- Posted on
Sun Feb 05, 2017 10:03 am
arwatson2000
offline
Attached in an event log.
A few comments:
* I thought this was wireless, therefore it shouldn't matter about an extension cord or how near it is to the USB - computer link?
* I have hard-wired it in (i.e. no batteries) so it is always on and should not be going to sleep and placed it 5 feet away from a wireless access point that manages normally and continually a number of other insteon devices - and still it shows no temp or humidity as you can see
* i changed the polling of the device to every 5 minutes and still no luck
* right now it does not show any temp / humidity - this time I linked the thermostat and software it has never shown the temp or humidity BUT I can change the mode between heat and cool and auto using the software. Strange.
So, hmmmmmmmmm..
Do you know if other people have enabled these devices to work? At this point I have tried 2 devices in 2 houses with parallel systems without success.
Once in a blue moon it will register a temperature. Frankly, I think the thermostat may still be going to sleep on me. Even though it is plugged in with no batteries and the display always shows an accurate temperature and humidity. The thermostat screen never goes to sleep.
********** EVENT LOG **********
(** Andrew note - this is the initial link between Indigo 7 to the wireless thermostat**)
Feb 5, 2017, 10:33:32 AM
PowerLinc Linking - received id request response from 39.3F.7E
PowerLinc Linking - initializing remote device "new device" (address 39.3F.7E, firmware version 0E)
PowerLinc Linking - . reading: settings and date/time
PowerLinc Linking - . updating: date/time to 10:34 AM
PowerLinc Linking - initialize complete
PowerLinc Linking - syncing remote device "new device" (address 39.3F.7E, firmware version 0E)
PowerLinc Linking - syncing all links
PowerLinc Linking - . . . read: INSTEON dev link to controller 3C.4B.8C, flags A2, group FE, data 3C 50 50
PowerLinc Linking - . . . read: INSTEON dev link to responder 3C.4B.8C, flags E2, group 01, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 3C.4B.8C, flags E2, group 02, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 3C.4B.8C, flags E2, group 03, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 3C.4B.8C, flags E2, group 04, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 3C.4B.8C, flags E2, group EF, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to controller 14.FA.7F, flags A2, group 01, data 03 1F 46
PowerLinc Linking - . . . read: INSTEON dev link to responder 3C.4A.C5, flags E2, group 01, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 3C.4A.C5, flags E2, group 02, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 3C.4A.C5, flags E2, group 03, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 3C.4A.C5, flags E2, group 04, data 00 52 3E
PowerLinc Linking - . . . read: INSTEON dev link to responder 3C.4A.C5, flags E2, group EF, data 00 52 3E
PowerLinc Linking - . . found: PowerLinc responder for group 1
PowerLinc Linking - . . found: PowerLinc responder for group 2
PowerLinc Linking - . . found: PowerLinc responder for group 3
PowerLinc Linking - . . found: PowerLinc responder for group 4
PowerLinc Linking - . . found: PowerLinc responder for group 239
PowerLinc Linking - . enabling: status change broadcasting
PowerLinc Linking - comparing local and remote links
PowerLinc Linking - compare complete
PowerLinc Linking - sync complete
PowerLinc Linking - device 39.3F.7E links updated
Feb 5, 2017, 10:36:04 AM
PowerLinc Linking - exited linking mode
Sent INSTEON "Temp" mode request (received: all off)
Sent INSTEON "Temp" temperature request (received: 0.0)
Sent INSTEON "Temp" humidity request (received: 0.0)
Sent INSTEON "Temp" setpoint request (bad value - ignored)
Feb 5, 2017, 10:40:13 AM
Sent INSTEON "Temp" turn heat on
Sent INSTEON "Temp" turn fan always on
Feb 5, 2017, 10:40:42 AM
Sent INSTEON "Temp" turn cool on
(** Andrew note - when I send status request the Indigo software shows “mode off” even though the wireless thermostat shows “heat”. The “heat” mode was set by the Indigo 7 software**)
(** What Indigo 7 software shows **)
Feb 5, 2017, 10:53:57 AM
Sent INSTEON "Temp" turn auto on
Sent INSTEON "Temp" turn fan auto on
- Screen Shot 2017-02-05 at 10.46.08 AM.png (24.14 KiB) Viewed 4280 times
