Insteon 2450 I/O Setup/Help
Fri Jan 11, 2019 5:58 pm
farberm offline
I am attempting to connect an Insteon 2450 I/O module to a Dakota Alert WR-3000 receiver,. The receiver has three terminals labeled NC, NO, and COM. The I/O Sensor has 6 pins ( 5V, GRD, Sense, NC, Com and NO) pins. I assumed that I would connect a wire from NO on the WR-3000 to the sense pin on the 2450, but indigo does not receive any indication that the WR-3000 was triggered. I do not see any ground on the receiver to connec a wire from ground to ground?
I am sure I am dong something wrong...
Fri Jan 11, 2019 7:00 pm
farberm offline
Re: Insteon 2450 I/O Setup/Help
Ok solved. Hooked up the Receiver NC to sense on 2450 and the receiver COM to GRD on 2450.
Fri Jan 11, 2019 7:20 pm
norcoscia offline
This should work assuming your have you transmitter and receiver paired and working. I drew it to relay number 4 but any relay from 2-4 will work, don’t hook it up to 12v output or it will damage the I/O module. Don’t forget to cycle the receiver off and on if you make any changes to anything on the receiver. The receiver doc is not very detailed but to be safe I would stay away from relay number 1 and the 12v output.
_______
Norm
Fri Jan 11, 2019 7:22 pm
norcoscia offline
Don’t forget to adjust you dip switches for the relay you decide to connect to.
_______
Norm
Fri Jan 11, 2019 7:43 pm
farberm offline
This is how I have it connnected. The only problem is that I have DIP switches 9 and 10 on so that means that it should send info over relay 1. Why did you suggest to stay away from Relay 1?
Fri Jan 11, 2019 7:52 pm
norcoscia offline
Relay number one is likely OK, but the documentation is so abrievated I could not be 110% sure the 12v is totally isolated from it. So the way you have it connected now do you hear the classical tone when the transmitter fires?
_______
Norm
Fri Jan 11, 2019 8:04 pm
norcoscia offline
Another test you can run is disconnect the two wires from the receiver and then touch the two wires together. You should get the signal from the I/O module at Indigo to see if that part is working properly.
_______
Norm
Fri Jan 11, 2019 8:07 pm
farberm offline
Yes I hear the classic time and indigo shows event as closed occurring. I can trigger others event so seems to be working fine as Ihave it. I talked with Dakota the other day and Ithink 12 v is separate from all relays 1-4
