EZIO8SA, EZIO2X4, EZIO8T support in Indigo
Mon Oct 15, 2007 7:33 am
Cosmuk offline
(No subject)
I have been using the DS18B20 temperature sensors on
the EZIO8SA and the EZIO8T.
I poll the status on both to update the temperature on my control page
every 15 min.
For some reason they stop working every night between 3 and 5 AM and give readings of 0 and 491.
The only way, so far, to get them back is to unplug & re sync them.
Skype : cosmuk
Mon Oct 15, 2007 1:40 pm
bobeast offline
(No subject)
Interesting. I'm having a similar problem with my EZSnsRF. It works fine for a while and then just stops responding to devices. When I unplug/replug, it starts working fine again.
It was actually only working for 3 or 4 triggers, but I sent it into SimpleHomeNet who upgraded the firmware, resulting in the current behavior.
I wonder is there is some common problem in the firmware for these devices causing this. I've taken to cycling its power through an Icon switch every so often, but that is obviously a hack.
Choose to chance the rapids.
Dare to dance the tide.
Mon Oct 15, 2007 1:44 pm
Cosmuk offline
(No subject)
it's only with the temp sensor on the 8 SA & T models
My SnsRF has not locked up
I am testing to see if its a polling issue
Skype : cosmuk
Mon Oct 15, 2007 6:28 pm
gregjsmith offline
(No subject)
I'm a little confused on how the EZIOxx devices work with one wire. If I hook up a temp or humidity sensor, can I just stick those values in a variable?
Mon Oct 15, 2007 6:32 pm
Cosmuk offline
(No subject)
As Far as the DS18B20, Matts already done that for you in the
EZIO xx device setup
Skype : cosmuk
Mon Oct 15, 2007 7:13 pm
gregjsmith offline
(No subject)
What about devices other than the DS18B20? Can i connect multiple 1-wire devices and Indigo will recognize all of them?
Mon Oct 15, 2007 7:23 pm
(No subject)
I believe the EZIOxxx currently only support a single DS18B20 sensor.
Matt
Mon Oct 15, 2007 7:28 pm
(No subject)
This is definitely odd. I wonder why it happens during that time window.
Do you have to re-sync to get it working, or just unplug the EZIO and plug it back in?
Would be interesting to not poll during that time period to see if it still locks up. If it does, then don't poll at all for a day and see if it still locks up.
Matt
Mon Oct 15, 2007 7:44 pm
Cosmuk offline
(No subject)
I have to do both unplug and re sync
then I re- select 1 wire sensor
It generally takes 2 status updates
before I receive the correct temp data
Skype : cosmuk
Mon Oct 15, 2007 7:56 pm
(No subject)
Do you get any errors in the Event Log when it isn't working, or does it just return the wrong temp values?
Mon Oct 15, 2007 8:05 pm
Cosmuk offline
(No subject)
Just the wrong temp values everything else seems operational
Skype : cosmuk
Mon Oct 15, 2007 8:55 pm
(No subject)
Have you posted about this on the SimpleHomeNet forum (or emailed them)? It sounds like it is getting confused, but I don't know why/how.
Matt
Mon Oct 15, 2007 8:59 pm
Cosmuk offline
(No subject)
Yes I did
Skype : cosmuk
Mon Oct 15, 2007 9:02 pm
(No subject)
Once you hear from them, let me know what they say.
Thu Oct 25, 2007 1:43 pm
mjew offline
(No subject)
Cosmuk wrote:
The EZSnsRF works like a charm so far
(1 WMT-3000 motion sensor)
Would any of the people who have gotten their EZSnsRF devices to work be willing to share even more detail and/or tips about how they did that?
(Beyond the brief information shared in this thread already...)
- Matthew
Page 4 of 10 1, 2, 3, 4, 5, 6, 7 ... 10
