ventstar 1700 interface glitch?
Tue May 02, 2017 2:39 pm
dtich offline
hey guys, i have a ventstar that has been running well for some years, however, after a recent update - not sure which one - the heat status icon is always on and the mode is always returning heat even when it's off or cooling at the time. not sure if there's a tweak i needed to do at some upgrade, but i have changed nothing and this started about 6 months ago and i can't figure it out.
any thoughts? thanks!
the attached scrnshot was taken while the system was cooling, fan and compressor.
Screen Shot 2017-05-02 at 1.32.01 PM.png (450.52 KiB) Viewed 1828 times
Tue May 02, 2017 4:05 pm
Re: ventstar 1700 interface glitch?
Try a resync - the equipment state only sends updates to the last controller it was synced with so if that link gets lost you won't see updates. Hopefully just doing a resync will reset that link.
Tue May 02, 2017 4:09 pm
dtich offline
thx jay. have done, couple times. not changing it.
should i pull the ventstar interface and replug it? not sure if that will jiggle anything free...
Tue May 02, 2017 4:12 pm
The equipment states cannot be polled from Indigo, so if Indigo missed the last "heater is off" command then the only way to get it refreshed (in the Indigo UI) is to cycle the furnace so it turns ON then OFF again.
Wed May 03, 2017 8:35 pm
dtich offline
ahhh! so if i turn the heat on and then off it'll update that variable properly??
will try.
thanks!
Wed May 03, 2017 9:48 pm
dtich offline
that did the trick, matt. can't believe i lived with that for 6 months without trying the heat on idea... d'oh.
thanks!
