Russound RNET Plugin
Tue Aug 06, 2013 12:36 pm
wideglidejrp offline
Re: Russound RNET Plugin
Bingo! I had forgotten that the IP address has to be updated in two places. Many thanks. Happy camper once again. These plugins have enabled me to gain full control of music throughout my vacation home. :D
John R Patrick
Author of
Home Attitude
Thu Feb 13, 2014 4:58 pm
allengray offline
hi there -
The Russound plugin is looking great except that I'm unable to interact with zone 4 on either my two CAV6.6 units. I can actually send commands to the unit for zone 4, but when the response comes back it's always shown as invalid.
Anyone see this before?
Fri Jun 20, 2014 5:39 am
peppop offline
Hello NLagaros thanks for taking over the plug-in.
Have you seen the XStream-X5 Zone Media Streamer?
I can get some control using the plug-in on port 9650, but I get a lot of errors.
Do you think you could add this streamer to the plug-in?
Also you might want to add the zip extension (.zip) to the download file.
The download file is a zip file but it shows up as a plug-in
Here is my event log.
https://dl.dropboxusercontent.com/u/459 ... %20Log.rtf
Sun Aug 03, 2014 5:47 am
nlagaros offline
Unfortunately I am no longer in possession of any Russound equipment so can no longer make any modifications or improvements to the plugin.
Wed Nov 12, 2014 5:00 pm
allengray offline
Hi nlagaros,
I'm interested in taking on maintenance of the Russound plugin if you've moved away from it.
Let me know.
Allen Gray
Thu Nov 13, 2014 12:18 pm
jottawa offline
Hi Allen,
Please feel free to take over the plugin as I no longer have any Russound equipment either.
Thu Feb 12, 2015 2:55 pm
peppop offline
Can somebody please take over this plug-in, or just create a new one using an IP address like the Russound application.
Mon Aug 03, 2015 2:20 pm
Not sure if anyone is supporting the plugin any longer. If so, I have been getting an error I never saw before, as follows....
Russound Error Error in plugin execution ExecuteAction:
File "plugin.py", line 113, in actionKeyPadEvent
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Russound.indigoPlugin/Contents/Server Plugin/Russound.py", line 810, in actionGeneric
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Russound.indigoPlugin/Contents/Server Plugin/Russound.py", line 367, in sendMessage
<class 'socket.error'>: (32, 'Broken pipe')
John R Patrick
Author of
Home Attitude
Sun Aug 09, 2015 2:00 pm
The problem turned out to be the Startech RS232 box failed. I could easily replace it but decided to go with Sonos instead. I am creating a plugin for the Epson 5030e projector. I have very simple ambitions: turn it on or off and select one of two sources. I am wondering if the Russound plugin would be a good template to start from. Any thoughts on this?
John R Patrick
Author of
Home Attitude
Wed Apr 12, 2017 6:09 pm
michaelcreamer offline
Hello-- is anyone using the Russound plugin successfully with Indigo 7?
I can get a zone to switch to "ON" but cannot get any sound and I see a bunch of errors in the log (see below). Any help is appreciated! Thanks!
Russound Debug TX: F0 00 00 7F 00 00 70 05 02 02 00 00 F1 21 00 0F 00 00 00 01 1E F7
Russound Debug TX: F0 00 00 7F 00 00 70 05 02 00 00 00 F1 3E 00 00 00 00 00 01 2A F7
Russound Debug TX: F0 00 00 7F 00 00 70 05 02 02 00 00 F1 23 00 01 00 00 00 01 12 F7
Russound Debug Method: runConcurrentThread
Russound Debug Running Concurrent Thread
Russound Error Error in plugin execution runConcurrentThread:
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Russound.indigoPlugin/Contents/Server Plugin/Russound.py", line 298, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Russound.indigoPlugin/Contents/Server Plugin/Russound.py", line 395, in checkForMessages
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Russound.indigoPlugin/Contents/Server Plugin/Russound.py", line 371, in readSerialPort
TypeError: readline() takes no keyword arguments
Thu Apr 13, 2017 2:41 am
Ksullivan offline
It's working ok for me on 7
Fri Apr 14, 2017 7:08 am
I have figured out the problem.
Apparently the signature for the readline() python function changed in 2.6 such that it no longer takes an EOL parameter. I have 2.7 installed.
If it is still working for anyone then I guess they are using a prior version of python.
Sat Apr 15, 2017 9:28 am
Fixed. I've updated the plugin code to correctly retrieve data from the Russound device.
It's working like a charm now and I'm VERY happy!
Does anyone know of a good source for wired speakers?
Sun Apr 23, 2017 8:15 am
Add XM Radio to your Russound for FREE
Sirius XM is running a promotion during which you can get a FREE receiver with a home kit to hook to your Russound or other home audio component. (Of course you do need to add a subscription to the service.)
I was going to add the Russound ST2-XM tuner but this option is FREE!
The offer is available to both new and existing customers. Check out the details here https://shop.siriusxm.com/radios/?intcmp=SHOP-HP-PROMO1.
I added the Onyx EZ receiver (shown below) to my Russound CAV 6.6 and it's great. You can also control the Onyx EZ using an IR Blaster from the Russound unit and have complete control from Indigo. (Note that you do need to "teach" the Russound the remote control codes from the Onyx EZ remote.)
If anyone would like further details just let me know and I'll post them.
XM Radio Onyx EX Receiver
Sat Jun 29, 2019 5:45 am
thepainter offline
Is this plugin still available?
