Zero experience troubleshooting SwitchLinc Relay
Sat Oct 14, 2017 8:03 am
Different Computers offline
Last night I noticed the sole SwitchLinc Relay I have installed stopped responding to commands.
   Error                           "Foyer Lights" off; send failed (no acknowledgment)
Still works manually.
If it's in the On position, indicator lights are as normal.
In Off position, again as normal unless I send a command, then it blinks red.
What is there to do here? I confirmed it's not the PowerLinc because X10 devices controlled through that still work.
This is the ONLY Insteon device I have, and it has been working 100% since I installed it about 5 weeks ago.
Sat Oct 14, 2017 9:41 am
Re: Zero experience troubleshooting SwitchLinc Relay
Try factory resetting the SwitchLinc (per its manual) then re-sync it in Indigo.
Sat Oct 14, 2017 9:56 am
Weirdness: tried pulling the air gap for 10 seconds. 1st time it did nothing. 2nd time the reset happened in about 3 seconds instead of 10, as shown by the controlled lights turning on.
But no control from Indigo, however Indigo IS receiving status changes from the switch:
   Received INSTEON                "Foyer Lights" on
   Received INSTEON                "Foyer Lights" off
The manual says to be sure to remove any links for the switch--but this switch has no links. It just controls the light it's hard wired to.
I'll try removing it from Indigo and re-adding it.
Sat Oct 14, 2017 10:01 am
Put the switchlinc back in inclusion mode:
 PowerLinc                       Linking - syncing PowerLinc links (address 3C.4C.95)
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 46.CC.59, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: (not added -- probably already exists)
   PowerLinc                       Linking - sync complete
   PowerLinc                       Linking - PowerLinc links updated
   PowerLinc                       Linking - sending engine version request to 46.CC.59
   PowerLinc                       Linking - no response from device
That last line repeats over and over.
Sat Oct 14, 2017 10:08 am
I think the module might have malfunctioned.
However, are you sure the factory reset "took?" It is tricky to perform. Unless they've changed it in newer models you have to pull the LED pipe out wait several seconds, then push it all the way in to a depressed state and hold it there for 10+ seconds. The movement from the out state to the depressed state has to be fast and is difficult to perform. I've done it hundreds of times and still have problems with it.
Sat Oct 14, 2017 10:09 am
I'll give it another try, especially as the manual said 3 seconds pressed in.
OK, this time the switchlinc made a long tone, then the light turned on, which https://www.manualslib.com/manual/77587 ... tory+reset says is sign of successful reset.
Still no response.
Mon Oct 16, 2017 2:49 pm
Has anyone seen one of these fail in this way, where it sends notifications of state but won't respond to commands?
Tue Oct 17, 2017 10:08 am
Did you try to resync after this last successful factory reset?
Tue Oct 17, 2017 10:28 am
Yes. No response.
Tue Oct 17, 2017 11:52 am
Yeah, I'm with Matt that it's probably a failed switch then.
