Problem with KD-65X9005C
Tue Feb 07, 2017 1:09 pm
mike@hpk.nu offline
I have been trying (almost) everything but still no success :( I'm currently running version 2.4.3
The model is : KD-65X9005C
I can successfully pair the TV but that's all. No TV on/off or sending command's work.
It has never worked, neither on Indigo 6 nor on Indigo 7
Sony Bravia Network Remote Plugin Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sony Bravia Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkRESTfulDevice.py", line 362, in concurrentCommandProcessingThread
self.handleRESTfulError(command, e, responseObj)
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sony Bravia Network Remote.indigoPlugin/Contents/Server Plugin/sonyTvNetworkRemoteDevice.py", line 159, in handleRESTfulError
self.commandQueue.put(RPFrameworkCommand.RPFrameworkCommand(CMD_AUTHENTICATE_TO_DEVICE, commandPayload=rpCommand.commandPayload))
NameError: global name 'RPFrameworkCommand' is not defined
Tue Feb 07, 2017 4:43 pm
RogueProeliator offline
Re: Problem with KD-65X9005C
You can try [ur]https://github.com/RogueProeliator/IndigoPlugins-Sony-Network-Remote/archive/v2.4.4.zip[/url], but your issue sounds similar to the one being debugged on the Sony Bravia plugin seems to be broken with Indigo 7.0 thread. Go ahead and try this 2.4.4 version and re-post your results with Debug set to High, if you would...
Adam
Thu Feb 09, 2017 12:39 pm
mike@hpk.nu offline
For the fist time ever there are no errors!! But there are also no action on the TV :-(.
I have tried Power On, Power Off, Send button volume up/down, Channel up/down and there are no error and no reaction on the TV
Action Group TEVE kanal ner
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:deviceIsChildDevice
Sony Bravia Network Remote Plugin Threaddebug Command queue has 1 command(s) waiting
Sony Bravia Network Remote Plugin Threaddebug Received SOAP/JSON command request:
/sony/IRCC
urn:schemas-sony-com:service:IRCC:1#X_SendIRCC
<SOAP-ENV:Envelope SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Body>
<m:X_SendIRCC xmlns:m="urn:schemas-sony-com:service:IRCC:1">
<IRCCCode xmlns:dt="urn:schemas-microsoft-com:datatypes" dt:dt="string">AAAAAQAAAAEAAAARAw==</IRCCCode>
</m:X_SendIRCC>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Sony Bravia Network Remote Plugin Debug Processing SOAP/JSON operation to http://tv65.hpk.nu:80/sony/IRCC
Sony Bravia Network Remote Plugin Threaddebug Sending SOAP/JSON request:
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
Sony Bravia Network Remote Plugin Threaddebug Using headers:
{'Content-type': 'text/xml; charset="UTF-8"', 'Host': u'tv65.hpk.nu', 'Cookie': u'auth=17DC1F24671278C0245EF4172A76025D2690C79B', 'SOAPAction': 'urn:schemas-sony-com:service:IRCC:1#X_SendIRCC', 'User-Agent': 'DuncanwareRemote (IndigoPlugin)'}
Sony Bravia Network Remote Plugin Received an authentication request, attempting now...
Sony Bravia Network Remote Plugin Threaddebug Received an authentication command, attempting connection
Sony Bravia Network Remote Plugin Threaddebug Sending Auth Request: {"id":13, "method":"actRegister", "version":"1.0", "params": [{"clientid":"DuncanwareRemote:34c43339-af3d-40e7-b1b2-743331375368c", "nickname":"DuncanwareRemote (IndigoPlugin)"}, [{"clientid":"DuncanwareRemote:34c43339-af3d-40e7-b1b2-743331375368c", "value":"yes", "nickname":"DuncanwareRemote (IndigoPlugin)", "function":"WOL"}]]}
Sony Bravia Network Remote Plugin Threaddebug Response to Auth Request: [200] [('set-cookie', 'auth=4101988FAEB93D1CFE897A0E1473AA868E17A3B6; Path=/sony/; Max-Age=1209600; Expires=tors, 23 feb 2017 18:34:40 GMT+00:00'), ('content-length', '21'), ('content-type', 'application/json'), ('connection', 'close')]
{"result":[],"id":13}
Sony Bravia Network Remote Plugin Debug Obtained Auth Cookie: auth=4101988FAEB93D1CFE897A0E1473AA868E17A3B6
Sony Bravia Network Remote Plugin Debug Entering deviceStopComm for TEVE; ID=1725479520
/sony/IRCC
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
Sony Bravia Network Remote Plugin Debug Initiating shutdown of communications with TEVE
Sony Bravia Network Remote Plugin Debug Command thread ending processing
Sony Bravia Network Remote Plugin Debug Shutdown of communications with TEVE complete
Sony Bravia Network Remote Plugin Debug Exiting deviceStopComm for TEVE
Sony Bravia Network Remote Plugin Debug Entering deviceStartComm for TEVE; ID=1725479520
Sony Bravia Network Remote Plugin Debug Concurrent Processing Thread started for device 1725479520
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:updateStatusPollerIntervalProperty
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:updateStatusPollerActionId
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:emptyQueueReducedWaitCycles
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:databaseConnectionEnabled
Sony Bravia Network Remote Plugin Threaddebug Database access enabled:
Sony Bravia Network Remote Plugin Threaddebug Database access has been disabled, skipping connection
Sony Bravia Network Remote Plugin Threaddebug Create connection command de-queued
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:updateStatusPollerStartupDelay
Sony Bravia Network Remote Plugin Threaddebug Command queue has 2 command(s) waiting
Sony Bravia Network Remote Plugin Threaddebug Initiating sleep of 3.0 seconds from command.
Sony Bravia Network Remote Plugin Debug Exiting deviceStartComm for TEVE
Sony Bravia Network Remote Plugin Threaddebug Ignoring status update request, no action specified to update device status
Tue Feb 14, 2017 1:33 pm
Thanks for posting the log the other day; have a go at this version -- I don't necessarily expect it to be fixed, but rather hopefully gather more information as to what went wrong.
https://github.com/RogueProeliator/IndigoPlugins-Sony-Network-Remote/archive/v2.4.5.zip
Wed Feb 15, 2017 10:01 am
mike@hpk.nu offline
Ok, as you predicted, no funktion, here are the new log. Sent two command to the TV channel down and volume down.
15 Feb 2017, 16:57:42
Action Group TEVE off
/sony/IRCC
<SOAP-ENV:Body>
<IRCCCode xmlns:dt="urn:schemas-microsoft-com:datatypes" dt:dt="string">AAAAAQAAAAEAAAAvAw==</IRCCCode>
</m:X_SendIRCC>
</SOAP-ENV:Body>
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
{'Content-type': 'text/xml; charset="UTF-8"', 'Host': 'tv65.hpk.nu', 'Cookie': 'auth=4FFDAA60C2CEBC7603F03B61FF853960FDD3C8B1', 'SOAPAction': 'urn:schemas-sony-com:service:IRCC:1#X_SendIRCC', 'User-Agent': 'DuncanwareRemote (IndigoPlugin)'}
Sony Bravia Network Remote Plugin Threaddebug Command Response was not HTTP OK, handling RESTful error
Sony Bravia Network Remote Plugin Threaddebug Response to Auth Request: [200] [('set-cookie', 'auth=B0FF3089D8D9473747EF53EAD5F27CBEE5ACCB36; Path=/sony/; Max-Age=1209600; Expires=ons, 01 mar 2017 15:57:39 GMT+00:00'), ('content-length', '21'), ('content-type', 'application/json'), ('connection', 'close')]
Sony Bravia Network Remote Plugin Debug Obtained Auth Cookie: auth=B0FF3089D8D9473747EF53EAD5F27CBEE5ACCB36
/sony/IRCC
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
15 Feb 2017, 16:58:11
/sony/IRCC
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
{'Content-type': 'text/xml; charset="UTF-8"', 'Host': 'tv65.hpk.nu', 'Cookie': 'auth=B0FF3089D8D9473747EF53EAD5F27CBEE5ACCB36', 'SOAPAction': 'urn:schemas-sony-com:service:IRCC:1#X_SendIRCC', 'User-Agent': 'DuncanwareRemote (IndigoPlugin)'}
Sony Bravia Network Remote Plugin Threaddebug Response to Auth Request: [200] [('set-cookie', 'auth=DA0D107DF157E7D58C186A7E4CEEA449A86821A6; Path=/sony/; Max-Age=1209600; Expires=ons, 01 mar 2017 15:58:08 GMT+00:00'), ('content-length', '21'), ('content-type', 'application/json'), ('connection', 'close')]
Sony Bravia Network Remote Plugin Debug Obtained Auth Cookie: auth=DA0D107DF157E7D58C186A7E4CEEA449A86821A6
/sony/IRCC
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
