Insteon interfaces/MODEMs
Posted: Sat Aug 05, 2017 12:02 am
My very first Insteon 2413U appears to have died. It seems alive, but the interface does not appear to be connected to Indigo. Its LED is solid pale green (as it should be) and the button does respond when it's pressed. I've order both types of interfaces, the dual band 2413U and the Insteon USB 'stick'. I have mostly dual band Insteon modules, so wouldn't they bridge the wired/wireless protocols or do I need the dual band Insteon interface to talk to non dual band (carrier current, only) modules?
I bought a stand alone Insteon hub just to keep my system going and to support my Amazon Dots. Indigo is still going and my Z-Stick is fine. Everything is working as usual, except that the Insteon devices are on their own and I obviously can't see them in Indigo. I once thought about keeping an extra 2413U around, since it is the single point of failure for most of my modules and since I can buy modules locally at the big box stores. None of them stock the Insteon USB interfaces, just the hubs.
