Hey All-
I'm going to be installing a dimmer switch in my bathroom to control the lights, at the same time I was planning on replacing the switch that controls the bathroom exhaust fan at the same time. I have several insteon dimmer switches available (2477D), is using a dimmer for the exhaust fan a particularly good or bad idea?
This internet forum suggests that it is ok, but they don't mention insteon devices:
https://diy.stackexchange.com/questions ... ith-dimmer
I can obviously get a 2477S if needed, but I wanted to try this out for a bit to see if I wanted the control to be insteon/indigo powered, or if I wanted to install a dumb switch with a humidity sensor and timer...
Jason
