all links for "Family Room Holiday Outlet"
2023-04-24 14:59:01.710   PowerLinc   Linking - batch syncing all links for "Family Room Fireplace Outlet"
2023-04-24 14:59:01.710   PowerLinc   Linking - batch syncing all links for "Holiday Lights - Front Upper"
2023-04-24 14:59:01.710   PowerLinc   Linking - batch syncing all links for "Upstairs Hallway Outlet - Top"
2023-04-24 14:59:01.710   PowerLinc   Linking - batch syncing all links for "Upstairs Hallway Outlet - Bottom"
2023-04-24 14:59:01.710   PowerLinc   Linking - batch syncing all links for "Right Gate Open/Close Sensor"
2023-04-24 14:59:01.710   PowerLinc   Linking - batch syncing all links for "Left Gate Open/Close Sensor"
2023-04-24 14:59:01.712   PowerLinc   Linking - batch syncing all links for "Shed Door Open/Close Sensor"
2023-04-24 14:59:01.712   PowerLinc   Linking - batch sync started
2023-04-24 14:59:01.732   PowerLinc   Linking - syncing PowerLinc links (address 70.1A.20)
2023-04-24 14:59:01.732   PowerLinc   Linking - comparing local and powerlinc links
2023-04-24 14:59:01.751   PowerLinc   Linking - .  missing: remote link not found for persistent link 34.D1.BE group 01 (adding remote link)
2023-04-24 14:59:01.751   PowerLinc   Linking - .  missing: remote link not found for persistent link 38.A8.57 group 02 (adding remote link)
2023-04-24 14:59:01.751   PowerLinc   Linking - .  missing: remote link not found for persistent link 38.A8.57 group 04 (adding remote link)
2023-04-24 14:59:01.751   PowerLinc   Linking - .  missing: remote link not found for persistent link 38.A8.57 group 09 (adding remote link)
2023-04-24 14:59:01.751   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A4.23 group 02 (adding remote link)
2023-04-24 14:59:01.752   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A4.23 group 04 (adding remote link)
2023-04-24 14:59:01.752   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A4.23 group 09 (adding remote link)
2023-04-24 14:59:01.752   PowerLinc   Linking - .  missing: remote link not found for persistent link 3B.E5.28 group 09 (adding remote link)
2023-04-24 14:59:01.752   PowerLinc   Linking - .  missing: remote link not found for persistent link 0A.89.EF group 01 (adding remote link)
2023-04-24 14:59:01.752   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.2B.90 group 04 (adding remote link)
2023-04-24 14:59:01.752   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.2B.90 group 06 (adding remote link)
2023-04-24 14:59:01.752   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.2B.90 group 09 (adding remote link)
2023-04-24 14:59:01.752   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.38.C1 group 02 (adding remote link)
2023-04-24 14:59:01.752   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A6.FE group 02 (adding remote link)
2023-04-24 14:59:01.753   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.38.C1 group 04 (adding remote link)
2023-04-24 14:59:01.756   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A6.FE group 04 (adding remote link)
2023-04-24 14:59:01.756   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.38.C1 group 06 (adding remote link)
2023-04-24 14:59:01.756   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A6.FE group 06 (adding remote link)
2023-04-24 14:59:01.757   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.38.C1 group 09 (adding remote link)
2023-04-24 14:59:01.757   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A6.FE group 09 (adding remote link)
2023-04-24 14:59:01.757   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.38.C1 group 0E (adding remote link)
2023-04-24 14:59:01.757   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A6.FE group 0E (adding remote link)
2023-04-24 14:59:01.757   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AD.88 group 02 (adding remote link)
2023-04-24 14:59:01.757   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AD.88 group 06 (adding remote link)
2023-04-24 14:59:01.757   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AD.88 group 04 (adding remote link)
2023-04-24 14:59:01.757   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AD.88 group 09 (adding remote link)
2023-04-24 14:59:01.757   PowerLinc   Linking - .  missing: remote link not found for persistent link 0D.36.E3 group 01 (adding remote link)
2023-04-24 14:59:01.757   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.23.9A group 02 (adding remote link)
2023-04-24 14:59:01.757   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.23.9A group 04 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.23.9A group 06 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.23.9A group 09 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B3.5C group 02 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B3.5C group 04 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B3.5C group 09 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.E6 group 02 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.E6 group 04 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.E6 group 06 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.E6 group 09 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.E6 group 0E (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.B9 group 02 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.FC.4B group 02 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.FC.4B group 04 (adding remote link)
2023-04-24 14:59:01.758   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.B9 group 04 (adding remote link)
2023-04-24 14:59:01.759   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.FC.4B group 06 (adding remote link)
2023-04-24 14:59:01.759   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.FC.4B group 07 (adding remote link)
2023-04-24 14:59:01.759   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.B9 group 09 (adding remote link)
2023-04-24 14:59:01.759   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.0B.C3 group 02 (adding remote link)
2023-04-24 14:59:01.759   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.0B.C3 group 04 (adding remote link)
2023-04-24 14:59:01.759   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.0B.C3 group 06 (adding remote link)
2023-04-24 14:59:01.759   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.0B.C3 group 07 (adding remote link)
2023-04-24 14:59:01.759   PowerLinc   Linking - .  missing: remote link not found for persistent link 08.9D.B4 group 01 (adding remote link)
2023-04-24 14:59:01.759   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.D3 group 02 (adding remote link)
2023-04-24 14:59:01.759   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.D3 group 04 (adding remote link)
2023-04-24 14:59:01.759   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.D3 group 09 (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.DB group 02 (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.DB group 04 (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.DB group 06 (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.DB group 09 (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 0D.36.AA group 01 (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.B8 group 03 (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.B8 group 04 (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.C8.30 group 03 (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B8.A6 group 04 (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.C8.30 group 0A (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.C8.30 group 0B (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.C8.30 group 0C (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.C8.30 group 0D (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 2C.87.E6 group 02 (adding remote link)
2023-04-24 14:59:01.760   PowerLinc   Linking - .  missing: remote link not found for persistent link 2C.87.E6 group 04 (adding remote link)
2023-04-24 14:59:01.761   PowerLinc   Linking - .  missing: remote link not found for persistent link 3D.F9.20 group 02 (adding remote link)
2023-04-24 14:59:01.761   PowerLinc   Linking - .  missing: remote link not found for persistent link 3D.F9.20 group 04 (adding remote link)
2023-04-24 14:59:01.761   PowerLinc   Linking - .  missing: remote link not found for persistent link 3D.F9.20 group 06 (adding remote link)
2023-04-24 14:59:01.761   PowerLinc   Linking - .  missing: remote link not found for persistent link 3D.F9.20 group 09 (adding remote link)
2023-04-24 14:59:01.761   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3A.EA group 02 (adding remote link)
2023-04-24 14:59:01.761   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3A.EA group 04 (adding remote link)
2023-04-24 14:59:01.761   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AE.E8 group 05 (adding remote link)
2023-04-24 14:59:01.761   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3A.EA group 09 (adding remote link)
2023-04-24 14:59:01.761   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A8.50 group 02 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A8.50 group 04 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A8.50 group 09 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.24.02 group 02 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.24.02 group 04 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.24.02 group 06 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.24.02 group 09 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.2D.D4 group 02 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.2D.D4 group 04 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.2D.D4 group 09 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.2D.D4 group 0E (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A4.2E group 04 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BC.1D group 04 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AC.E7 group 02 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AC.E7 group 04 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AC.E7 group 06 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AC.E7 group 09 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B9.93 group 02 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B9.93 group 04 (adding remote link)
2023-04-24 14:59:01.762   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B9.93 group 09 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.10.A6 group 02 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.10.A6 group 04 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AB.B1 group 05 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.10.A6 group 06 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.10.A6 group 07 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.10.A6 group 09 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.8B group 02 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.8B group 04 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 3B.E5.28 group 01 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.8B group 09 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.8B group 0E (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 0D.D6.25 group 01 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.2F group 04 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.2F group 09 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.9A.A7 group 02 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.9A.A7 group 03 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.9A.A7 group 09 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B8.4A group 02 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B8.4A group 04 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B8.4A group 06 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B8.4A group 09 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B0.B1 group 02 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B0.B1 group 03 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B0.B1 group 04 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B0.B1 group 09 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.79.52 group 02 (adding remote link)
2023-04-24 14:59:01.763   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.79.52 group 04 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.79.52 group 09 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.F5 group 02 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.CB.95 group 02 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.F5 group 04 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.CB.95 group 08 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.CB.95 group 09 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.F5 group 09 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.CB.95 group 0E (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.CB.95 group 0F (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.A5 group 02 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.A5 group 04 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.98.D3 group 02 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.98.D3 group 04 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.98.D3 group 09 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AC.44 group 02 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AC.44 group 04 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 01.73.D0 group 01 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 15.F2.A5 group 01 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 39.70.C5 group 0A (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 39.70.C5 group 04 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.CB.95 group 10 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.E4.71 group 11 (adding remote link)
2023-04-24 14:59:01.764   PowerLinc   Linking - .  missing: remote link not found for persistent link 39.70.C5 group 11 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.E4.17 group 12 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 39.70.C5 group 12 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.E3.00 group 13 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 39.70.C5 group 13 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 14.89.FB group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 47.BE.F0 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 14.9E.1A group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 2A.97.75 group 04 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 3B.0F.99 group 04 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.2F group 14 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.B9 group 14 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.D3 group 14 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 19.8A.9E group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 21.CF.80 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 2A.97.75 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 3F.FA.80 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 2C.87.E6 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.C8.30 group 15 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 38.A8.57 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 39.70.C5 group 16 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 39.70.C5 group 17 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 39.70.C5 group 18 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 39.70.C5 group 19 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 39.70.C5 group 1A (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.2D.D4 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 36.9E.99 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 32.97.C2 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.2B.90 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 3D.F9.20 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.79.52 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 36.6C.65 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.E4.17 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.E4.71 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 34.D4.F2 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 39.70.C5 group 01 (adding remote link)
2023-04-24 14:59:01.765   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.E3.00 group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.0B.C3 group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.FC.4B group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.23.9A group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.24.02 group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.CB.95 group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.C8.30 group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.09.72 group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.09.68 group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.24.A5 group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.09.72 group 04 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.09.68 group 04 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.24.A5 group 04 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A8.50 group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 4D.3B.DB group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3B.1A group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.0B.C3 group 1B (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.FC.4B group 1B (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 4E.5B.BB group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 3B.0A.84 group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 36.63.2F group 01 (adding remote link)
2023-04-24 14:59:01.766   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.10.A6 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A4.23 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3A.EA group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B0.B1 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.A5 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.F5 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3B.A4 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.EC group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.EC group 04 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3B.A4 group 04 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.9A.A7 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A4.2E group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BC.1D group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AD.DE group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AB.B1 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AE.E8 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.36.6E group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.36.6E group 04 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3B.7D group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AE.4E group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3B.7D group 04 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AE.4E group 04 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.2F group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.D3 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B9.93 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.B9 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AC.44 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B3.5C group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 3B.25.FE group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.2B.E6 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.37.83 group 01 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.2B.E6 group 04 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.37.83 group 04 (adding remote link)
2023-04-24 14:59:01.767   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.98.D3 group 1C (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.37.83 group 1C (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.2B.E6 group 1C (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 38.A8.57 group 1D (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B9.93 group 1D (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 3C.2D.D4 group 1E (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.8B group 1E (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.38.C1 group 1E (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.E6 group 1E (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A6.FE group 1E (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B8.A6 group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AF.B8 group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AC.E7 group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.B8.4A group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.DB group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AD.88 group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BB.8B group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.E6 group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.38.C1 group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.37.1B group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.F4.7D group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.A6.FE group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.98.D3 group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3C.3E group 01 (adding remote link)
2023-04-24 14:59:01.768   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3C.3E group 04 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 3B.0F.99 group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.39.7F group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 42.16.10 group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 42.16.10 group 02 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 42.16.10 group 03 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.C8.30 group 04 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 42.16.10 group 04 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 42.16.10 group 09 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 42.16.10 group 0B (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 42.16.10 group 0C (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.E3.9A group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.E3.24 group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 43.62.4A group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 3E.FF.55 group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 37.10.A6 group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 45.7E.25 group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 3F.FA.80 group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 4E.5B.BB group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3F.3E group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.9A.A7 group 04 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 45.7E.25 group 04 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.3B.1A group 04 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 3B.E5.28 group 04 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 43.62.4A group 04 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 4D.44.26 group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.45.BC group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 4D.45.BC group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 4D.43.F6 group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 4D.44.8D group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 47.B6.77 group 01 (adding remote link)
2023-04-24 14:59:01.769   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.44.25 group 01 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 4D.44.25 group 01 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 47.BE.F0 group 01 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 2A.97.75 group 1F (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 2A.97.75 group 20 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 2A.97.75 group 21 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 42.16.10 group 22 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 43.62.4A group 22 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 42.16.10 group 23 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 43.62.4A group 23 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 42.16.10 group 24 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 43.62.4A group 24 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 43.62.4A group 25 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 42.16.10 group 26 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 43.62.4A group 26 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 4E.61.A3 group 01 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 4E.63.CD group 01 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 2D.C4.2B group 01 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.AC.44 group 01 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 2C.87.E6 group 01 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 40.FC.4B group 01 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.0B.C3 group 01 (adding remote link)
2023-04-24 14:59:01.770   PowerLinc   Linking - .  missing: remote link not found for persistent link 41.BA.A5 group 01 (adding remote link)
2023-04-24 14:59:01.774   PowerLinc   Linking - . .  found: link with duplicate address and group number 47.BE.F0 group 01 (deleting)
2023-04-24 14:59:01.775   PowerLinc   Linking - . .  found: link with duplicate address and group number 3F.FA.80 group 01 (deleting)
2023-04-24 14:59:01.775   PowerLinc   Linking - . .  found: link with duplicate address and group number 2C.87.E6 group 01 (deleting)
2023-04-24 14:59:01.775   PowerLinc   Linking - . .  found: link with duplicate address and group number 41.0B.C3 group 01 (deleting)
2023-04-24 14:59:01.775   PowerLinc   Linking - . .  found: link with duplicate address and group number 40.FC.4B group 01 (deleting)
2023-04-24 14:59:01.776   PowerLinc   Linking - . .  found: link with duplicate address and group number 4E.5B.BB group 01 (deleting)
2023-04-24 14:59:01.776   PowerLinc   Linking - . .  found: link with duplicate address and group number 37.10.A6 group 01 (deleting)
2023-04-24 14:59:01.776   PowerLinc   Linking - . .  found: link with duplicate address and group number 41.BA.A5 group 01 (deleting)
2023-04-24 14:59:01.777   PowerLinc   Linking - . .  found: link with duplicate address and group number 41.AC.44 group 01 (deleting)
2023-04-24 14:59:01.779   PowerLinc   Linking - compare complete
2023-04-24 14:59:01.779   PowerLinc   Linking - . . adding: INSTEON plc link to controller 34.D1.BE, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:01.844   PowerLinc   Linking - . . adding: INSTEON plc link to responder 38.A8.57, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:01.909   PowerLinc   Linking - . . adding: INSTEON plc link to responder 38.A8.57, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:01.972   PowerLinc   Linking - . . adding: INSTEON plc link to responder 38.A8.57, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:02.036   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A4.23, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:02.100   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A4.23, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:02.165   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A4.23, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:02.229   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3B.E5.28, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:02.309   PowerLinc   Linking - . . adding: INSTEON plc link to controller 0A.89.EF, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:02.372   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3C.2B.90, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:02.452   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3C.2B.90, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:02.516   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3C.2B.90, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:02.580   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.38.C1, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:02.660   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A6.FE, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:02.726   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.38.C1, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:02.804   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A6.FE, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:02.884   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.38.C1, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:02.964   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A6.FE, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:03.044   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.38.C1, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:03.126   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A6.FE, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:03.204   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.38.C1, flags 02, group 0E, data 03 1F 00
2023-04-24 14:59:03.284   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A6.FE, flags 02, group 0E, data 03 1F 00
2023-04-24 14:59:03.364   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AD.88, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:03.444   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AD.88, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:03.524   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AD.88, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:03.605   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AD.88, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:03.685   PowerLinc   Linking - . . adding: INSTEON plc link to controller 0D.36.E3, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:03.764   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.23.9A, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:03.844   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.23.9A, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:03.927   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.23.9A, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:04.005   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.23.9A, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:04.084   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B3.5C, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:04.164   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B3.5C, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:04.262   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B3.5C, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:04.356   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.E6, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:04.436   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.E6, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:04.532   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.E6, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:04.612   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.E6, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:04.709   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.E6, flags 02, group 0E, data 03 1F 00
2023-04-24 14:59:04.789   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AF.B9, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:04.885   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.FC.4B, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:04.964   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.FC.4B, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:05.060   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AF.B9, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:05.140   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.FC.4B, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:05.236   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.FC.4B, flags 02, group 07, data 03 1F 00
2023-04-24 14:59:05.332   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AF.B9, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:05.428   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.0B.C3, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:05.524   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.0B.C3, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:05.621   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.0B.C3, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:05.739   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.0B.C3, flags 02, group 07, data 03 1F 00
2023-04-24 14:59:05.828   PowerLinc   Linking - . . adding: INSTEON plc link to controller 08.9D.B4, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:05.924   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.D3, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:06.020   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.D3, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:06.118   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.D3, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:06.217   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.DB, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:06.311   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.DB, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:06.420   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.DB, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:06.516   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.DB, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:06.614   PowerLinc   Linking - . . adding: INSTEON plc link to controller 0D.36.AA, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:06.708   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AF.B8, flags 02, group 03, data 03 1F 00
2023-04-24 14:59:06.804   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AF.B8, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:06.916   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.C8.30, flags 02, group 03, data 03 1F 00
2023-04-24 14:59:07.012   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B8.A6, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:07.127   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.C8.30, flags 02, group 0A, data 03 1F 00
2023-04-24 14:59:07.238   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.C8.30, flags 02, group 0B, data 03 1F 00
2023-04-24 14:59:07.348   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.C8.30, flags 02, group 0C, data 03 1F 00
2023-04-24 14:59:07.460   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.C8.30, flags 02, group 0D, data 03 1F 00
2023-04-24 14:59:07.573   PowerLinc   Linking - . . adding: INSTEON plc link to responder 2C.87.E6, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:07.684   PowerLinc   Linking - . . adding: INSTEON plc link to responder 2C.87.E6, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:07.796   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3D.F9.20, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:07.908   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3D.F9.20, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:08.020   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3D.F9.20, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:08.132   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3D.F9.20, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:08.245   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.3A.EA, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:08.356   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.3A.EA, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:08.469   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AE.E8, flags 02, group 05, data 03 1F 00
2023-04-24 14:59:08.580   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.3A.EA, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:08.692   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A8.50, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:08.804   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A8.50, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:08.916   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A8.50, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:09.028   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.24.02, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:09.140   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.24.02, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:09.252   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.24.02, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:09.364   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.24.02, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:09.476   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3C.2D.D4, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:09.632   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3C.2D.D4, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:09.753   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3C.2D.D4, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:09.878   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3C.2D.D4, flags 02, group 0E, data 03 1F 00
2023-04-24 14:59:10.005   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A4.2E, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:10.132   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BC.1D, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:10.251   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AC.E7, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:10.377   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AC.E7, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:10.513   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AC.E7, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:10.644   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AC.E7, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:10.772   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B9.93, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:10.900   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B9.93, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:11.028   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B9.93, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:11.157   PowerLinc   Linking - . . adding: INSTEON plc link to responder 37.10.A6, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:11.284   PowerLinc   Linking - . . adding: INSTEON plc link to responder 37.10.A6, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:11.432   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AB.B1, flags 02, group 05, data 03 1F 00
2023-04-24 14:59:11.556   PowerLinc   Linking - . . adding: INSTEON plc link to responder 37.10.A6, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:11.691   PowerLinc   Linking - . . adding: INSTEON plc link to responder 37.10.A6, flags 02, group 07, data 03 1F 00
2023-04-24 14:59:11.828   PowerLinc   Linking - . . adding: INSTEON plc link to responder 37.10.A6, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:11.965   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.8B, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:12.100   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.8B, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:12.228   PowerLinc   Linking - . . adding: INSTEON plc link to controller 3B.E5.28, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:12.356   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.8B, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:12.486   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.8B, flags 02, group 0E, data 03 1F 00
2023-04-24 14:59:12.612   PowerLinc   Linking - . . adding: INSTEON plc link to controller 0D.D6.25, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:12.740   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AF.2F, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:12.868   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AF.2F, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:13.012   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.9A.A7, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:13.139   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.9A.A7, flags 02, group 03, data 03 1F 00
2023-04-24 14:59:13.268   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.9A.A7, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:13.412   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B8.4A, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:13.555   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B8.4A, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:13.683   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B8.4A, flags 02, group 06, data 03 1F 00
2023-04-24 14:59:13.829   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B8.4A, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:13.971   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B0.B1, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:14.115   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B0.B1, flags 02, group 03, data 03 1F 00
2023-04-24 14:59:14.259   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B0.B1, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:14.405   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B0.B1, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:14.547   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3C.79.52, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:14.691   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3C.79.52, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:14.836   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3C.79.52, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:14.980   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.F5, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:15.124   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.CB.95, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:15.268   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.F5, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:15.412   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.CB.95, flags 02, group 08, data 03 1F 00
2023-04-24 14:59:15.555   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.CB.95, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:15.699   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.F5, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:15.843   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.CB.95, flags 02, group 0E, data 03 1F 00
2023-04-24 14:59:15.987   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.CB.95, flags 02, group 0F, data 03 1F 00
2023-04-24 14:59:16.131   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.A5, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:16.291   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.A5, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:16.451   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.98.D3, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:16.595   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.98.D3, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:16.740   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.98.D3, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:16.899   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AC.44, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:17.059   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AC.44, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:17.219   PowerLinc   Linking - . . adding: INSTEON plc link to controller 01.73.D0, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:17.379   PowerLinc   Linking - . . adding: INSTEON plc link to controller 15.F2.A5, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:17.539   PowerLinc   Linking - . . adding: INSTEON plc link to responder 39.70.C5, flags 02, group 0A, data 03 1F 00
2023-04-24 14:59:17.699   PowerLinc   Linking - . . adding: INSTEON plc link to responder 39.70.C5, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:17.859   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.CB.95, flags 02, group 10, data 03 1F 00
2023-04-24 14:59:18.019   PowerLinc   Linking - . . adding: INSTEON plc link to responder 37.E4.71, flags 02, group 11, data 03 1F 00
2023-04-24 14:59:18.179   PowerLinc   Linking - . . adding: INSTEON plc link to responder 39.70.C5, flags 02, group 11, data 03 1F 00
2023-04-24 14:59:18.339   PowerLinc   Linking - . . adding: INSTEON plc link to responder 37.E4.17, flags 02, group 12, data 03 1F 00
2023-04-24 14:59:18.499   PowerLinc   Linking - . . adding: INSTEON plc link to responder 39.70.C5, flags 02, group 12, data 03 1F 00
2023-04-24 14:59:18.659   PowerLinc   Linking - . . adding: INSTEON plc link to responder 37.E3.00, flags 02, group 13, data 03 1F 00
2023-04-24 14:59:18.818   PowerLinc   Linking - . . adding: INSTEON plc link to responder 39.70.C5, flags 02, group 13, data 03 1F 00
2023-04-24 14:59:18.978   PowerLinc   Linking - . . adding: INSTEON plc link to controller 14.89.FB, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:19.142   PowerLinc   Linking - . . adding: INSTEON plc link to controller 14.9E.1A, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:19.298   PowerLinc   Linking - . . adding: INSTEON plc link to responder 2A.97.75, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:19.459   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3B.0F.99, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:19.618   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AF.2F, flags 02, group 14, data 03 1F 00
2023-04-24 14:59:19.779   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AF.B9, flags 02, group 14, data 03 1F 00
2023-04-24 14:59:19.940   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.D3, flags 02, group 14, data 03 1F 00
2023-04-24 14:59:20.114   PowerLinc   Linking - . . adding: INSTEON plc link to controller 19.8A.9E, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:20.291   PowerLinc   Linking - . . adding: INSTEON plc link to controller 21.CF.80, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:20.451   PowerLinc   Linking - . . adding: INSTEON plc link to controller 2A.97.75, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:20.612   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.C8.30, flags 02, group 15, data 03 1F 00
2023-04-24 14:59:20.771   PowerLinc   Linking - . . adding: INSTEON plc link to controller 38.A8.57, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:20.946   PowerLinc   Linking - . . adding: INSTEON plc link to responder 39.70.C5, flags 02, group 16, data 03 1F 00
2023-04-24 14:59:21.122   PowerLinc   Linking - . . adding: INSTEON plc link to responder 39.70.C5, flags 02, group 17, data 03 1F 00
2023-04-24 14:59:21.299   PowerLinc   Linking - . . adding: INSTEON plc link to responder 39.70.C5, flags 02, group 18, data 03 1F 00
2023-04-24 14:59:21.476   PowerLinc   Linking - . . adding: INSTEON plc link to responder 39.70.C5, flags 02, group 19, data 03 1F 00
2023-04-24 14:59:21.652   PowerLinc   Linking - . . adding: INSTEON plc link to responder 39.70.C5, flags 02, group 1A, data 03 1F 00
2023-04-24 14:59:21.827   PowerLinc   Linking - . . adding: INSTEON plc link to controller 3C.2D.D4, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:22.002   PowerLinc   Linking - . . adding: INSTEON plc link to controller 36.9E.99, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:22.178   PowerLinc   Linking - . . adding: INSTEON plc link to controller 32.97.C2, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:22.354   PowerLinc   Linking - . . adding: INSTEON plc link to controller 3C.2B.90, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:22.531   PowerLinc   Linking - . . adding: INSTEON plc link to controller 3D.F9.20, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:22.706   PowerLinc   Linking - . . adding: INSTEON plc link to controller 3C.79.52, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:22.883   PowerLinc   Linking - . . adding: INSTEON plc link to controller 36.6C.65, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:23.058   PowerLinc   Linking - . . adding: INSTEON plc link to controller 37.E4.17, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:23.236   PowerLinc   Linking - . . adding: INSTEON plc link to controller 37.E4.71, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:23.411   PowerLinc   Linking - . . adding: INSTEON plc link to controller 34.D4.F2, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:23.586   PowerLinc   Linking - . . adding: INSTEON plc link to controller 39.70.C5, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:23.762   PowerLinc   Linking - . . adding: INSTEON plc link to controller 37.E3.00, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:23.939   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.23.9A, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:24.115   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.24.02, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:24.291   PowerLinc   Linking - . . adding: INSTEON plc link to controller 40.CB.95, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:24.467   PowerLinc   Linking - . . adding: INSTEON plc link to controller 40.C8.30, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:24.643   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.09.72, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:24.818   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.09.68, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:24.994   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.24.A5, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:25.172   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.09.72, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:25.363   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.09.68, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:25.554   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.24.A5, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:25.749   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.A8.50, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:25.938   PowerLinc   Linking - . . adding: INSTEON plc link to controller 4D.3B.DB, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:26.130   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.3B.1A, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:26.322   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.0B.C3, flags 02, group 1B, data 03 1F 00
2023-04-24 14:59:26.514   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.FC.4B, flags 02, group 1B, data 03 1F 00
2023-04-24 14:59:26.706   PowerLinc   Linking - . . adding: INSTEON plc link to controller 3B.0A.84, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:26.898   PowerLinc   Linking - . . adding: INSTEON plc link to controller 36.63.2F, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:27.090   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.A4.23, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:27.282   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.3A.EA, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:27.476   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.B0.B1, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:27.666   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.BB.F5, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:27.858   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.3B.A4, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:28.050   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.BA.EC, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:28.243   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.EC, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:28.434   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.3B.A4, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:28.626   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.9A.A7, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:28.818   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.A4.2E, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:29.010   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.BC.1D, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:29.202   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.AD.DE, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:29.410   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.AB.B1, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:29.602   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.AE.E8, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:29.794   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.36.6E, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:30.030   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.36.6E, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:30.230   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.3B.7D, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:30.434   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.AE.4E, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:30.626   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.3B.7D, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:30.818   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AE.4E, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:31.026   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.AF.2F, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:31.234   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.BA.D3, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:31.444   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.B9.93, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:31.650   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.AF.B9, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:31.858   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.B3.5C, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:32.066   PowerLinc   Linking - . . adding: INSTEON plc link to controller 3B.25.FE, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:32.274   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.2B.E6, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:32.484   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.37.83, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:32.690   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.2B.E6, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:32.898   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.37.83, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:33.106   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.98.D3, flags 02, group 1C, data 03 1F 00
2023-04-24 14:59:33.314   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.37.83, flags 02, group 1C, data 03 1F 00
2023-04-24 14:59:33.522   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.2B.E6, flags 02, group 1C, data 03 1F 00
2023-04-24 14:59:33.733   PowerLinc   Linking - . . adding: INSTEON plc link to responder 38.A8.57, flags 02, group 1D, data 03 1F 00
2023-04-24 14:59:33.938   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.B9.93, flags 02, group 1D, data 03 1F 00
2023-04-24 14:59:34.146   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3C.2D.D4, flags 02, group 1E, data 03 1F 00
2023-04-24 14:59:34.354   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BB.8B, flags 02, group 1E, data 03 1F 00
2023-04-24 14:59:34.562   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.38.C1, flags 02, group 1E, data 03 1F 00
2023-04-24 14:59:34.770   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.E6, flags 02, group 1E, data 03 1F 00
2023-04-24 14:59:34.978   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.A6.FE, flags 02, group 1E, data 03 1F 00
2023-04-24 14:59:35.202   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.B8.A6, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:35.426   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.AF.B8, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:35.650   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.AC.E7, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:35.874   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.B8.4A, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:36.098   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.BB.DB, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:36.322   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.AD.88, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:36.546   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.BB.8B, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:36.770   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.BA.E6, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:36.994   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.38.C1, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:37.217   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.37.1B, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:37.441   PowerLinc   Linking - . . adding: INSTEON plc link to controller 40.F4.7D, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:37.665   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.A6.FE, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:37.889   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.98.D3, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:38.113   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.3C.3E, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:38.338   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.3C.3E, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:38.562   PowerLinc   Linking - . . adding: INSTEON plc link to controller 3B.0F.99, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:38.786   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.39.7F, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:39.009   PowerLinc   Linking - . . adding: INSTEON plc link to controller 42.16.10, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:39.238   PowerLinc   Linking - . . adding: INSTEON plc link to responder 42.16.10, flags 02, group 02, data 03 1F 00
2023-04-24 14:59:39.457   PowerLinc   Linking - . . adding: INSTEON plc link to responder 42.16.10, flags 02, group 03, data 03 1F 00
2023-04-24 14:59:39.697   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.C8.30, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:39.937   PowerLinc   Linking - . . adding: INSTEON plc link to responder 42.16.10, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:40.162   PowerLinc   Linking - . . adding: INSTEON plc link to responder 42.16.10, flags 02, group 09, data 03 1F 00
2023-04-24 14:59:40.386   PowerLinc   Linking - . . adding: INSTEON plc link to responder 42.16.10, flags 02, group 0B, data 03 1F 00
2023-04-24 14:59:40.609   PowerLinc   Linking - . . adding: INSTEON plc link to responder 42.16.10, flags 02, group 0C, data 03 1F 00
2023-04-24 14:59:40.849   PowerLinc   Linking - . . adding: INSTEON plc link to controller 37.E3.9A, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:41.089   PowerLinc   Linking - . . adding: INSTEON plc link to controller 37.E3.24, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:41.329   PowerLinc   Linking - . . adding: INSTEON plc link to controller 43.62.4A, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:41.554   PowerLinc   Linking - . . adding: INSTEON plc link to controller 3E.FF.55, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:41.793   PowerLinc   Linking - . . adding: INSTEON plc link to controller 37.10.A6, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:42.057   PowerLinc   Linking - . . adding: INSTEON plc link to controller 45.7E.25, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:42.313   PowerLinc   Linking - . . adding: INSTEON plc link to controller 3F.FA.80, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:42.560   PowerLinc   Linking - . . adding: INSTEON plc link to controller 4E.5B.BB, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:42.803   PowerLinc   Linking - . . adding: INSTEON plc link to controller 41.3F.3E, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:43.041   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.9A.A7, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:43.281   PowerLinc   Linking - . . adding: INSTEON plc link to responder 45.7E.25, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:43.520   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.3B.1A, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:43.760   PowerLinc   Linking - . . adding: INSTEON plc link to responder 3B.E5.28, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:44.000   PowerLinc   Linking - . . adding: INSTEON plc link to responder 43.62.4A, flags 02, group 04, data 03 1F 00
2023-04-24 14:59:44.240   PowerLinc   Linking - . . adding: INSTEON plc link to controller 4D.44.26, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:44.480   PowerLinc   Linking - . . adding: INSTEON plc link to controller 40.45.BC, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:44.721   PowerLinc   Linking - . . adding: INSTEON plc link to controller 4D.45.BC, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:44.961   PowerLinc   Linking - . . adding: INSTEON plc link to controller 4D.43.F6, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:45.216   PowerLinc   Linking - . . adding: INSTEON plc link to controller 4D.44.8D, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:45.456   PowerLinc   Linking - . . adding: INSTEON plc link to controller 47.B6.77, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:45.696   PowerLinc   Linking - . . adding: INSTEON plc link to controller 40.44.25, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:45.952   PowerLinc   Linking - . . adding: INSTEON plc link to controller 4D.44.25, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:46.208   PowerLinc   Linking - . . adding: INSTEON plc link to controller 47.BE.F0, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:46.448   PowerLinc   Linking - . . adding: INSTEON plc link to responder 2A.97.75, flags 02, group 1F, data 03 1F 00
2023-04-24 14:59:46.688   PowerLinc   Linking - . . adding: INSTEON plc link to responder 2A.97.75, flags 02, group 20, data 03 1F 00
2023-04-24 14:59:46.944   PowerLinc   Linking - . . adding: INSTEON plc link to responder 2A.97.75, flags 02, group 21, data 03 1F 00
2023-04-24 14:59:47.200   PowerLinc   Linking - . . adding: INSTEON plc link to responder 42.16.10, flags 02, group 22, data 03 1F 00
2023-04-24 14:59:47.440   PowerLinc   Linking - . . adding: INSTEON plc link to responder 43.62.4A, flags 02, group 22, data 03 1F 00
2023-04-24 14:59:47.696   PowerLinc   Linking - . . adding: INSTEON plc link to responder 42.16.10, flags 02, group 23, data 03 1F 00
2023-04-24 14:59:47.952   PowerLinc   Linking - . . adding: INSTEON plc link to responder 43.62.4A, flags 02, group 23, data 03 1F 00
2023-04-24 14:59:48.208   PowerLinc   Linking - . . adding: INSTEON plc link to responder 42.16.10, flags 02, group 24, data 03 1F 00
2023-04-24 14:59:48.464   PowerLinc   Linking - . . adding: INSTEON plc link to responder 43.62.4A, flags 02, group 24, data 03 1F 00
2023-04-24 14:59:48.720   PowerLinc   Linking - . . adding: INSTEON plc link to responder 43.62.4A, flags 02, group 25, data 03 1F 00
2023-04-24 14:59:48.976   PowerLinc   Linking - . . adding: INSTEON plc link to responder 42.16.10, flags 02, group 26, data 03 1F 00
2023-04-24 14:59:49.233   PowerLinc   Linking - . . adding: INSTEON plc link to responder 43.62.4A, flags 02, group 26, data 03 1F 00
2023-04-24 14:59:49.488   PowerLinc   Linking - . . adding: INSTEON plc link to controller 4E.61.A3, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:49.744   PowerLinc   Linking - . . adding: INSTEON plc link to controller 4E.63.CD, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:50.000   PowerLinc   Linking - . . adding: INSTEON plc link to controller 2D.C4.2B, flags 03, group 01, data 00 00 FF
2023-04-24 14:59:50.259   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.AC.44, flags 02, group 01, data 03 1F 00
2023-04-24 14:59:50.512   PowerLinc   Linking - . . adding: INSTEON plc link to responder 2C.87.E6, flags 02, group 01, data 03 1F 00
2023-04-24 14:59:50.768   PowerLinc   Linking - . . adding: INSTEON plc link to responder 40.FC.4B, flags 02, group 01, data 03 1F 00
2023-04-24 14:59:51.024   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.0B.C3, flags 02, group 01, data 03 1F 00
2023-04-24 14:59:51.282   PowerLinc   Linking - . . adding: INSTEON plc link to responder 41.BA.A5, flags 02, group 01, data 03 1F 00
2023-04-24 14:59:51.553   PowerLinc   Linking - sync complete
2023-04-24 14:59:51.554   PowerLinc   Linking - PowerLinc links updated
skipping a ton of log entries on that first sync to look at just one device in that first sync:
2023-04-24 15:41:56.339   PowerLinc   Linking
2023-04-24 15:41:56.341   PowerLinc   Linking - initializing remote device "Front Door Lights" (address 32.97.C2, firmware version 48)
2023-04-24 15:41:56.706   PowerLinc   Linking - adding PowerLinc to database of module 32.97.C2
2023-04-24 15:41:56.754   PowerLinc   Linking - entered discovery linking mode (240 seconds)
2023-04-24 15:41:57.680   PowerLinc   Linking - received module button pressed from 2A.97.75
2023-04-24 15:42:05.810   PowerLinc   Linking - exited linking mode
2023-04-24 15:42:09.516   PowerLinc   Linking - initialize complete
2023-04-24 15:42:09.516   PowerLinc   Linking - syncing remote device "Front Door Lights" (address 32.97.C2, firmware version 48)
2023-04-24 15:42:09.611   PowerLinc   Linking - adding PowerLinc to database of module 32.97.C2
2023-04-24 15:42:09.659   PowerLinc   Linking - entered discovery linking mode (240 seconds)
2023-04-24 15:42:11.051   PowerLinc   Linking - received module button pressed from 32.97.C2
2023-04-24 15:42:19.205   PowerLinc   Linking - exited linking mode
2023-04-24 15:42:22.271   PowerLinc   Linking - syncing all links
2023-04-24 15:42:22.662   Error   failed to send command to module - PowerLinc not in module's database -- try the Define and Sync process in the device dialog
2023-04-24 15:42:22.662   Error   Linking - syncing failed
Define and Sync of device:
   PowerLinc                       Linking - sending engine version request to 32.97.C2
   PowerLinc                       Linking - adding PowerLinc to module's database
   PowerLinc                       Linking - received engine version 02 from 32.97.C2
   PowerLinc                       Linking - sending id request for device information to 32.97.C2
   PowerLinc                       Linking - received id request response from 32.97.C2
   PowerLinc                       Linking - . . . read: default on brightness 100%, ramp rate duration 0.5 seconds
   PowerLinc                       Linking - device "Front Door Lights" properties updated
   PowerLinc                       Linking - . . . read: INSTEON dev link to responder 41.EF.64, flags EA, group 01, data 03 1F 00
   PowerLinc                       Linking - . removing: old PowerLinc address 41.EF.64 from device's database
   PowerLinc                       Linking - . . . read: INSTEON dev link to responder 70.1A.20, flags EA, group 00, data 03 1C 00
   PowerLinc                       Linking - . . . read: INSTEON dev link to responder 41.EF.64, flags EA, group 00, data 03 1C 00
   PowerLinc                       Linking - . . . read: INSTEON dev link to controller 41.AD.DE, flags A2, group 01, data FF 1C 01
   PowerLinc                       Linking - . . . read: INSTEON dev link to controller 41.EF.64, flags AA, group FE, data 00 1C 00
   PowerLinc                       Linking - . . . read: INSTEON dev link to controller 70.1A.20, flags AA, group FE, data 00 1C 00
   PowerLinc                       Linking - . . adding: PowerLinc responder for group 1 (replacing empty link at 0FF8)
   PowerLinc                       Linking - comparing local and remote links
   PowerLinc                       Linking - . .  match: remote link is identical to persistent link 41.AD.DE, flags A2, group 01
   PowerLinc                       Linking - device "Front Door Lights" links updated
What's interesting is that Indigo didn't think it needed to sync this device when I synced device links the second time. So I guess the second time didn't fix a bunch of items, it just ignored them. So I've got a very long list of items to define and sync... Sigh...
Fri Apr 28, 2023 11:43 am
Re: Replacing PowerLinc USB with a new one
Thanks for the details and log snippets. The problem is the modules won't allow Indigo to write links into them until the PowerLinc is added to the module. Indigo is trying to do that in both the re-Sync All cases and the Define & Sync individual module case. In this particular case it is failing during the Sync All case but the log isn't showing why. It looks like Indigo is sending the commands to add the PowerLinc as module in both cases. We'll investigate this some more and see if we can reproduce the problem.
Fri Apr 28, 2023 11:53 am
webdeck offline
The one thing I noticed in the log that looked strange is that it would get "received module button pressed" and the address would be for the previous item it was syncing, then it would repeat and show the address for the current item being synced. That seemed odd.
Fri Apr 28, 2023 4:21 pm
Agreed. Can you email me the log file for the day you replaced the PowerLinc?
Fri Apr 28, 2023 4:40 pm
webdeck offline
Email sent.
Thu Jun 22, 2023 3:17 pm
turtle offline
I just received my replacement PLM and was looking for the instructions for replacing it and found this thread - has there been any progress in the past couple of months?
Thu Jun 22, 2023 3:42 pm
The problem is configuration specific. Are you experiencing it as well?
Users browsing this forum: No registered users and 18 guests
