Sharp Aquos LC-60C6400U connects and disconnects
Wed Oct 21, 2015 3:41 pm
pacman offline
I can't keep this TV connected. I am using login/password and everything looks correct in settings. It does connect but for a few seconds only.
Oct 21, 2015, 2:37:42 PM
Sharp TV Network Remote Plugin Debug Attempting reconnection to device 1548464646
Sharp TV Network Remote Plugin Debug Connection established
Oct 21, 2015, 2:38:04 PM
Sharp TV Network Remote Plugin Error Connection timed out for device 1548464646
Sharp TV Network Remote Plugin Debug Closing connection to device
Oct 21, 2015, 2:38:28 PM
Received INSTEON "T-Stat" temperature changed to 75.0
Oct 21, 2015, 2:39:22 PM
Received INSTEON "T-Stat" temperature changed to 74.0
Oct 21, 2015, 2:41:02 PM
EasyDAQ Relay Card received "DAQ Card 2 - Outside Air Temp Setpoint(24)" update to off
What should I try next?
Wed Oct 21, 2015 8:48 pm
RogueProeliator offline
Re: Sharp Aquos LC-60C6400U connects and disconnects
Turn the debug on the full (via the Plugin Configuration Dialog) and let it try connecting... that will give the actual communication between the plugin and the television. Off hand, I wonder if that model has a different response to the login such that the command the plugin waits for never matches.
Adam
Thu Oct 22, 2015 3:08 pm
pacman offline
Here is the high level troubleshooting log. Today it doesn't connect at all.
Oct 22, 2015, 2:03:36 PM
Sharp TV Network Remote Plugin Debug Executing Enable Power On Commands...
Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
Sharp TV Network Remote Plugin Debug Read device state config... isConnected: "isConnected"; connectionState: "connectionState"
Sharp TV Network Remote Plugin Debug Establishing connection to 192.168.0.145
Sharp TV Network Remote Plugin Debug Scheduling reconnection attempt...
Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:reconnectAttemptDelay
Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:reconnectAttemptScheme
Sharp TV Network Remote Plugin Debug Reconnection attempt scheduled for 120 seconds
Sharp TV Network Remote Plugin Debug Plugin Command queue has 2 command(s) waiting
Sharp TV Network Remote Plugin Debug Plugin Command queue has 1 command(s) waiting
Sharp TV Network Remote Plugin Debug Plugin command queue not yet ready; requeuing for future execution
Sharp TV Network Remote Plugin Debug Reconnection attempt scheduled for 180 seconds
Oct 22, 2015, 2:04:00 PM
Received INSTEON "T-Stat" temperature changed to 71.0
Reloading plugin "Sharp TV Network Remote Plugin 1.4.18"
Stopping plugin "Sharp TV Network Remote Plugin 1.4.18" (pid 6322)
Sharp TV Network Remote Plugin Debug Entering deviceStopComm for LRM TV; ID=1548464646
Sharp TV Network Remote Plugin Debug Initiating shutdown of communications with LRM TV
Sharp TV Network Remote Plugin Debug Shutdown of communications with LRM TV complete
Sharp TV Network Remote Plugin Debug Exiting deviceStopComm for LRM TV
Stopped plugin "Sharp TV Network Remote Plugin 1.4.18"
Starting plugin "Sharp TV Network Remote Plugin 1.4.18" (pid 6326)
Sharp TV Network Remote Plugin Initializing RPFrameworkPlugin
Sharp TV Network Remote Plugin Beginning processing of RPFrameworkConfig.xml file
Sharp TV Network Remote Plugin Found plugin setting: pluginUpdateURL=http://forums.indigodomo.com/viewtopic.php?f=64&t=10981
Sharp TV Network Remote Plugin Found device mapping; id: sharpTvRemoteDevice to class: SharpTvNetworkRemoteDevice
Sharp TV Network Remote Plugin Created device parameter for managed device "sharpTvRemoteDevice": ipAddress
Sharp TV Network Remote Plugin Created device parameter for managed device "sharpTvRemoteDevice": portNumber
Sharp TV Network Remote Plugin Created device parameter for managed device "sharpTvRemoteDevice": updateInterval
Sharp TV Network Remote Plugin Found device setting: deviceAddressFormat=%ap:ipAddress%:%ap:portNumber%
Sharp TV Network Remote Plugin Found device setting: telnetConnectionDeviceStateName=connectionState
Sharp TV Network Remote Plugin Found device setting: telnetConnectionDeviceStateBoolean=isConnected
Sharp TV Network Remote Plugin Found device setting: telnetConnectionRequiresLoginProperty=requiresLogin
Sharp TV Network Remote Plugin Found device setting: updateStatusPollerActionId=updateDeviceStatesFromTv
Sharp TV Network Remote Plugin Found device setting: reconnectAttemptLimit=100
Sharp TV Network Remote Plugin Found device response: loginPrompt
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=%dp:tvUsername%; ValueFormatEx=; Eval=False; Condition=
Sharp TV Network Remote Plugin Found device response: passwordPrompt
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=%dp:tvPassword%; ValueFormatEx=; Eval=False; Condition=
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: UPDATEDEVICESTATUS_FULL; ValueFormat=; ValueFormatEx=; Eval=False; Condition=
Sharp TV Network Remote Plugin Found device response: volRemoteKeyPressed
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=VOLM?? ; ValueFormatEx=; Eval=False; Condition="%dp:updateInterval%" != "-1"
Sharp TV Network Remote Plugin Found device response: muteRemoteKeyPressed
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=MUTE? ; ValueFormatEx=; Eval=False; Condition="%dp:updateInterval%" != "-1"
Sharp TV Network Remote Plugin Found device response: channelRemoteKeyPressed
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=DCCH??? ; ValueFormatEx=; Eval=False; Condition="%dp:updateInterval%" != "-1"
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=DC2U??? ; ValueFormatEx=; Eval=False; Condition="%dp:updateInterval%" != "-1"
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=DC2L??? ; ValueFormatEx=; Eval=False; Condition="%dp:updateInterval%" != "-1"
Sharp TV Network Remote Plugin Found device response: avModeRemoteKeyPressed
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=AVMD??? ; ValueFormatEx=; Eval=False; Condition="%dp:updateInterval%" != "-1"
Sharp TV Network Remote Plugin Found device response: viewModeRemoteKeyPressed
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=WIDE?? ; ValueFormatEx=; Eval=False; Condition="%dp:updateInterval%" != "-1"
Sharp TV Network Remote Plugin Found device response: sleepModeRemoteKeyPressed
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=OFTM? ; ValueFormatEx=; Eval=False; Condition="%dp:updateInterval%" != "-1"
Sharp TV Network Remote Plugin Found device response: closedCaptionRemoteKeyPressed
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=CLCP? ; ValueFormatEx=; Eval=False; Condition="%dp:updateInterval%" != "-1"
Sharp TV Network Remote Plugin Found device response: inputRemoteKeyPressed
Sharp TV Network Remote Plugin Found response effect: Type=queueCommand; Param: writeToTelnetConn; ValueFormat=ITGD? ; ValueFormatEx=; Eval=False; Condition="%dp:updateInterval%" != "-1"
Sharp TV Network Remote Plugin Found device response: powerStatusQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: powerState; ValueFormat="%cp:response%" == "1"; ValueFormatEx=; Eval=True; Condition=
Sharp TV Network Remote Plugin Found device response: powerOnMessagesEnabledStatusQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: powerOnCommandsEnabled; ValueFormat="%cp:response%" == "2"; ValueFormatEx=; Eval=True; Condition=
Sharp TV Network Remote Plugin Found device response: currentInputQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: currentInputNumber; ValueFormat=-1 if "%cp:response%" == "ERR" else int("%cp:response%"); ValueFormatEx=; Eval=True; Condition=
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: currentInputLabel; ValueFormat="unknown" if "%cp:response%" == "ERR" else "%dp:input%cp:response%Label%"; ValueFormatEx=; Eval=True; Condition=
Sharp TV Network Remote Plugin Found device response: currentAVModeQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: avMode; ValueFormat=N%cp:response%; ValueFormatEx=; Eval=False; Condition=
Sharp TV Network Remote Plugin Found device response: currentViewModeQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: viewMode; ValueFormat=N%cp:response%; ValueFormatEx=; Eval=False; Condition=
Sharp TV Network Remote Plugin Found device response: currentVolumeQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: volume; ValueFormat=-1 if "%cp:response%" == "ERR" else int("%cp:response%"); ValueFormatEx=; Eval=True; Condition=
Sharp TV Network Remote Plugin Found device response: isMutedQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: muted; ValueFormat="%cp:response%" == "1"; ValueFormatEx=; Eval=True; Condition=
Sharp TV Network Remote Plugin Found device response: currentSurroundSoundModeQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: surroundSoundMode; ValueFormat=N%cp:response%; ValueFormatEx=; Eval=False; Condition=
Sharp TV Network Remote Plugin Found device response: currentSleepTimerQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: sleepTimerMinutes; ValueFormat=%cp:response%; ValueFormatEx=; Eval=False; Condition=
Sharp TV Network Remote Plugin Found device response: isCCEnabledQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: closedCaptioning; ValueFormat="%cp:response%" == "1"; ValueFormatEx=; Eval=True; Condition=
Sharp TV Network Remote Plugin Found device response: deviceNameQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: deviceName; ValueFormat=%cp:response%; ValueFormatEx=; Eval=False; Condition=
Sharp TV Network Remote Plugin Found device response: modelNumberQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: deviceModel; ValueFormat=%cp:response%; ValueFormatEx=; Eval=False; Condition=
Sharp TV Network Remote Plugin Found device response: currentAnalogChannelQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: currentAnalogChannel; ValueFormat=0 if "%cp:response%" == "ERR" else int("%cp:response%"); ValueFormatEx=; Eval=True; Condition=
Sharp TV Network Remote Plugin Found device response: currentDigitalChannelUpperQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: currentDigitalChannel; ValueFormat=0 if "%cp:response%" == "ERR" else float("%cp:response%"); ValueFormatEx=; Eval=True; Condition=
Sharp TV Network Remote Plugin Found device response: currentDigitalChannelLowerQuery
Sharp TV Network Remote Plugin Found response effect: Type=updateDeviceState; Param: currentDigitalChannel; ValueFormat=0 if "%cp:response%" == "ERR" else math.floor(float("%ds:currentDigitalChannel%")) + float("0.%cp:response%"); ValueFormatEx=; Eval=True; Condition=
Sharp TV Network Remote Plugin Found managed action: updateDeviceStatesFromTv
Sharp TV Network Remote Plugin Found managed action: toggleTVPower
Sharp TV Network Remote Plugin Found managed action: setTVPower
Sharp TV Network Remote Plugin Processing 1 params for action
Sharp TV Network Remote Plugin Created parameter for managed action "setTVPower": powerState
Sharp TV Network Remote Plugin Found managed action: changeTVPowerOnMessages
Sharp TV Network Remote Plugin Created parameter for managed action "changeTVPowerOnMessages": powerOnMessageState
Sharp TV Network Remote Plugin Found managed action: changeAVMode
Sharp TV Network Remote Plugin Created parameter for managed action "changeAVMode": avMode
Sharp TV Network Remote Plugin Found managed action: changeViewMode
Sharp TV Network Remote Plugin Created parameter for managed action "changeViewMode": viewMode
Sharp TV Network Remote Plugin Found managed action: setVolumeLevel
Sharp TV Network Remote Plugin Created parameter for managed action "setVolumeLevel": volumeLevel
Sharp TV Network Remote Plugin Found managed action: setMuteStatus
Sharp TV Network Remote Plugin Created parameter for managed action "setMuteStatus": muteState
Sharp TV Network Remote Plugin Found managed action: setSurroundSoundMode
Sharp TV Network Remote Plugin Created parameter for managed action "setSurroundSoundMode": surroundSoundMode
Sharp TV Network Remote Plugin Found managed action: setSleepTimer
Sharp TV Network Remote Plugin Created parameter for managed action "setSleepTimer": sleepTimerSetting
Sharp TV Network Remote Plugin Found managed action: setClosedCaptioning
Sharp TV Network Remote Plugin Created parameter for managed action "setClosedCaptioning": ccState
Sharp TV Network Remote Plugin Found managed action: selectInput
Sharp TV Network Remote Plugin Created parameter for managed action "selectInput": tvInput
Sharp TV Network Remote Plugin Found managed action: tuneToAnalogChannel
Sharp TV Network Remote Plugin Created parameter for managed action "tuneToAnalogChannel": channelNumber
Sharp TV Network Remote Plugin Found managed action: addDigitToChannelSelector
Sharp TV Network Remote Plugin Created parameter for managed action "addDigitToChannelSelector": digitToAdd
Sharp TV Network Remote Plugin Found managed action: remoteDigitFromChannelSelector
Sharp TV Network Remote Plugin Found managed action: clearChannelSelector
Sharp TV Network Remote Plugin Found managed action: tuneToChannelSelector
Sharp TV Network Remote Plugin Found managed action: sendRemoteKey
Sharp TV Network Remote Plugin Created parameter for managed action "sendRemoteKey": keyToSend
Sharp TV Network Remote Plugin Found managed action: sendArbitraryCommand
Sharp TV Network Remote Plugin Created parameter for managed action "sendArbitraryCommand": commandCode
Sharp TV Network Remote Plugin Successfully completed processing of RPFrameworkConfig.xml file
Sharp TV Network Remote Plugin Customizing MenuItems.xml
Sharp TV Network Remote Plugin Returning default GUIConfigValue for plugin:showUPnPDebug
Started plugin "Sharp TV Network Remote Plugin 1.4.18"
Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for plugin:databaseConnectionEnabled
Sharp TV Network Remote Plugin Debug Database access enabled:
Sharp TV Network Remote Plugin Debug Database access has been disabled, skipping connection
Sharp TV Network Remote Plugin Debug Entering deviceStartComm for LRM TV; ID=1548464646
Sharp TV Network Remote Plugin Debug Exiting deviceStartComm for LRM TV
Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for plugin:pluginCommandQueueIdleSleep
Sharp TV Network Remote Plugin Debug Version check initiated
Sharp TV Network Remote Plugin Debug Version File Url:http://www.duncanware.com/Downloads/IndigoHomeAutomation/Plugins/SharpTvNetworkRemote/SharpTvNetworkRemoteVersionInfo.html
Sharp TV Network Remote Plugin Your plugin version, v1.4.18, is current.
Sharp TV Network Remote Plugin Debug Reconnection attempt scheduled for 60 seconds
Oct 22, 2015, 2:04:38 PM
Oct 22, 2015, 2:04:58 PM
Sharp TV Network Remote Plugin Debug Setting address of 1548464646 to 192.168.0.145:10006
Disabling plugin "Sharp TV Network Remote Plugin 1.4.18"
Stopping plugin "Sharp TV Network Remote Plugin 1.4.18" (pid 6326)
Enabling plugin "Sharp TV Network Remote Plugin 1.4.18"
Starting plugin "Sharp TV Network Remote Plugin 1.4.18" (pid 6329)
Sat Oct 31, 2015 10:47 pm
I assume that you have checked the IP address, but have you (or can you) double check the port number? The default should be 10002 for the Sharp models that I have seen, but it should be shown on the TV's settings menu.
That debug report shows that the TV is basically never responding to the connection request. One thing you might be able to do is to manually attempt to connect to the TV -- from the terminal just telnet to the IP address and port specified and see if it gives you a response (should ask for a login since you have that setup). Since we are not even making a connection, at least in that debug report, that would be my first step.
Adam
Tue Nov 10, 2015 6:08 pm
pacman offline
I use port 10006. When I setup the TV I specified this port because 10002 conflicted with another port within my network.
I don't understand telnet request. I am not a network guy except for maintaining my internal network config. All my code is mostly taken from other people and then applied through trial and error until I get it right. Sorry!
Mon Nov 16, 2015 1:37 pm
Okay, first of all, sorry for the delayed response... I lost this in my list of threads that I was tracking. I'd like to start "over" from the beginning and look at the configuration of the device in case that gives any clues. If you would, please go to Plugins ->Sharp TV Network Remove->Log Device Details. This will allow you to select your TV device and export details to the event log that you can then copy/paste in (you may want to remove the password as it will show).
I BELIEVE that menu item is available in your version - if not then let me know and I'll check the released version.
Adam
Tue Mar 24, 2020 1:10 pm
dduff617 offline
I wanted to control my Sharp TV and was having some problems. So I am reviving an ancient thread. I have a Sharp 6400U model. As reported by pacman, my TV seems to connect and exchange data with the plugin for a while, then disconnects and there are no further updates after that. I'm not positive but I think I had this working ok a few years back and I was using it to turn my TV on and off when my Harmony changed modes.
Now, it seems like nothing works - if I turn the TV on/off with remote, the device status in Indigo does not change. I don't seem to be able to send any commands to the TV from the plugin.
Here's the result of Plugins ->Sharp TV Network Remote->Log Device Details
Sharp TV Network Remote Plugin Dumping details for DeviceID: 1738424886
Sharp TV Network Remote Plugin address : 192.168.1.30:10002
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : sharpTvRemoteDevice
displayStateId : powerState
displayStateImageSel : SensorOn
displayStateValRaw : True
displayStateValUi : On
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1983864326
com.duncanware.sharpTvNetworkRemote : (dict)
address : 192.168.1.30:10002 (string)
input0Label : TV Tuner (string)
input1Label : HDMI 1 (string)
input2Label : HDMI 2 (string)
input3Label : HDMI 3 (string)
input4Label : HDMI 4 (string)
input5Label : Component (string)
input6Label : Video 1 (string)
input7Label : Video 2 (string)
input8Label : PC (string)
ipAddress : 192.168.1.30 (string)
portNumber : 10002 (string)
requiresLogin : false (bool)
tvPassword : (string)
tvUsername : (string)
updateInterval : 10 (string)
lastChanged : 2020-03-24 15:01:26
lastSuccessfulComm : 2020-03-24 15:01:26
model : Sharp TV Network Remote Control
name : 0MR Sharp TV
ownerProps : com.duncanware.sharpTvNetworkRemote : (dict)
pluginId : com.duncanware.sharpTvNetworkRemote
pluginProps : com.duncanware.sharpTvNetworkRemote : (dict)
protocol : Plugin
remoteDisplay : True
states : States : (dict)
avMode : N1 (string)
avMode.N1 : true (bool)
avMode.N100 : false (bool)
avMode.N110 : false (bool)
avMode.N111 : false (bool)
avMode.N14 : false (bool)
avMode.N15 : false (bool)
avMode.N16 : false (bool)
avMode.N17 : false (bool)
avMode.N18 : false (bool)
avMode.N2 : false (bool)
avMode.N3 : false (bool)
avMode.N300 : false (bool)
avMode.N4 : false (bool)
avMode.N5 : false (bool)
avMode.N6 : false (bool)
avMode.N7 : false (bool)
avMode.N8 : false (bool)
avMode.NERR : false (bool)
channelSelector : (string)
closedCaptioning : false (bool)
connectionState : Connected (string)
currentAnalogChannel : 0 (integer)
currentDigitalChannel : 0 (integer)
currentInputLabel : HDMI 3 (string)
currentInputNumber : 3 (integer)
deviceModel : C6400UA (string)
deviceName : My AQUOS TV (string)
isConnected : true (string)
muted : false (bool)
powerOnCommandsEnabled : false (bool)
powerState : true (bool)
powerState.ui : On (string)
sleepTimerMinutes : 0 (string)
surroundSoundMode : N2 (string)
surroundSoundMode.N1 : false (bool)
surroundSoundMode.N2 : true (bool)
surroundSoundMode.N4 : false (bool)
surroundSoundMode.N5 : false (bool)
surroundSoundMode.N6 : false (bool)
surroundSoundMode.NERR : false (bool)
viewMode : N2 (string)
viewMode.N1 : false (bool)
viewMode.N10 : false (bool)
viewMode.N11 : false (bool)
viewMode.N2 : true (bool)
viewMode.N3 : false (bool)
viewMode.N4 : false (bool)
viewMode.N5 : false (bool)
viewMode.N6 : false (bool)
viewMode.N7 : false (bool)
viewMode.N8 : false (bool)
viewMode.N9 : false (bool)
viewMode.NERR : false (bool)
volume : 20 (integer)
subModel :
supportsAllOff : False
supportsStatusRequest : False
version : None
Fri Mar 27, 2020 4:18 pm
Can you turn on debugging and then restart the plugin? Need to see the logs from when it attempts to initialize the TV device. Then perhaps try sending a command and getting that in the debug log as well. You can post here or send via PM... just watch as your password could be in the logs I think, if enabled.
Adam
