Ok, as you predicted, no funktion, here are the new log. Sent two command to the TV channel down and volume down.
15 Feb 2017, 16:57:42
Action Group TEVE off
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:deviceIsChildDevice
Sony Bravia Network Remote Plugin Threaddebug Command queue has 1 command(s) waiting
Sony Bravia Network Remote Plugin Threaddebug Received SOAP/JSON command request:
/sony/IRCC
urn:schemas-sony-com:service:IRCC:1#X_SendIRCC
<SOAP-ENV:Envelope SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Body>
<m:X_SendIRCC xmlns:m="urn:schemas-sony-com:service:IRCC:1">
<IRCCCode xmlns:dt="urn:schemas-microsoft-com:datatypes" dt:dt="string">AAAAAQAAAAEAAAAvAw==</IRCCCode>
</m:X_SendIRCC>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Sony Bravia Network Remote Plugin Debug Processing SOAP/JSON operation to
http://tv65.hpk.nu:80/sony/IRCC Sony Bravia Network Remote Plugin Threaddebug Sending SOAP/JSON request:
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
Sony Bravia Network Remote Plugin Threaddebug Using headers:
{'Content-type': 'text/xml; charset="UTF-8"', 'Host': 'tv65.hpk.nu', 'Cookie': 'auth=4FFDAA60C2CEBC7603F03B61FF853960FDD3C8B1', 'SOAPAction': 'urn:schemas-sony-com:service:IRCC:1#X_SendIRCC', 'User-Agent': 'DuncanwareRemote (IndigoPlugin)'}
Sony Bravia Network Remote Plugin Threaddebug Command Response was not HTTP OK, handling RESTful error
Sony Bravia Network Remote Plugin Received an authentication request, attempting now...
Sony Bravia Network Remote Plugin Threaddebug Received an authentication command, attempting connection
Sony Bravia Network Remote Plugin Threaddebug Sending Auth Request: {"id":13, "method":"actRegister", "version":"1.0", "params": [{"clientid":"DuncanwareRemote:34c43339-af3d-40e7-b1b2-743331375368c", "nickname":"DuncanwareRemote (IndigoPlugin)"}, [{"clientid":"DuncanwareRemote:34c43339-af3d-40e7-b1b2-743331375368c", "value":"yes", "nickname":"DuncanwareRemote (IndigoPlugin)", "function":"WOL"}]]}
Sony Bravia Network Remote Plugin Threaddebug Response to Auth Request: [200] [('set-cookie', 'auth=B0FF3089D8D9473747EF53EAD5F27CBEE5ACCB36; Path=/sony/; Max-Age=1209600; Expires=ons, 01 mar 2017 15:57:39 GMT+00:00'), ('content-length', '21'), ('content-type', 'application/json'), ('connection', 'close')]
{"result":[],"id":13}
Sony Bravia Network Remote Plugin Debug Obtained Auth Cookie: auth=B0FF3089D8D9473747EF53EAD5F27CBEE5ACCB36
Sony Bravia Network Remote Plugin Debug Entering deviceStopComm for TEVE; ID=1725479520
/sony/IRCC
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
Sony Bravia Network Remote Plugin Debug Initiating shutdown of communications with TEVE
Sony Bravia Network Remote Plugin Debug Command thread ending processing
Sony Bravia Network Remote Plugin Debug Shutdown of communications with TEVE complete
Sony Bravia Network Remote Plugin Debug Exiting deviceStopComm for TEVE
Sony Bravia Network Remote Plugin Debug Entering deviceStartComm for TEVE; ID=1725479520
Sony Bravia Network Remote Plugin Debug Concurrent Processing Thread started for device 1725479520
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:updateStatusPollerIntervalProperty
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:updateStatusPollerActionId
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:emptyQueueReducedWaitCycles
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:databaseConnectionEnabled
Sony Bravia Network Remote Plugin Threaddebug Database access enabled:
Sony Bravia Network Remote Plugin Threaddebug Database access has been disabled, skipping connection
Sony Bravia Network Remote Plugin Threaddebug Create connection command de-queued
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:updateStatusPollerStartupDelay
Sony Bravia Network Remote Plugin Threaddebug Command queue has 2 command(s) waiting
Sony Bravia Network Remote Plugin Threaddebug Initiating sleep of 3.0 seconds from command.
Sony Bravia Network Remote Plugin Debug Exiting deviceStartComm for TEVE
Sony Bravia Network Remote Plugin Threaddebug Ignoring status update request, no action specified to update device status
15 Feb 2017, 16:58:11
Action Group TEVE kanal ner
/sony/IRCC
<SOAP-ENV:Body>
<IRCCCode xmlns:dt="urn:schemas-microsoft-com:datatypes" dt:dt="string">AAAAAQAAAAEAAAARAw==</IRCCCode>
</m:X_SendIRCC>
</SOAP-ENV:Body>
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
{'Content-type': 'text/xml; charset="UTF-8"', 'Host': 'tv65.hpk.nu', 'Cookie': 'auth=B0FF3089D8D9473747EF53EAD5F27CBEE5ACCB36', 'SOAPAction': 'urn:schemas-sony-com:service:IRCC:1#X_SendIRCC', 'User-Agent': 'DuncanwareRemote (IndigoPlugin)'}
Sony Bravia Network Remote Plugin Threaddebug Response to Auth Request: [200] [('set-cookie', 'auth=DA0D107DF157E7D58C186A7E4CEEA449A86821A6; Path=/sony/; Max-Age=1209600; Expires=ons, 01 mar 2017 15:58:08 GMT+00:00'), ('content-length', '21'), ('content-type', 'application/json'), ('connection', 'close')]
Sony Bravia Network Remote Plugin Debug Obtained Auth Cookie: auth=DA0D107DF157E7D58C186A7E4CEEA449A86821A6
/sony/IRCC
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
http://tv65.hpk.nu:80/sony/IRCC Sony Bravia Network Remote Plugin Debug Command thread ending processing
