LC-XXLE653U Series - Status update failure
Thu Oct 08, 2015 7:37 am
RogueProeliator offline
Re: LC-XXLE653U Series - Status update failure
Give the latest version a try and disable the status polling -- the instructions are in the Device Configuration dialog, but try shutting off status updates completely by entering "-1" into the Polling Interval for the device. The normal status polling executes several commands in a row, so I am wondering if your TV locking up has to do with it receiving a bunch of commands that it doesn't respond to / know about.
You may get a disconnect error/message in the Indigo Log every so often as the TV may shut down the session without any activity, but the plugin will re-establish the connection. If that is working for you I can put in some code to suppress that error.
Adam
Fri Oct 09, 2015 6:42 pm
DougHahn offline
This is what I got after updating the plug in, but not before I change the status poll to -1. I'll try the -1 next. May have to reconnect.
Oct 9, 2015, 8:39:12 PM
Sharp TV Network Remote Plugin Debug set to True by user
WebServer request to execute "Main" control #23 from 127.0.0.1
Sharp TV Network Remote Plugin Debug Returning default GUIConfigValue for sharpTvRemoteDevice:deviceIsChildDevice
Sharp TV Network Remote Plugin Debug Command queue has 3 command(s) waiting
Sharp TV Network Remote Plugin Debug Sending command: POWR1
Sharp TV Network Remote Plugin Debug Write command completed.
Sharp TV Network Remote Plugin Debug Received: OK
Sharp TV Network Remote Plugin Debug Command queue has 2 command(s) waiting
Sharp TV Network Remote Plugin Debug Initiating sleep of 1.0 seconds from command.
Sharp TV Network Remote Plugin Debug Command queue has 1 command(s) waiting
Sharp TV Network Remote Plugin Debug Sending command: POWR?
Sharp TV Network Remote Plugin Debug Received: ERR
Sharp TV Network Remote Plugin Debug Found response match: powerStatusQuery
Sharp TV Network Remote Plugin Debug Effect execution: Update state "powerState" to "False"
Sharp TV Network Remote Plugin Debug Received w/o Command:
Fri Oct 09, 2015 6:47 pm
DougHahn offline
With the -1, it worked for the last 5 minutes, looks promising, let me see if it stabilizes.
Sat Nov 28, 2015 9:15 pm
DougHahn offline
Been stable all this time, thanks!
Sat Nov 28, 2015 11:15 pm
Great, thanks for following up and letting me know!
