Manage Insteon Links - Not Editable / Not erasable
Tue Nov 29, 2022 7:05 pm
Venicenerd offline
My tenant told me one of the lights that's physically connected to my 4 button keypad keeps turning on randomly. So I selected the Keypad in Indigo, selected "Edit" and then "re-sync" Links just to make sure everything is synced correctly. This took a really long time. After it was done I noticed that I had a bunch of "not editable" and "not erasable" in the status section of the device:
Screenshot 2022-11-29 at 5.00.53 PM.jpg (223.96 KiB) Viewed 967 times
Does this mean there is something wrong with my keypad? Do I need to replace it? It's also the only keypad in my home that "beeps" when I press a button. All other keypads are quiet. Not sure if that means anything at all.
Any insight would be appreciated!
PS: I also noticed that the keypad was incorrectly configured as and "8-button" keypad even though it only has 6 buttons. I set it to "6-button" mode now and re-synced again but the "not editable/not erasable" status remains. It also shows back up as an 8-button keypad after I re-sync!
Thu Dec 08, 2022 2:25 pm
Re: Manage Insteon Links - Not Editable / Not erasable
Those might be old orphaned links to modules (or even a PowerLinc) you no longer have. You can delete them by holding down the OPTION key when you choose the menu item to open the link editor. You can also factory reset the module (per the steps in its manual) then re-sync it with Indigo, which should automatically write back out the persistent links you had previously created.
If the light is randomly turning on then the module might be starting to malfunction.
Users browsing this forum: No registered users and 21 guests
