tdc wrote:I see how I can add a responder to for example a keypad, but I don't see how I can make that responder a scene.
A scene is just multiple links that all have the same group (or button) number. So if you add multiple responder links to the KeypadLinc and set them all to group/button #4, then when you press button #4 on the KeypadLinc all of those responders will respond (and thus are a scene).
tdc wrote:Only the other devices I've previously added, and one device that is called 'unknown device', uses data 254 31 0 are available.
Any INSTEON device that you have added which controls a load should be able to be added (SwitchLinc, LampLinc, ApplianceLinc, KeypadLinc). This presumes you have defined these devices in Indigo, of course.
tdc wrote:I tried to add the powerlink as a device (using the listed address from one of the controllers), but that never completes.
Yeah, don't do that.
You are trying to create a scene such that pressing KeypadLinc button #3 controls a few other modules directly, correct? If so, then no need to do anything with the PowerLinc.
tdc wrote:So I can only use a trigger action to set one of the scenes.
You can do it this way (by using a Trigger Action that then sends a PowerLinc Group scene), but it is an extra step. And note that Indigo always automatically adds the PowerLinc as a responder to every controlling module, so you can create Trigger Actions for any KeypadLinc button without doing anything but defining the KeypadLinc device in Indigo. The Links Management dialog doesn't show these links since they are not user editable.
tdc wrote:Unknown device: Would an X10 IR controller show up?
Nope, only INSTEON devices.
Regards,
Matt
