4 scene mini remote
Tue Sep 26, 2017 6:42 pm
kelmk offline
4 scene mini remote
Hi I recently got one of these mini remotes and added it to Indigo no problem. I chose to link the remote to the switches using the insteon links rather than Indigo actions. However doing it this way indigo isn't changing the on/off statuses of the lights when using the remote. What is the best way to sync the light switch statuses when using the remote? Should I just add an action to get status from the light switches when a button press is detected or is there a better way?
Wed Sep 27, 2017 9:44 am
Re: 4 scene mini remote
How did you create the links between the remote and the device?
Wed Sep 27, 2017 12:48 pm
kelmk offline
By using the insteon instructions. Hold down the on button on the remote until it flashes and press the set button on the switch to connect to.
Wed Sep 27, 2017 10:33 pm
If you manually created the links then you need to re-sync the mini remote and the destination modules. Indigo will then know about the links you manually added and will be able to update its states and UI correctly. Note you'll need to wake up the remote for Indigo to sync with it.
