It's unclear on Insteon's website, but can I forgo the Insteon hub if I have Indigo and an Access Point to convert the RF signals to PowerLine?
matt (support) wrote:Instead of the INSTEON Hub Indigo uses the USB PowerLinc (2413U, 2412U, or 2448A7) to communicate with INSTEON modules. So the Hub won't help Indigo at all.
The AccessPoint RF is used to help bridge the 2 110V power legs and extend the range of the network. But they may not be needed. A dual-band LampLinc (or even dual-band SwitchLinc) will serve the same purpose, presuming it can be plugged into an outlet on the correct circuit.
CraigM wrote:Just wondering, could this sensor be used in reverse to trigger a water-fill for a fountain?
Wet = good
Dry = bad, need more water [turn on irrigation valve]
Is the sensor rated for exterior use?
Could the sensing portion of the base withstand always being in water?
hamw wrote:CraigM wrote:Just wondering, could this sensor be used in reverse to trigger a water-fill for a fountain?
Wet = good
Just wondering if you ever got this figured out, or came up with another solution?
Users browsing this forum: No registered users and 20 guests
