Stack trace
Posted: Thu Jan 09, 2014 12:17 pm
When adding my new television for the first time (LC-60C6500U, which is the same as the LC-60LE650 but with a model number specific to Costco and Sams), I immediately got this error when I closed the config dialog:
Disabling the device and reenabling it results in the same. Tried to look at it quickly but it's apparently buried in the RPFramework library.
I couldn't get the Sharp TV Remote app to work, but I'm seeing the same issue everyone else is since they put up version 1.1 - it appears they broke the app (read the reviews and you'll see tons of complaints).
- Code: Select all
Sharp TV Network Remote Plugin Error Error in plugin execution:
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sharp TV Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkTelnetDevice.py", line 209, in concurrentCommandProcessingThread
self.handleDeviceResponse(responseText.replace(lineEndingToken, ""), command)
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sharp TV Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkTelnetDevice.py", line 330, in handleDeviceResponse
rpResponse.executeEffects(responseText, rpCommand, self, self.hostPlugin)
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sharp TV Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkDeviceResponse.py", line 115, in executeEffects
newStateValue = eval(newStateValueString)
File "<string>", line 1, in <module>
ValueError: invalid literal for int() with base 10: 'ERR'
