Insteon Low Voltage Contact Closure
Fri May 12, 2017 8:56 am
captcurrent offline
I had this working around back as a sensor on my mailbox.... For some reason it stopped working
From trouble shooting I had sort of decided that it was the basis 2450 that died as Indigo couldn't communicate with it.
I want through my extras. Found one that Indigo could synch with.
The trouble is in bench testing it (just using two wires going to the GND and SENSE. I am getting no change is status whether I short the wires or not
I am assuming tha I am screwing up the device settings.... any suggestions??
Fri May 12, 2017 9:16 am
Re: Insteon Low Voltage Contact Closure
I'm assuming you're talking about an I/O Linc. When you touch the two wires together, is the green LED coming on?
[MODERATOR NOTE] Moved to the Insteon forum.
Fri May 12, 2017 9:45 am
captcurrent offline
Re: Insteon Low Voltage Contact Closure SOLVED
It was not. so tried Anita I/O unit and this was the green light comes on when shorted and unit shows closed
when not closed the white led comes on and it show open
All is good in this part of the I/O world. just a couple more units for recycling
thanks for quick response
