I have an 8-key keypad, and button #3 (and only button #3) is not sending insteon commands. When I press it, the LED behind button 3 turns off and on as expected. But the greet light under the set button doesn't blink like it does when I press other buttons. Also, the Indigo log does not indicate that Button #3 was pressed (I can see all other button presses as expected).
I tried pulling the air gap switch for ten seconds, no help.
Then I tried doing a factory reset. Pulled the air gap out, waited ten seconds, pushed and held the set button in until keypad beeped a long beep. I released the set buttons, the keypad LEDs came on (the ones that were supposed to be on), but the keypad never made the <beep beep> sounds as described in the manual's instructions on the factory reset. Also, Button #3 is still not sending commands (though its LED continues to turn on and off as expected).
Any help would be appreciated!!!!
