2421 TriggerLinc Issue
Posted:
Mon Jul 17, 2017 8:27 am
by qcvictor
I meet trouble for including my 2421 in Indigo, on 4 devices 2 fails but when I push the set button, I can see it in the log !
- Code: Select all
Jul 17, 2017, 10:23:15 AM
Received INSTEON 14.8E.97 on (button 1)
I tried several factory reset on the 2421 without success !
How I can flush it from the powerlinc ?
Any clue?
Re: 2421 TriggerLinc Issue
Posted:
Mon Jul 17, 2017 8:46 am
by jay (support)
Copy/paste the lines from the Event Log window when you try to do the Define and Sync on the device. Note that you'll have to keep it awake for syncing to work correctly - press and hold the set button on it for several seconds before doing the sync.
[MODERATOR NOTE] moved to the Insteon forum.
Posted:
Mon Jul 17, 2017 10:19 am
by qcvictor
Hi Jay
The battery is brand new, during the sync he ask me to wake up device, but he is already in link mode....
- Code: Select all
Jul 17, 2017, 12:08:35 PM
PowerLinc Linking - entered discovery linking mode (240 seconds)
Jul 17, 2017, 12:09:17 PM
PowerLinc Linking - syncing PowerLinc links (address 20.F4.B4)
PowerLinc Linking - . . adding: INSTEON plc link to controller 14.8E.97, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . adding: (not added -- probably already exists)
PowerLinc Linking - sync complete
PowerLinc Linking - PowerLinc links updated
PowerLinc Linking - sending engine version request to 14.8E.97
PowerLinc Linking - no response from device
PowerLinc Linking - received engine version 01 from 14.8E.97
PowerLinc Linking - sending id request for device information to 14.8E.97
Received INSTEON 14.8E.97 on (button 2)
PowerLinc Linking - received id request response from 14.8E.97
PowerLinc Linking - initializing remote device "new device 2" (address 14.8E.97, firmware version 28)
Jul 17, 2017, 12:11:12 PM
Received INSTEON 14.8E.97 off (button 2)
Jul 17, 2017, 12:11:29 PM
Jul 17, 2017, 12:12:23 PM
PowerLinc Linking - initialize complete
PowerLinc Linking - syncing remote device "new device 2" (address 14.8E.97, firmware version 28)
Jul 17, 2017, 12:12:57 PM
Received INSTEON "Motion Garage Ouside" on (button 1)
Jul 17, 2017, 12:13:45 PM
PowerLinc Linking - syncing all links
Jul 17, 2017, 12:14:03 PM
Received INSTEON "Motion Garage Ouside" off (button 1)
Jul 17, 2017, 12:14:44 PM
Error failed to fetch data from remote module
Error Linking - syncing failed; remote device might be asleep
Error linking failed
Jul 17, 2017, 12:15:48 PM
Jul 17, 2017, 12:16:08 PM
PowerLinc Linking - exited linking mode
Posted:
Mon Jul 17, 2017 10:49 am
by jay (support)
There's a problem with communication between the PowerLinc and the TriggerLinc - note how many times the PowerLinc had to request the engine version information from the device before it responded. Same with the device type. After that it was hit or miss until it finally just stopped responding. My guess is that it's just going back to sleep - this was an issue with the early TriggerLincs.
Just to eliminate potential distance issues, make sure the TriggerLinc is physically close to the PowerLinc. Remove the battery and wait for 30 seconds. Insert the battery and immediately begin the sync process (inserting the battery may cause it to stay awake a bit longer). If you start seeing repeated messages in the Event Log, or if it stops doing anything before the sync is finished, tap the set button. You may have to do that multiple times during the sync process to keep it awake long enough for the sync to finish.
Posted:
Mon Jul 17, 2017 11:37 am
by qcvictor
Thank You Jay, got it working after unplug/plug the powerlinc, so now I'm looking for get battery status !
Posted:
Mon Jul 17, 2017 1:37 pm
by jay (support)
AFAIK, no Insteon device reports the actual battery status, though some will send a group ON when the battery gets low. Those reports, however, are fairly unreliable.
