DS18B20 Temp sensor with EZIO8SA
Tue Jan 10, 2017 5:22 pm
akimball offline
I've spent serious time for a week now trying to get my 1-wire DS18B20 sensor to wrk with my ezio8sa. Pretty sure of my wiring and I'm using the 'powered' mode. Thought that maybe a pull-up might be needed on the data wire but I chatted with the smartenit people who said that was not required.
I have the sensor enabled in the device. I write a schedule to read the value every 10 seconds (for now). Usually the value is either 32-F but sometimes it's or 118-F.
I've tried wiring it twice now....measured for power....my measurement from RJ-12 pins 1 to 2 yields 3.28V. From pins 1 to pin 4 it reads 3.28V. Pin 1 is power, pins 2 and 4 are ground. Pin 3 is data.
Any ideas?
I have 2 of these ezio8sa's....both have the same issue.
-Al
Tue Jan 10, 2017 6:08 pm
Re: DS18B20 Temp sensor with EZIO8SA
[MODERATOR NOTE] moved to the Insteon forum
Tue Jan 10, 2017 6:12 pm
akimball offline
One addition thought going through my head, I read somewhere that ds18b20's may behave different from different manufactures. Would be interested to know which manufactures have been proven to work with an ezio8sa.
-Al
Wed Jan 11, 2017 5:51 pm
akimball offline
No luck. I poll the 1-wire input every 10 seconds, place the sensor value into a variable which I watch. It reads 32F or 118F.....usually 32Farenhight. Don't know what to do next. The log shows it reading the ezio8sa....and returning the mentioned values. Maybe I should try it unpowered.
-Al
Wed Jan 11, 2017 9:26 pm
You might try posting on this forum thread. It is really old, but the original poster might get an email notification and offer some suggestions.
Wed Jan 11, 2017 10:36 pm
akimball offline
Thanks. I've ordered additional sensors from a different source...I read that these sensors are prone to counterfeit market shenanigans. If the replacements don't work I'll post over there. Not much hope.
-Al
