Indigo fails with multiple responders with the same node ID
Mon Nov 21, 2016 2:30 am
jeremyhu offline
I have two 6 button keypads which I'd like to keep in sync. Specifically:
Master On on either -> All button lights turn on for both keypads
Master Off on either -> All button lights turn off for both keypads
3 on either -> Button light 3 turns on for both keypads
4 on either -> Button light 4 turns on for both keypads
5 on either -> Button light 5 turns on for both keypads
6 on either -> Button light 6 turns on for both keypads
This is trivial to do with the units themselves, but it seems to be impossible to do with Indigo. The UI allows it to be configured this way, but it fails upon starting to sync. When syncing, only these get synced over:
Button 1 -> Button 1
Button 1 -> Button 3
Button 3 -> Button 3
Button 4 -> Button 4
Button 5 -> Button 5
Button 6 -> Button 6
Interestingly, the 1->3 links will only shows up in the "Link to Controller Device" section of the "Manage INSTEON Device Links" window, so there's apparently a UI bug there in addition to the functionality bug of not being able to configure this from Indigo.
I gave up on using Indigo for this and decided to try and program it manually between the devices. It worked great. I then decided to refresh the links in Indigo, and it blew away all my hard work (leaving just the links mentioned above). Indigo logs all the links and then deletes the ones I made myself:
PowerLinc Linking - initializing remote device "6-Button Upper Hallway" (address 33.DC.80, firmware version 43)
PowerLinc Linking - . reading: configuration settings
PowerLinc Linking - . . . read: configuration settings 00, keypad in 6 button mode
PowerLinc Linking - . . . read: backlight brightness 10%
PowerLinc Linking - . . . read: default on brightness 100%, ramp rate duration 0.5 seconds
PowerLinc Linking - initialize complete
PowerLinc Linking - device "6-Button Upper Hallway" properties updated
PowerLinc Linking - syncing remote device "6-Button Upper Hallway" (address 33.DC.80, firmware version 43)
PowerLinc Linking - syncing all links
PowerLinc Linking - . . . read: INSTEON dev link to controller 24.12.B3, flags AA, group FE, data 00 1C 00
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags F2, group 01, data 03 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags E2, group 02, data 03 1F 02
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags F2, group 03, data 03 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags F2, group 04, data 03 1F 04
Received INSTEON "Office Lights" on
Received INSTEON "Office Lights" off
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags F2, group 05, data 03 1F 05
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags F2, group 06, data 03 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags E2, group 07, data 03 1F 07
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags E2, group 08, data 03 1F 08
PowerLinc Linking - . . . read: INSTEON dev link to controller 38.12.9B, flags A2, group 01, data FF 1F 04
PowerLinc Linking - . . . read: INSTEON dev link to responder 38.12.9B, flags E2, group 01, data 03 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 38.12.9B, flags E2, group 04, data 03 1F 04
PowerLinc Linking - . . . read: INSTEON dev link to responder 38.12.A1, flags E2, group 05, data 03 1C 05
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.67.BC, flags E2, group 01, data 03 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 38.12.A1, flags E2, group 01, data 03 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 38.08.4F, flags E2, group 03, data 03 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.D7.FB, flags A2, group 01, data FF 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to controller 38.08.4F, flags AA, group 01, data FF 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.D7.FB, flags E2, group 01, data 03 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 38.08.4F, flags A2, group 01, data FF 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to responder 38.08.4F, flags E2, group 01, data 03 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.D7.FB, flags AA, group 06, data FF 1C 06
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.D7.FB, flags E2, group 06, data 03 1C 06
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.D7.FB, flags AA, group 03, data FF 1C 03
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.D7.FB, flags E2, group 03, data 03 1C 03
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.D7.FB, flags E2, group 04, data 03 1C 04
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.D7.FB, flags AA, group 01, data FF 1C 04
PowerLinc Linking - . . . read: INSTEON dev link to controller 38.12.A1, flags AA, group 01, data FF 1C 05
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.67.BC, flags E2, group 06, data 03 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to controller 24.67.BC, flags A2, group 01, data FF 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.D7.FB, flags AA, group 01, data FF 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.D7.FB, flags E2, group 05, data 03 1C 05
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.D7.FB, flags AA, group 04, data FF 1C 04
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.D7.FB, flags AA, group 05, data FF 1C 05
PowerLinc Linking - . . . read: INSTEON dev link to responder 38.08.A8, flags E2, group 06, data 03 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to controller 38.08.A8, flags A2, group 01, data FF 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to responder 38.08.A8, flags E2, group 01, data 03 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.D7.FB, flags AA, group 01, data FF 1C 05
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.D7.FB, flags AA, group 01, data FF 1C 06
PowerLinc Linking - . . found: PowerLinc responder for group 1
PowerLinc Linking - . . found: PowerLinc responder for group 2
PowerLinc Linking - . . found: PowerLinc responder for group 3
PowerLinc Linking - . . found: PowerLinc responder for group 4
PowerLinc Linking - . . found: PowerLinc responder for group 5
PowerLinc Linking - . . found: PowerLinc responder for group 6
PowerLinc Linking - . . found: PowerLinc responder for group 7
PowerLinc Linking - . . found: PowerLinc responder for group 8
PowerLinc Linking - comparing local and remote links
PowerLinc Linking - . . match: remote link is identical to persistent link 38.12.9B, flags A2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 38.12.9B, flags E2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 38.12.9B, flags E2, group 04
PowerLinc Linking - . . match: remote link is identical to persistent link 38.12.A1, flags E2, group 05
PowerLinc Linking - . . match: remote link is identical to persistent link 24.67.BC, flags E2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 38.08.4F, flags E2, group 03
PowerLinc Linking - . . match: remote link is identical to persistent link 33.D7.FB, flags A2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 38.08.4F, flags AA, group 01
PowerLinc Linking - . mismatch: remote link differs from persistent link 33.D7.FB, flags E2, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 38.08.4F, flags A2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 38.08.4F, flags E2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 33.D7.FB, flags AA, group 06
PowerLinc Linking - . . match: remote link is identical to persistent link 33.D7.FB, flags E2, group 06
PowerLinc Linking - . . match: remote link is identical to persistent link 33.D7.FB, flags AA, group 03
PowerLinc Linking - . . match: remote link is identical to persistent link 33.D7.FB, flags E2, group 03
PowerLinc Linking - . . match: remote link is identical to persistent link 33.D7.FB, flags E2, group 04
PowerLinc Linking - . . match: remote link is identical to persistent link 38.12.A1, flags AA, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 24.67.BC, flags E2, group 06
PowerLinc Linking - . . match: remote link is identical to persistent link 24.67.BC, flags A2, group 01
PowerLinc Linking - . mismatch: remote link differs from persistent link 33.D7.FB, flags AA, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 33.D7.FB, flags E2, group 05
PowerLinc Linking - . . match: remote link is identical to persistent link 33.D7.FB, flags AA, group 04
PowerLinc Linking - . . match: remote link is identical to persistent link 33.D7.FB, flags AA, group 05
PowerLinc Linking - . . match: remote link is identical to persistent link 38.08.A8, flags E2, group 06
PowerLinc Linking - . . match: remote link is identical to persistent link 38.08.A8, flags A2, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 38.08.A8, flags E2, group 01
PowerLinc Linking - . missing: remote link not found for persistent link 38.12.A1 group 01 (adding remote link)
PowerLinc Linking - . . found: link with duplicate address and group number 38.12.A1 group 01 (deleting remote link)
PowerLinc Linking - . . found: link with duplicate address and group number 33.D7.FB group 01 (deleting remote link)
PowerLinc Linking - compare complete
PowerLinc Linking - . deleting: INSTEON dev link to responder 38.12.A1, flags E2, group 01, data 03 1C 01
PowerLinc Linking - . changing: INSTEON dev link to responder 33.D7.FB, flags E2, group 01, data 03 1C 01
PowerLinc Linking - . . . . to: INSTEON dev link to responder 33.D7.FB, flags E2, group 01, data 03 1F 01
PowerLinc Linking - . changing: INSTEON dev link to controller 33.D7.FB, flags AA, group 01, data FF 1C 04
PowerLinc Linking - . . . . to: INSTEON dev link to controller 33.D7.FB, flags AA, group 01, data FF 1C 01
PowerLinc Linking - . deleting: INSTEON dev link to controller 33.D7.FB, flags AA, group 01, data FF 1C 01
PowerLinc Linking - . deleting: INSTEON dev link to controller 33.D7.FB, flags AA, group 01, data FF 1C 05
PowerLinc Linking - . deleting: INSTEON dev link to controller 33.D7.FB, flags AA, group 01, data FF 1C 06
PowerLinc Linking - . . adding: INSTEON dev link to responder 38.12.A1, flags EA, group 01, data 03 1C 01
PowerLinc Linking - sync complete
PowerLinc Linking - device "6-Button Upper Hallway" links updated
Nov 20, 2016, 23:52:45
PowerLinc Linking - syncing PowerLinc links (address 24.12.B3)
PowerLinc Linking - . . adding: INSTEON plc link to controller 33.D7.FB, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . adding: (not added -- probably already exists)
PowerLinc Linking - PowerLinc links updated
PowerLinc Linking - initializing remote device "6-Button Lower Hallway" (address 33.D7.FB, firmware version 43)
PowerLinc Linking - syncing remote device "6-Button Lower Hallway" (address 33.D7.FB, firmware version 43)
PowerLinc Linking - device "6-Button Lower Hallway" properties updated
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.DC.80, flags E2, group 01, data 03 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.DC.80, flags A2, group 01, data FF 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to controller 38.08.A8, flags AA, group 01, data FF 1C 06
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.DC.80, flags E2, group 06, data 03 1C 06
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.DC.80, flags AA, group 06, data FF 1C 06
PowerLinc Linking - . . . read: INSTEON dev link to controller 38.08.4F, flags AA, group 01, data FF 1C 03
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.DC.80, flags E2, group 03, data 03 1C 03
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.DC.80, flags AA, group 03, data FF 1C 03
PowerLinc Linking - . . . read: INSTEON dev link to controller 38.12.9B, flags AA, group 01, data FF 1C 04
PowerLinc Linking - . . . read: INSTEON dev link to responder 38.12.9B, flags E2, group 04, data 03 1C 04
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.DC.80, flags AA, group 04, data FF 1C 04
PowerLinc Linking - . . . read: INSTEON dev link to responder 38.12.9B, flags E2, group 01, data 03 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.DC.80, flags AA, group 01, data FF 1C 04
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.DC.80, flags AA, group 05, data FF 1C 05
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.DC.80, flags AA, group 01, data FF 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 38.08.4F, flags E2, group 03, data 03 1C 03
PowerLinc Linking - . . . read: INSTEON dev link to controller 24.12.B3, flags AA, group FE, data FE 1C 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags EA, group 01, data 03 1F 01
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags EA, group 03, data 03 1F 03
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags EA, group 04, data 03 1F 04
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags EA, group 05, data 03 1F 05
PowerLinc Linking - . . . read: INSTEON dev link to responder 24.12.B3, flags EA, group 06, data 03 1F 06
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.DC.80, flags E2, group 04, data 03 1C 04
PowerLinc Linking - . . . read: INSTEON dev link to responder 33.DC.80, flags E2, group 05, data 03 1C 05
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.DC.80, flags AA, group 01, data FF 1C 05
PowerLinc Linking - . . . read: INSTEON dev link to controller 33.DC.80, flags AA, group 01, data FF 1C 06
PowerLinc Linking - . . match: remote link is identical to persistent link 33.DC.80, flags E2, group 06
PowerLinc Linking - . . match: remote link is identical to persistent link 33.DC.80, flags AA, group 06
PowerLinc Linking - . . match: remote link is identical to persistent link 33.DC.80, flags E2, group 03
PowerLinc Linking - . . match: remote link is identical to persistent link 33.DC.80, flags AA, group 03
PowerLinc Linking - . . match: remote link is identical to persistent link 38.12.9B, flags AA, group 01
PowerLinc Linking - . . match: remote link is identical to persistent link 33.DC.80, flags AA, group 04
PowerLinc Linking - . . match: remote link is identical to persistent link 33.DC.80, flags AA, group 05
PowerLinc Linking - . mismatch: remote link differs from persistent link 33.DC.80, flags AA, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 33.DC.80, flags E2, group 04
PowerLinc Linking - . . match: remote link is identical to persistent link 33.DC.80, flags E2, group 05
PowerLinc Linking - . . match: remote link is identical to persistent link 38.12.A1, flags E2, group 01
PowerLinc Linking - . mismatch: remote link differs from persistent link 33.DC.80, flags E2, group 01 (changing remote link)
PowerLinc Linking - . . match: remote link is identical to persistent link 33.DC.80, flags A2, group 01
PowerLinc Linking - . . found: link with duplicate address and group number 33.DC.80 group 01 (deleting remote link)
PowerLinc Linking - . changing: INSTEON dev link to responder 33.DC.80, flags E2, group 01, data 03 1C 01
PowerLinc Linking - . . . . to: INSTEON dev link to responder 33.DC.80, flags E2, group 01, data 03 1F 01
PowerLinc Linking - . changing: INSTEON dev link to controller 33.DC.80, flags AA, group 01, data FF 1C 04
PowerLinc Linking - . . . . to: INSTEON dev link to controller 33.DC.80, flags AA, group 01, data FF 1C 01
PowerLinc Linking - . deleting: INSTEON dev link to controller 33.DC.80, flags AA, group 01, data FF 1C 01
PowerLinc Linking - . deleting: INSTEON dev link to controller 33.DC.80, flags AA, group 01, data FF 1C 05
PowerLinc Linking - . deleting: INSTEON dev link to controller 33.DC.80, flags AA, group 01, data FF 1C 06
PowerLinc Linking - device "6-Button Lower Hallway" links updated
Please fix this data-loss issue with Indigo.
Please fix the UI bug that is resulting in the 1->3 links only appearing in "Link to Controller Device" sections and not "Link to Responder Device" sections
Mon Nov 21, 2016 3:04 am
jeremyhu offline
Re: Indigo fails with multiple responders with the same node
The issue persists even if I don't make the links persistent in Indigo. Indigo misinterprets them as duplicate because it only considers the address and group. Here's from a sync without any persistence flags set:
Mon Nov 21, 2016 11:09 am
You are correct that Indigo gets confused when there are multiple links from one module targeting multiple endpoints (LEDs, load) on another module. This is on our request/bug list to look into.
Mon Nov 28, 2016 10:42 pm
jeremyhu offline
It's not just that Indigo gets confused by this. Indigo actually messes up the configurations when it is syncing =(.
Sat Mar 16, 2019 1:52 am
jeremyhu offline
Can you provide an update on when you might be able to address this (or at least update Indigo to not mess up the links setup manually)? I see no reason to pay for an Indigo update until this functionality is available and will gladly pay for it when it is.
Thanks.
Sat Mar 16, 2019 3:34 pm
It is on the feature request / bug fix list, but won't be in the next release. I don't have a time estimate – we rarely provide estimates for changes except critical fixes or functionality that is in an upcoming release we feel comfortable discussing.
I agree it needs to be fixed, but because how Indigo handles links changes to address the problem are complicated and prone to introduce problems. That is, this isn't a couple of hour tweak but a several day task.
Fri Mar 22, 2024 11:58 pm
jeremyhu offline
It's been quite a few years now. I'd absolutley love to see this fixed. I haven't updated from 2022.x but I certainly would if this issue were addressed. Is there any hope this will get addressed? If the UI isn't going to support these configurations, could we at least prevent the data loss?
Sat Mar 23, 2024 10:37 am
Korey offline
+1!
Korey
Sun Mar 24, 2024 1:05 pm
I'm going to be perfectly honest with you guys: barring a big resurgence in Insteon interest, we will continue to avoid making any substantial changes to the Insteon interface (adding device definitions is less risky and we do want to add as much support for new devices as we deem safe). The code for this interface is large and quite complex (the API for Insteon management is an extremely low-level binary protocol and often not consistent between devices); any time we touch that code we risk breaking it in unforeseen ways and we judge that stability for the interface is the highest priority.
Also, demand is quite low on this one, as illustrated by the low post rate on this topic and among our other support avenues.
Mon Mar 25, 2024 5:43 am
Grognard offline
I was going to add a +1 as someone who still has a fair amount of INSTEON gear in my setup, but I suspected that it was a low priority.
While the answer is a bit of a disappointment, I definitely appreciate Jay’s honesty as I plan my how to replace my network of INSTEON wall keypads with something acceptable to SWMBO.
Users browsing this forum: No registered users and 18 guests
