Naive about Fanlincs?
Tue Sep 05, 2017 7:00 pm
Different Computers offline
Having just installed my first Insteon Synchrolink to great success, I now wonder about Fanlincs. From a quick google search, all I see is "Compatible with all AC powered fans!" Forgive me if I'm dubious.
My fan is some sort of fancy modern brand whose wall switch has a built in slide controller with 10 steps for fan speed and a slide dimmer. Should I even try a Fanlinc? Is there a guide to brand compatibility somewhere?
Tue Sep 05, 2017 9:10 pm
Re: Naive about Fanlincs?
Check with smarthome. But my guess would be no. It works well with standard no-frills ceiling fans (I have 4 in my house with no issues).
Wed Sep 06, 2017 6:36 am
jalves offline
Despite Jay's suggestion above, I'd still give it a try. I suspect the fan itself is a fairly standard fan and the electronics in the switch are what's giving it the 10 speeds and dimmable light. Perhaps you could pull the switch out first and just connect the power straight through (ie bypass the switch) and see if the fan operates at its highest speed and lights on bright. If so, then go ahead with the fanlinc installation, combined with a 6-button wall switch.
Jeff
