Sony Bravia Network Remote - Introduction and Installation
Tue Nov 26, 2013 10:59 pm
RogueProeliator offline
Quick Download: Plugin | GitHub Repository
Introducing the Sony Bravia Network Remote Plugin
This Indigo 6.0+ plugin allows Indigo to act as a remote control for select network-connected Sony devices. All commands/buttons found on the standard, included remote can be sent to the device as well as a multitude of additional commands generally available only through network or advanced universal remotes. The protocol exposed by Sony devices, and utilized by this plugin, does not allow for state information about the device to be obtained (such as what current application/channel is active or what input the television is currently showing). If the protocol is changed or a device comes out that does provide feedback then it may be possible to enhance the plugin at that time.
Currently this plugin is loaded with the necessary remote commands to control Sony televisions; however, if anyone has alternate Sony devices supporting IP control (e.g. some recent Blu-Ray players) then it should be trivial to add support for those device types.
Hardware Requirements
This plugin should work with any supported Sony device type as the remote commands do not change much between individual device models; some models may not support all commands provided by the plugin (e.g. Netflix & Picture-in-Picture commands). Also note that turning ON the device is only supported on those Sony models that support Wake-On-LAN (WOL). This includes many/most 2013 models supporting IP commands and some limited previous year models.
The auto-discovery feature requires that the Sony device and Indigo server be on the same subnet, though manual IP entry should allow remote control via a WAN interfaces (such as over a VPN connection).
IMPORTANT NOTE: If you wish to allow the plugin to remotely power on the device, you must turn on "Remote Start" on your Sony device. This is found in different menus depending upon your device, but is often found in the "Home Network Setup" section of the settings menu. Note that you must also configure the MAC address on the Device Configuration screen (see below).
Installation and Configuration
Downloading the Plugin Package
The latest version of the plugin is v2.3.0 and may be downloaded here.
Previous and pre-release versions of the plugin are available for download in the GitHub Releases section... those versions in beta will be marked as a Pre-Release and will not appear in update notifications. Once installed, you may use the Check for Updates option in the plugin's menu to check for and download updates.
Configuring the Plugin
Upon first installation you will be asked to configure the plugin; please see the instructions on the configuration screen for more information. Most users should be fine with the default values.
Plugin Devices
Each Sony device that you wish to control should be created as an Indigo Device; in the Device Settings you will need to select from the list of supported devices found on the network or else manually enter your devices's IP address. Note that if you ever lose connection with your device, you may need to return here to find/enter the IP Address again if it has picked up a new address on the network. Please read the additional instructions on the configuration dialog as you may need to fill out additional information to get full control of your device:
Available Actions
  • Send Button Press
    This action will send a network command that is equivalent to pressing the button on the remote (some buttons included are not found on the physical remote). Not all models will support all commands available in the plugin... non-supported commands will generally just be ignored by the device. If there are any commands that you believe your TV supports but which are not included here, please let me know and I can attempt to add it to the action.
  • Power ON
    When a device is powered off it will not respond to network commands; however, many Sony devices now include the ability for the plugin to "wake up" the device over the network. This action attempts to do just that.
  • Power OFF
    This command will power off the device.
Sun Dec 08, 2013 9:09 pm
Re: Sony Bravia Network Remote - Introduction and Installati
v1.0.4 Released
The Sony Bravia Network Remote has been upgraded to v1.0.4, with the following changes:
  • Improved format and sorting of device configuration and action dialogs/menus to make them easier to use
Thu Jul 03, 2014 2:22 pm
v1.0.9 Released
The Sony Bravia Network Remote has been upgraded to v1.0.9, with the following changes:
  • Updated download URLs on initial post (was broken, pointing to old server)
  • Updated plugin version check URL
  • Updated About/Help link to point to the new forum URL
  • Updated error handling and task scheduling (slight efficiency improvements, more technical than practical)
Thu Nov 26, 2015 10:17 pm
v2.2.17 Released
The Sony Bravia Network Remote has been upgraded to v2.2.17, with the following changes:
  • Added ability to pair with devices requiring a pairing / authentication before control is allowed
  • Added a Power On IR command for use on TVs that never fully sleep
  • Numerous misc. enhancements for debugging and troubleshooting
Wed Aug 03, 2016 9:04 pm
v2.3.0 Released
The Sony Bravia Network Remote has been upgraded to v2.3.0, with the following changes:
  • Migrated code and updater to GitHub; you will need to update to continue to get update notifications
  • Enhanced code that identifies when a previously-paired device's pairing has timed out; will automatically attempt to reconnect more often without user intervention
